F250 Project
Old Jan 4, 2020 | 08:41 PM
Red60's Avatar
Red60
Originally Posted by spurredon
You can always put a board across the frame for a seat. For the battery box, I just sand blast and get rid of the corrosion then paint several coats. I have put thin rubber mat under them before. I also try to keep the battery in good shape and put grease on the terminals to keep them clean to prevent problems.
Thank you Spurredon, paint is always a good protection. Never tried the board seat though...
I am considering using Herculiner rattle-can bed liner polyurithane. Has anyone else done it and have feedback on that idea or its durability?
Thx
BMC
Old Jan 4, 2020 | 09:32 PM
JohnNewb's Avatar
JohnNewb
The spray bedliner I tried was thin. Too thin for bedliner. Would likely work ok for battery tray. In a former life refurbing rock saws I used a lot of "hammer tone" paints. Says it encapsulates rust. Leaves a slight texture that hides rusty surface. Multiple coats best. Once it is cleaned and sealed routine maintenance will make it last.
Old Jan 4, 2020 | 09:40 PM
Red60's Avatar
Red60
Thanks! I will look into this. Have you used it in one of your battery boxes? I figure the more options one has, the best available decision can be obtained!
BMC
Old Jan 5, 2020 | 12:58 AM
JohnNewb's Avatar
JohnNewb
No. Mine was a little rusty on the shelf part. I wire brushed it a little, primered with red oxide primer and sprayed with gloss black enamel. Mine has a thin rubber mat to put under the battery.
Old Jan 5, 2020 | 07:16 PM
spurredon's Avatar
spurredon
The thing about getting it to thick is that it can crack and allow stuff to get under it. I have had that happen so I just use paint and a rubber mat, move to protect the paint from wearing thru. Your battery box looks fair to me. I had to use parts from several trucks to put a good one together.
Old Jan 11, 2020 | 02:34 PM
Red60's Avatar
Red60
Smile progress
Here are more pictures of whats going on.
Progress ALWAYS feels slow but I'm finding that if I take pictures as I go along, I can see the hurtles behind me.
Brakes look like they were new-ish
Stripped to backing plate
Shocks are DEAD Rubber parts shot to S!@#
Anyone have the part numbers for good replacement shocks?
Passengers side
Wheel cylinder plungers stuck to shoes LOL
Access to the firewall on drivers side is busy
Got everything zip tied out of the way . . Finally
Fenders are painted gloss black Battery tray is bedliner black Firewall is bedliner black
New wheel cylinders and hoses Decided to paint the backing plate (first time I have done this...Will see if it was a good idea)
New bearings and seals ready to go into the hubs
Old Jan 13, 2020 | 05:06 PM
spurredon's Avatar
spurredon
Looks like some real progress, always seems good to be working on new painted areas as opposed to old dirty rusty ones! You spent some time on those inner fenders and firewall.
Old Jan 14, 2020 | 09:19 PM
Red60's Avatar
Red60
Yes and glad its behind me. I regret not doing the firewall recently when I did the motor in Red but fixed it on this one!
My 289 heads are almost finished and can start the motor build soon...
BMC
Old Jan 15, 2020 | 08:40 AM
douglpr42's Avatar
douglpr42
like to see some pics of red one !
Old Jan 15, 2020 | 10:27 PM
Red60's Avatar
Red60
I introduced myself incorrectly in my first attempt to post:
My family says I bleed Old "Ford Blue"
in this post I gave pics of Red and new motor.
im trying to learn how this works and proper post techniques.
Old Jan 18, 2020 | 09:02 PM
Red60's Avatar
Red60
Need more shop time to move this further but baby steps is better than none
Some more pictures of this week
Old Jan 19, 2020 | 08:08 PM
spurredon's Avatar
spurredon
Lots of goodies!
Old Jan 19, 2020 | 08:36 PM
  #28
thrifty's Avatar
thrifty
Sure is purdy
Old Jan 22, 2020 | 06:55 PM
  #29
Red60's Avatar
Red60
Originally Posted by thrifty
Sure is purdy
Im hoping the 1/2” thicker core isn’t a problem in my conversion. Already losing an inch based on preliminary measurements from shifter to the water pump pulley...
Old Jan 23, 2020 | 01:18 PM
  #30
Byrd.Dog's Avatar
Byrd.Dog
That didn't look like a Y-Block that you pulled out; was that a 335 series? Are you rebuilding that one, or going back to a 292?
