Catastrophic engine failure?
Old May 27, 2020 | 04:59 PM
  #166
Calidiesel73red's Avatar
Calidiesel73red
Originally Posted by hosegp
Until you mentioned this, I had forgotten that when I changed out my EBP sensor a couple years ago, the only real change that I noticed was that my shift from 1st to 2nd got better. I have no idea why that was the case.
i've read something about it affecting line pressure or something, but don't quote me on that. There's way too much conflicting information about it. I'm just gonna clean/replace it and check it off the list of potential problems.
Old May 28, 2020 | 02:58 PM
  #167
Calidiesel73red
Unplugged ICP sensor and went for a drive. Noticed it’s running significantly better. Some oil visible when you disconnect it, probably warrants replacement. Still low on power and shifting hard, but less of a dog.
Old May 28, 2020 | 03:44 PM
  #168
Dan V's Avatar
Dan V
Well, this is a start. I'm surprised your mechanic didn't find this. At any rate, a new FORD (yes really) ICP and a new pigtail. RiffRaff would be glad to help you out. Diesel O-Rings could as well.
Old May 29, 2020 | 02:42 AM
  #169
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
What Dan said, new ICP for sure (and Ford or IH sensor only, no aftermarket!) but I'd inspect the harness closely before cutting in a new pigtail. If OE wires are good, cutting it up for a new pigtail just opens up more potential problems. Clean the oil off the harness with brake clean and inspect.
Old May 29, 2020 | 11:04 AM
  #170
Calidiesel73red
But is it possible for the sensor to be bad without throwing a code?
Old May 29, 2020 | 11:38 AM
  #171
Dan V's Avatar
Dan V
If it's leaking oil....it's bad.
Old May 29, 2020 | 12:08 PM
  #172
SkySkiJason's Avatar
SkySkiJason
Agreed. Or it will be.
The fact that it ‘runs better unplugged’ means it IS bad.
Does not necessarily throw a code when bad, but sends bad data to PCM.
Old May 29, 2020 | 01:57 PM
  #173
Calidiesel73red
Gotcha. Will order a new one today. Ford ones are pretty damn expensive compared to the $15 aftermarket ones :/
Old May 29, 2020 | 02:16 PM
  #174
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@Calidiesel73red Use @Riffraff Performance or @DieselOrings for your sensor and most OEM parts needs. Both of these shops are long time members of the 7.3L community, stand by their products, stand by their service and offer very competitive prices on genuine OEM parts.
https://www.riffraffdiesel.com/
https://www.dieselorings.com/
Old May 29, 2020 | 02:41 PM
  #175
RacinJasonWV's Avatar
RacinJasonWV
100% agreement with Sous on this matter. Those 2 places are consistently the cheapest for OEM parts and have good service.
Old May 30, 2020 | 09:17 AM
  #176
BBslider001's Avatar
BBslider001
Yup, good info all around from the guys...as usual. Stay patient. Believe me, we have all been through it one way or another. It sounds like you got a VERY abused and neglected truck.
Old May 30, 2020 | 04:31 PM
  #177
Calidiesel73red
Did some number-crunching to see where I stand financially. Obviously some estimates are gonna be off, but I think it's generally accurate. I am also missing some necessary items. The list doesn't address non-essential repairs like 4x4, interior, intake air heater, etc. Does this project still make any financial sense? Ignore "Mechanic #2" line-item, I didn't end up paying for it.
Old May 30, 2020 | 07:54 PM
  #178
Dan V's Avatar
Dan V
Light it on fire...push it over a cliff.
Old May 30, 2020 | 08:16 PM
  #179
BBslider001
Some of those are somewhat off. You gotta decide though. That tag issue would bother me most LOL. Sell it for 2k and call it done.
Old May 31, 2020 | 05:58 AM
  #180
SkySkiJason
I’d like to see it run right before committing to a large investment.
If it does not have blow-by, the engine is worth $1000-1500. The (bare) cab with clean title is worth $1000. Axles can bring $500 each, $500 for used transmission, $250 for t-case, $100 for good bumpers, $40 for a grill, etc. This does require time and a place to park the hulk while you sell it off.
I have paid $1000 for trucks similar to yours.
