2020 Order Guide.
Old Sep 27, 2019 | 06:48 PM
  #496
h20camper's Avatar
h20camper
Originally Posted by nick112288
Maybe I missed it (I'm on my phone), but why does that link show conventional towing specs only with 3.31 and 3.55 gears, but 5th wheel/goose neck it shows 3.73 and 4.3?
It shows them both for Regular cabs but I see what you are saying about SC and CC models.
Old Sep 27, 2019 | 06:49 PM
  #497
ForCal's Avatar
ForCal
Based on these charts, it looks like a F250 could be had with 10,800 GVRW? What is the conventional tow rating for a F250 CCSB 4x4 6.7L?
Old Sep 27, 2019 | 06:54 PM
  #498
h20camper's Avatar
h20camper
Good question. Apparently Ford no longer offers that configuration. (Just kidding.) Looks like this spec guide leaves a lot to be desired.
Old Sep 27, 2019 | 07:24 PM
  #499
ForCal's Avatar
ForCal
If the 7.3l F250 cc 4x4 is rated at 20K, the 6.7L should be at least the same. That would be a HUGE jump from what it is now (14,500?).
Old Sep 27, 2019 | 10:03 PM
  #500
puddintank's Avatar
puddintank
Height differences from 2019 to 2020 using the figures in the 2019 sales brochure:
Height differences from 2019 to 2020 using the figures in the 2019 Tech Specs PDF:
Old Sep 27, 2019 | 10:18 PM
  #501
puddintank's Avatar
puddintank
2019 Numbers:
https://media.ford.com/content/dam/f...Super-Duty.pdf
2020 Numbers:
https://media.ford.com/content/dam/f...Tech-Specs.pdf
For SRW models:
The regular cab 4x4, Super Cab SWB 4x4, Super Cab LWB 4x4, and Crew Cab LWB 4x4 all have a one inch lower distance from the tailgate to ground from 2019 to 2020. Both F250 and F350.
The regular cab 4x2, Super Cab SWB 4x2, Super Cab LWB 4x2, and Crew Cab LWB 4x2 were raised about half an inch from tailgate to ground from 2019 to 2020. Both F250 and F350.
For DRW:
The LWB 4x2 Crew Cab F350 is one inch higher from ground, negligible changes on the F450.
Old Sep 27, 2019 | 10:37 PM
  #502
drjcw24's Avatar
drjcw24
Looking at the guides from 19-20, it looks like the F450 height is unchanged. It's listed at 82 inches on the 2020 specs and 81.x on the 2019s from what I can see. I sure hope they didnt lower it any!
Old Sep 28, 2019 | 08:33 AM
  #503
nick112288's Avatar
nick112288
Maybe I'm reading it wrong but it appears the manual transfer case won't be available at all for 2020?
Old Sep 28, 2019 | 10:05 AM
  #504
h20camper's Avatar
h20camper
You're reading it correctly.
Old Sep 28, 2019 | 10:16 AM
  #505
cowzrul's Avatar
cowzrul
Originally Posted by puddintank
2019 Numbers:
2020 Numbers:
For SRW models:
For DRW:
I wonder how the lift on the Tremor Pkg will change these numbers? I haven't been able to find the height anywhere online.
Old Sep 28, 2019 | 10:48 AM
  #506
mxer0022's Avatar
mxer0022
Is it lifted of just leveled? I was under the impression they just through a leveling kit on up front.
Old Sep 28, 2019 | 11:27 AM
  #507
ForCal's Avatar
ForCal
Information from somewhere said front and rear.
Old Sep 28, 2019 | 11:41 AM
  #508
h20camper's Avatar
h20camper
The order guide leads you to believe only the front. I'm guessing just the front so the 35" tires clear everything. The rear already has the clearance.
Old Sep 28, 2019 | 11:46 AM
  #509
nick112288's Avatar
nick112288
Well that sucks! I wanted a 7.3 with the manual transfer case
Old Sep 28, 2019 | 03:15 PM
  #510
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Ongoing thanks to @h20camper and @puddintank for taking the time to supply screen shots to the forum so that members can see what is available without leaving the thread. I've sent reps to both, and if you've found that the time these members have taken to do what they did to be helpful to you, then give them some reps by clicking on the justice scales icon in the upper right hand corner of whichever of their posts you found to be useful to you.
