Removing the Engine
Old Dec 16, 2018 | 09:10 AM
F350 1990's Avatar
F350 1990
We've been customers of McMaster-Carr for many many moons --- they really have quite the selection and it seems we get most of the stuff next day or 2nd day....................I recommend them.
Old Dec 16, 2018 | 11:12 AM
TooManyToys.'s Avatar
TooManyToys.
Yep, I've been dealing with them on a professional and personal basis for almost 40 years. The pricing can be a little high but the one warehouse is driving distance away. I typically get things the next day, Monday if I order Sat morning. And the return policy is phenomenal, no time limit, no questions asked.
Old Dec 16, 2018 | 12:56 PM
BG0360350's Avatar
BG0360350
I used a ratchet strap to the frame rails to hold up the tranny. I just used a chain diagonally across, to pull the engine. I made a little cone out of thin metal (like a soda can) to make a guide for the torque converter. I put tape on the harmonic balancer and marked (and numbered) where the converter bolts were for torquing.
Old Dec 16, 2018 | 01:06 PM
TooManyToys.
Could you explain that? I can't get my head around doing that.
Old Dec 16, 2018 | 04:16 PM
Yahiko's Avatar
Yahiko
The problem with the converter is getting it back in and fully engaged with the pump and stater support.
Do it wrong and buy a transmission.
Old Dec 16, 2018 | 04:23 PM
HTM101's Avatar
HTM101
Today I got halfway thru relocating some overhead fluorescent lighting in the garage, and will be replacing them with two LED flat panel lights. Each panel is 2' x 4' and puts out 6250 lumens. I may be wearing sunglasses during the engine pull.
The propane powered forced air heater arrived 2 days ago. It puts out great heat for its compact size, and should make this winter engine pull a lot more comfortable.
Got a new 3/4" drive torque wrench, a longer breaker bar and some more goodies to help with the project.
David
Old Dec 16, 2018 | 04:35 PM
Yahiko's Avatar
Yahiko
Did you stock up of beer or some other adult beverage?
You likely will need something after to take care of any pain.
EDIT: The pain can be mental or physical or ever both.
Old Dec 17, 2018 | 08:24 AM
HTM101's Avatar
HTM101
I agree! Normally my hands will ache, so we keep a bottle of Aleve.
Old Dec 17, 2018 | 09:40 AM
BBslider001's Avatar
BBslider001
Beer is ALMOST the most important part.
Old Dec 17, 2018 | 10:08 AM
Tom14032's Avatar
Tom14032
A handy little tool to use for the upper starter bolt is this extension with a magnet. I used this coupled with another 6" extension. This little thing is great for a lot of things on the 6.0 where dropping bolts and nuts are critical.
https://store.snapon.com/Adaptors-Ma...r-P631048.aspx
Old Dec 17, 2018 | 11:49 AM
HTM101's Avatar
HTM101
I like that! After seeing it I ordered this trio of magnetic adapters.
https://www.ebay.com/itm/GearWrench-...72.m2749.l2649
David
Old Dec 17, 2018 | 01:49 PM
Yahiko's Avatar
Yahiko
Also a magnet pickup tool is handy for that dropped bolt or metal tool.
Works well for fishing out the dropped upper starter bolt.
Old Dec 18, 2018 | 07:04 AM
  #28
HTM101's Avatar
HTM101
Torque converter nuts...I know they are a flanged nut and the socket size is 14mm. I can't find the thread size and pitch, or part number. Do any of you know the part number?
Old Dec 18, 2018 | 08:01 AM
  #29
TooManyToys.
Old Dec 18, 2018 | 08:12 AM
  #30
HTM101's Avatar
HTM101
Jack,
Thanks for that photo. I've lost count of the number of threads/posts and searches I've done trying to find that part number.
David
