Pro Comp install
Old Jun 5, 2019 | 11:19 PM
  #121
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Blue oval,
how is the suspension project ? Driving impressions ?
Old Jun 6, 2019 | 01:38 AM
  #122
bluovl's Avatar
bluovl
Originally Posted by pirate4x4_camo
Blue oval,
I just picked up the Ex from the paint shop today, I'll post pictures tomorrow. I'm thinking I want to reattach the front sway bar see if it makes a difference or not. I need longer end links. I want just a little more feedback or "road feel".
Old Jun 6, 2019 | 09:11 AM
  #123
PrescottIce's Avatar
PrescottIce
So far, I've found mine to be okay without the sway bar. We have several two-lane roundabouts close to home, I tend to go into them a little fast if there's no traffic around to try and feel out the limits... there's a noticable degree of additional body roll, but not as much as I'd expect considering the body is literally six inches higher than it was - let alone the sway bar was removed.
I am concerned about how it will react in a highway-speed emergency avoidance "swerve" manuever. I'll have to work up to that.
Old Jun 6, 2019 | 09:40 AM
  #124
pirate4x4_camo
FTE Remembers
Put it back on and compare.
as far as high speed emergency swerve..... sticking with my theme of avoiding what the Ex is not good at and sticking to what it is good at. I suppose it depends on what you are swerving for but consider hitting it and not swerving since rolling is a likely outcome.
Old Jun 6, 2019 | 12:07 PM
  #125
PrescottIce
I probably won't bother putting it back on unless some cautious highway testing thoroughly terrifies me. And even with the bar installed, I doubt it would have a dramatic positive effect should my most feared scenario unfold.
Old Jun 6, 2019 | 12:56 PM
  #126
pirate4x4_camo
FTE Remembers
I would encourage you to try the front bar if for no other reason to compare the diffrence.
i prefer mine off over the factory bar as the size and mounting location is not ideal, I do have a smaller bar that mounts forward of the axle I am going to test. We shall see how that goes.
fwiw, It is a bar off of a RWD Ex.
Old Jul 13, 2019 | 09:28 PM
  #127
EX40's Avatar
EX40
Did the OP use a factory track bar? Pics earlier in the thread doesn't look like the Zone bar pictured on Amazon. Or am I looking at it wrong?
Old Jul 13, 2019 | 09:59 PM
  #128
bluovl's Avatar
bluovl
I did use the original factory track bar initially, and later switched to an Icon adjustable bar.
Old Jul 21, 2019 | 05:47 PM
  #129
EXSwap's Avatar
EXSwap
Hey @bluovl do you have a link or even just a size of the front ubolts you used with the 22210 pro Comps? Thanks!
Old Jul 21, 2019 | 08:11 PM
  #130
bluovl's Avatar
bluovl
I got them from 4wheel Parts. The same place I got the springs. They have exactly what you need. https://www.4wheelparts.com
Old Jul 22, 2019 | 08:31 AM
  #131
EXSwap's Avatar
EXSwap
Do you happen to remember the size you ordered? I know they have to be longer, just don't know by how much. Or what part number form 4 wheel parts? Thanks!
Old Jul 22, 2019 | 07:24 PM
  #132
bluovl's Avatar
bluovl
I don't remember, the counter guy looked up the ones Pro Comp recommended for the 22210 springs.
Old Jul 23, 2019 | 08:38 AM
  #133
EXSwap's Avatar
EXSwap
Thanks! I just called the local shop and the guy said they don't sell them other than in the kits with more items (and couldn't give me the part number )
@pirate4x4_camo do you happen to know the dimensions required for the front u-bolts for the 22210 springs? Or anyone else? I swear I saw someone reference it, but I've looked at the threads where folks have done it and I'm not seeing it. @PrescottIce @BigBlueX
Amazon kindly supplies a "maybe you want to buy this too" at the bottom of my order with some u-bolts, but I'm not confident they are actually what I need. I'd rather have a local shop make them (and I'd like to have them this weekend).
Thanks folks!!
Old Jul 23, 2019 | 09:03 AM
  #134
bluovl's Avatar
bluovl
That don't sound right? I bought mine separate at 4wheelparts here in SoCal. Their main warehouse is about 20 miles away. Anyway here's a link to their catalog for U bolts. https://www.4wheelparts.com/s?Ntt=u+...lectedTab=true Also WFO has em:https://www.wfoconcepts.com/pr/WFO-I...its/3208/16924. And there"s PMFwww.pmfsuspension.com/
Old Jul 23, 2019 | 04:15 PM
  #135
PrescottIce
I bought my front u-bolts from Summit:
Bolts: https://www.summitracing.com/parts/e...0510/overview/
Nuts: https://www.summitracing.com/parts/e...5302/overview/
