Help have coolant leak.
Old Apr 27, 2013 | 08:28 PM
RavageX's Avatar
RavageX
I have coolant leaking from behind the lowest pulley on the engine. It kind of looks like the bracket holding the pulley has a seal behind it that might be leaking. Does anyone have any idea what this might be? It is a 7.3l on a 2001 Excursion. Figures I just noticed that the coolant was low yesterday and today I take it for a drive and find a coolant trail down the driveway after it was parked for a few hours. Could it be the water pump? http://www.superdutypsd.com/water_pump_article.php
Old Apr 27, 2013 | 09:37 PM
jeffreyt's Avatar
jeffreyt
Coolant should be coming from somewhere above there. If that seal/gasket leaks, it would be oil, not coolant. I'm thinking its either the water pump, or more likely the thermostat housing.
Old Apr 27, 2013 | 10:39 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
There is a weep hole under the water pump. Right under the shaft the fan connects to. Reach under there and feel if that weep hole is wet.
Old Apr 28, 2013 | 08:27 AM
jeffreyt's Avatar
jeffreyt
This is a little off topic, but once you fix the coolant leak, you should really address that rusty oil pan. If it rusts through, you have to pull the engine to replace it. The good news is, it doesn't look bad, and can be sanded and painted in place
So there does look to be a little residue (discoloration) on the front cover above and to the right
And a little discoloration below the water pump pulley, but it's tough to see real well
Old Apr 28, 2013 | 01:39 PM
srteach's Avatar
srteach
What you describe indicates a failing seal / bearing on the water pump. Failing water pump usually shows up as a wet weep hole (location described above) first. This usually happens after the WP bearing is worn out. My guess is that it is time to replace the pump.
Another suggestion ... put a coolant filter on the system. When I did that, my water pump lasted much longer (4 months vs. 2 years so far). I clogged my first filter (grit and rust) in just a few weeks, the second in 2 months, and the third is still going strong. Old Coolant went from mud looking to dull green, then I changed the coolant. Coolant is bright green now.
Old Apr 28, 2013 | 03:14 PM
RavageX's Avatar
RavageX
awesome, thanks for all the info. going to go out and see if I can get my hand on the weep hole.
Old Apr 30, 2013 | 08:08 PM
RavageX's Avatar
RavageX
ok, well, couldn't quite find the weep hole with my hand but then my hand didn't fit very well. I don't think it is the housing leaking though didn't feel any leakage coming from around it. I priced out all the parts for a new pump, housing, ELC and came to about $400 total for parts for swap to one of the international pumps with the filter on them. Anyone here tried the international pump conversion?
<table border="0" cellpadding="0" cellspacing="0" width="569"><colgroup><col style="mso-width-source:userset;mso-width-alt:5961;width:122pt" width="163"> <col style="mso-width-source:userset;mso-width-alt472;width:194pt" width="259"> <col style="mso-width-source:userset;mso-width-alt:1536;width:32pt" width="42"> <col style="mso-width-source:userset;mso-width-alt:1499;width:31pt" width="41"> <col style="width:48pt" width="64"> </colgroup><tbody><tr style="height:15.0pt" height="20"> <td colspan="5" class="xl68" style="height:15.0pt;width:427pt" height="20" width="569">International Pump</td> </tr> <tr style="height:15.0pt" height="20"> <td class="xl65" style="height:15.0pt" height="20">Part #</td> <td class="xl65">Item</td> <td class="xl65">Price</td> <td class="xl65"> #</td> <td class="xl65"> Total</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1831676C92</td> <td>water pump</td> <td align="right">127</td> <td align="right">1</td> <td align="right">127</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1817958C1</td> <td>Bolt 30mm</td> <td align="right">1</td> <td align="right">3</td> <td align="right">3</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1817811C1</td> <td>Bolt 20mm</td> <td align="right">1</td> <td align="right">2</td> <td align="right">2</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1818693C1</td> <td>Bolt 110mm</td> <td align="right">1</td> <td align="right">4</td> <td align="right">4</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1823450C1</td> <td>Pulley Bearing Dust Cover</td> <td align="right">2.5</td> <td align="right">1</td> <td align="right">2.5</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">1823417C92</td> <td>Thermostat 197 degree</td> <td align="right">13</td> <td align="right">1</td> <td align="right">13</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">NAPA 8825/Gates #26517</td> <td class="xl66">Coolant flex-hose</td> <td align="right">40</td> <td align="right">1</td> <td align="right">40</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Riffraff</td> <td class="xl67">upper hose for around belt at riffraff</td> <td align="right">17</td> <td align="right">1</td> <td align="right">17</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">NAPA 705-1319</td> <td>Hose clamp</td> <td align="right">3</td> <td align="right">2</td> <td align="right">6</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">NAPA 705-1313</td> <td>Hose clamp</td> <td align="right">3</td> <td align="right">2</td> <td align="right">6</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">NAPA 705-1315</td> <td>Hose clamp</td> <td align="right">3</td> <td align="right">2</td> <td align="right">6</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Russell 663080</td> <td>1/2 NPT to 5/8 male barb 45*</td> <td align="right">10</td> <td align="right">1</td> <td align="right">10</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">
</td> <td>-205 Viton o-ring</td> <td align="right">0.5</td> <td align="right">10</td> <td align="right">5</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">NAPA FIL 4070</td> <td>NON-SCA coolant filter</td> <td align="right">10</td> <td align="right">1</td> <td align="right">10</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">
</td> <td>5/8 heater hose </td> <td align="right">1.5</td> <td align="right">4</td> <td align="right">6</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">
</td> <td>housing by Riffraff</td> <td align="right">48</td> <td align="right">1</td> <td align="right">48</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">
</td> <td>ELC coolant (per gal)</td> <td align="right">20</td> <td align="right">5</td> <td align="right">100</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">
</td> <td>
</td> <td>
</td> <td>
</td> <td align="right">405.5</td> </tr> </tbody></table>
Old Apr 30, 2013 | 08:54 PM
jspence105's Avatar
jspence105
Nicmike put an T444E water pump on his Ex.
Old Apr 30, 2013 | 09:50 PM
srteach's Avatar
srteach
I put my own DIY on my truck, but you can buy a kit from SP Diesel (look in filtration section).
It's cheaper and easier than an international pump setup.
Old May 1, 2013 | 01:31 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I did the T444e for about $240. Bought the pump from Bus Parts Experts (Florida), who happen to be having a 10% off sale right now...try using coupon code BPE0430 if you buy the pump from them. It really was easy to do. No more difficult than a regular pump swap. I did a write up on it under Trey's thread with photos and part numbers, etc. PM me if you decide to do it and have questions. https://www.ford-trucks.com/forums/1...ater-pump.html
Post #61 has a picture of the stock pump and weephole.
Old May 1, 2013 | 05:06 AM
jeffreyt's Avatar
jeffreyt
Just be sure you have single alternators. The dual setup runs the belt through the filter iirc.
Old May 13, 2013 | 11:24 PM
RavageX's Avatar
RavageX
thanks for all the help. Hopefully have enough saved up to buy all the parts to do the pump swap soon. Does the T444e pump use the stock pulley and fan?
Old May 14, 2013 | 01:18 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes it does.
Old May 25, 2013 | 06:49 PM
RavageX's Avatar
RavageX
Well, got the pump installed and almost everything hooked up. Still need coolant, -205 viton o-ring for filter valve, and a new thermostat housing. Hope I did everything right. Is there a difference between the Riffraff housing and the Diesel sight housing? I'll take some picks and post them up soon. Thanks again for all the help from those who have experience doing this before.
Old May 25, 2013 | 08:07 PM
jeffreyt's Avatar
jeffreyt
Not 100% here, but I think riffraff is the stock housing. The diesel site housing is a billet housing that is thicker and is supposed to seal better. I never had issues with stock housings sealing up, and haven't had the reason to update.
