F250 Project
Old Jan 23, 2020 | 01:35 PM
  #31
JohnNewb's Avatar
JohnNewb
I think he said it is a 302.
Old Jan 23, 2020 | 08:41 PM
  #32
Red60's Avatar
Red60
302 but not stock
Originally Posted by Byrd.Dog
That didn't look like a Y-Block that you pulled out; was that a 335 series? Are you rebuilding that one, or going back to a 292?
Unfortunately I do not have any 292's left but it has a 302 my dad was starting a conversion. I know. The 302 is so standard its boring but I did spice it up with 289 heads, 11:1 compression etc...
At least it wont be milk-crate boring. It was intended to be a race motor and I have it onhand for my build. My apologies to the purists in the crowd (I am kind of excited about the higher HP, RPM range and power to weight ratio though).
Old Jan 23, 2020 | 09:10 PM
  #33
spurredon's Avatar
spurredon
[QUOTE=Red60;19074220 My apologies to the purists in the crowd[/QUOTE]
Hey, it is a Ford in a Ford. Using what you have is always cool. Now tearing apart a totally fine truck to make it "different", but the same as other darksiders, that is where I would take exception. While I appreciate the work and effort and art it takes to make a custom, not my cup of tea. But hey, that is why they make both chocolate and vanilla! Enjoy your own truck your own way.
Old Jan 24, 2020 | 07:22 PM
  #34
Red60's Avatar
Red60
SLOW
Not making much progress, bogged down with the rear shocks not matching whats offered for 1960 F250! I need longer shocks than what the parts guys come up with. They suspect due to a lift but I don’t see spacers or evidence of aftermarket lift kit. Spent an hour looking in their book to find a setup to match my configuration... praying the KYB’s ordered work as intended. Specs:
perch to bolt on my truck no load is 19.5”
top is 3/8” stud
bottom is eye loop 5/8” bore 1.25” wide
BMC
Front brakes & shocks done
Passengers side
Rear shock lower mount bushing still stuck on
1.25” shoulder
0.625” OD
Old Jan 24, 2020 | 10:24 PM
  #35
Red60's Avatar
Red60
Gages Work!
Testing the gages shows they work fine. Book says 3vdc approximately full scale and yessir! Small victories but more in rear view
Fuel gage is most valuable. At least the indicator itself checks out as operational.
A picture of my test apparatus
Not sure but maybe I will use the factory temperature indicator. I did buy a triple gage set...
BMC
Old Jan 25, 2020 | 11:58 AM
  #36
Red60's Avatar
Red60
Drum bolts
Does anyone know why the drake drums have 3 bolts holding it to the axle/spindle? I have had to heat and impact driver them to remove. Big pain and am considering deleting them but want to know why they are used before I make that decision. Anyone know? Or even more important, what is the issue with leaving them off?
BMC
Three flathead countersunk bolts hold drum to axles. Why are these needed?
Old Jan 25, 2020 | 12:41 PM
  #37
Red60's Avatar
Red60
C7AA 18A952-A
What is this? It has a small wire coil under the insulation.
Old Jan 25, 2020 | 12:46 PM
  #38
spurredon's Avatar
spurredon
BMC
I see it looks kind of rough on the back of the speedo. When I redid mine, I neglected to keep/find the little red plastic lens that goes over the high beam indicator light. Without it, that little lite would be quite annoying shinning in my eyes. It took me a while to find something the right thickness to replace it with but sure am glad I did! I think I used a piece of broken tail light lens and taped it in place.
Old Jan 25, 2020 | 03:23 PM
  #39
Red60's Avatar
Red60
Dashboard
Thanks for the tip. The highbeam slot is covered
. The instrument cluster is getting a cleanup and overhaul
Old Jan 25, 2020 | 04:34 PM
  #40
spurredon's Avatar
spurredon
Pretty cool how simple and understandable the entire dash is compared to modern overkill.
Old Jan 25, 2020 | 04:42 PM
  #41
Red60's Avatar
Red60
Clean cluster
Nice to work on
Cardboard shields (standard issue)
I dont need the idiot lights anymore but will retain them un the absence of a better use of the hole...
Real glass real metal
Cleaned up respectable. Leaving the original paint
Old Jan 26, 2020 | 05:15 PM
  #42
Red60's Avatar
Red60
Wiring verification
Next week I'm into wiring verification. This part is hardest for me because I’m partially color blind. I also dislike standing on my head trying to see where it disappears and reappears. My beautiful bride helps me (1hr intervals) find the correct colors as they travel through the firewall/harness/pillars etc so thats a bonus. Taking lots of pics but not sure they would be intelligible posted here...
BMC
Old Feb 1, 2020 | 07:27 PM
  #43
Red60's Avatar
Red60
Pics of the drivers rear... looks like I am replacing the rear bearings while it’s open! They show wear and some small scoring so I would regret having to go back later.
Looks like the seal is leaking on everything. Brake pads are soaked.
Manual adjust only
Axle next
Old Feb 14, 2020 | 10:31 PM
  #44
Red60's Avatar
Red60
Update pics
Im spending plenty of time cleaning and fixing bullet connectors. I decided to replace all the electrical switches a since they look pretty used and corroded. For example the whole back of the ignition switch fell off the metal section connected to the dash! The light switch interior light dimmer ceramic was broken and the dimmer switch frozen solid. I need to figure out if I can replace or rebuild my two speed heater switch (recirculating style). Does anyone have a DIY to repair the stock switch? Reason I ask is LMC does not carry the 1959-1960 heater switch (but does the 61-63 lever style go figure). I also struck out on ebay. Did anyone cross this bridge without putting an aftermarket two speed switch under the dash??? PLEASE HELP!
Old Feb 15, 2020 | 07:21 AM
  #45
JohnNewb's Avatar
JohnNewb
Can't help with switch but welcome to the club. These series trucks are the least popular so many specific parts not produced by aftermarket vendors. LMC is great but according to their catalog there are no 350's or larger. I have to hope my parts are same as the 150 and 250. Or get ford numbers before ordering.
