Pro Comp install
Old Feb 8, 2021 | 09:04 AM
  #151
bluovl's Avatar
bluovl
Originally Posted by bluovl
I just picked up the Ex from the paint shop today, I'll post pictures tomorrow. I'm thinking I want to reattach the front sway bar see if it makes a difference or not. I need longer end links. I want just a little more feedback or "road feel".
This a follow up to this question. The "road feel" issue turned out to be a worn out steering column. I replaced the housing and all bearings, and it made a huge difference. The rough bearings where masking the feedback from road.
Old Feb 8, 2021 | 09:20 AM
  #152
bluovl's Avatar
bluovl
My truck is 27.5 front and rear. I just measured it 5mins ago. This is after thousands miles over the road. This is right where it was when I finished the job last year. So the issue seams to be your front. How many shims did you install? I have one 2 degree shim on each side.
Old Feb 8, 2021 | 09:32 AM
  #153
Hayden Lewis's Avatar
Hayden Lewis
Thanks. I bought the WFO shims but my mechanic said they didn't fit into the bottom of the spring pack, I guess the hole was too small. Apparently it needs to be drilled larger? Anyway I had told him I wanted the caster at 5.5, he got it too 4.5 with no shims. It's riding great. My concern is my back is almost 2 inches lower so we want to put the rear block in but it's tapered and can only go with the fat part at back because of the bump stop part. Right now it's driving awesome with no driveline vibration at all....that's with no shims front or rear. I just can't figure out why the factory tapered block is thick part at the back and everyone else says thick part goes towards the front on the rear axle.
Old Feb 8, 2021 | 09:52 AM
  #154
Dweber85rc's Avatar
Dweber85rc
The thick part of the block goes to the back in a factory configuration for how oem lined up the driveline. When you lift it what worked at the factory can no longer be applicable.
Old Feb 8, 2021 | 10:04 AM
  #155
bluovl's Avatar
bluovl
I would try and figure out why the front ended up higher. I have no blocks or shims in the rear either, and the truck drives perfect. How about your track bar? I installed a Icon adjustable.
Old Feb 8, 2021 | 12:00 PM
  #156
Hayden Lewis
I bought an adjustable Freedom off-road bar. Alignment is great and it's riding great, I just hate that the front is 28.5 almost 29 inches! I wonder if they sent me the wrong front springs, they were labeled 22210 but maybe they're the 24410's? Crazy. I'm at 27 in the back from center of the wheel to the arch which is what everyone else is too.
Old Oct 24, 2021 | 07:18 PM
  #157
crashed_edition's Avatar
crashed_edition
I know the thread is kinds old, but I figured out the wfo shims today. They are made to be bolted onto the spring pack, not sat on. I realized this AFTER I drilled the holes out so the bottom of the spring pack would fit in it.
Long story short, new shims were ordered.
Old Oct 26, 2021 | 08:52 PM
  #158
pirate4x4_camo's Avatar
pirate4x4_camo
sounds like the fronts are 22410
you can pull the bottom leaf out of the front packs
in the rear, did you use the block ?
Dr. Johnson
Jul 13, 2012 06:23 PM
ford #7
Jun 21, 2012 11:55 PM
Ricky Jr
2004 - 2008 F150
Feb 19, 2008 08:24 AM
Bulldog187th
Offroad & 4x4
Sep 27, 2006 01:56 PM
Greg/Stu
1978 - 1996 Big Bronco
May 26, 2004 02:07 AM
