2019 Ambient lighting?
Old Nov 27, 2019 | 07:40 AM
  #151
Jason_8455JP's Avatar
Jason_8455JP
I just completed the front foot wells and under front seat oem ambient lighting to my 17’ Lariat to see how it went. Now I want to finish with all of the other locations but I’m not sure which part is correct for the cup holder lights. In the post above I saw two part references and both are very far apart in price and the more expensive one seems it has gone up in price. Any help would be greatly appreciated!
HC3Z-14A318-E $45
HC3Z-25045A76-CA $265
Old Nov 27, 2019 | 09:11 AM
  #152
jonathanjr1's Avatar
jonathanjr1
HC3Z-14A318-E $45
HC3Z-14A318-E is the lighting module if you have fixed color lights this is the part you need.
HC3Z-25045A76-CA is the cup holder assembly if you don't have the lights this is what you need.
Old Nov 27, 2019 | 10:11 AM
  #153
Mkos1980's Avatar
Mkos1980
Geez.... glad I bought all my stuff when it was cheap. Yup, you need the whole expensive console not just the wire module. Here's my order.
Old Nov 27, 2019 | 12:14 PM
  #154
Jason_8455JP
that is crazy!! Well I hate to spend that but it’s just not the same without it. I love how y’alls turned out.
I was intrigued reading all the threads adding this as mine did not have it but it did have them already in place under the seat, just not active. I ordered the front foot wells and went from there.
it’s fascinating parts were in place but not in use. The seat harness has everything wired to the led but the harness from the bcm to the seat harness was without the date and power wire.
the front foot wells had plugs but no leds in place but they were actually wired with the data wire fully, was just missing the power wire.
Old Nov 27, 2019 | 12:35 PM
  #155
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Just to be clear, there is no where to make the existing Ice Blue Ambient Lighting brighter via Sync3? I'll deal with the color, but it isn't very bright to really be useful
It's a bummer Ford did away with adjusting the colors like my 2016 F150
Old Nov 27, 2019 | 01:10 PM
  #156
ForCal's Avatar
ForCal
[QUOTE=Bullitt390;18970735]Just to be clear, there is no where to make the existing Ice Blue Ambient Lighting brighter via Sync3?
/QUOTE]
Not on the 19's. I did notice they brought the adjustability of brightness back for 2020. I thought maybe updating to that version of Sync, might include that feature, but according to those who have have done it, it still doesn't enable it on the 19's.
Old Dec 31, 2019 | 05:03 AM
  #157
Jeff6146's Avatar
Jeff6146
s
szsas
ssswwpppppssssssz.z"
Old Jan 6, 2020 | 10:54 PM
  #158
2013powerstroke6.7's Avatar
2013powerstroke6.7
I have a 19 lariat ultimate. I do not care about changing the color of the lighting, but is there a way to enable changing lighting intensity through forscan? When you shut it off all the lights get brighter so I know they can change. But I want them to be bright all the time, not just when I shut it off. Even if I could change a code through forscan and not have it change on the screen that is fine too. TIA
Old Jan 6, 2020 | 11:01 PM
  #159
ForCal's Avatar
ForCal
Originally Posted by 2013powerstroke6.7
I have a 19 lariat ultimate. I do not care about changing the color of the lighting, but is there a way to enable changing lighting intensity through forscan? When you shut it off all the lights get brighter so I know they can change. But I want them to be bright all the time, but just when I shut it off. TIA
The 2020s have that ability, with some people updating their Snyc to the 2020 version it had me wondering if that also included the ability to change the ambient lighting intensity. When I asked, I was told that it does not.
Old Jan 7, 2020 | 11:15 AM
  #160
Jeff6146's Avatar
Jeff6146
could you maybe elaborate a little on the 2020 version of sync3. Is that not what just came out a couple months back? Which version are you referring too?
TIA
Old Jan 7, 2020 | 08:27 PM
  #161
ForCal's Avatar
ForCal
TIA
I'm talking about the version that comes in the 2020's, its not available through Ford as an update for the pre 20's, but some have found a way to do it. There is a thread with instructions on how to do it to a pre 2020 truck.
Old Feb 7, 2020 | 11:37 PM
  #162
2013powerstroke6.7
Originally Posted by jonathanjr1
its possible to add it on the value package. I'm currently adding it to mine. My body harness came pre wired for it. the console and door harness are missing the conectors. I just need the time to add the missing conectors. Look under the driver and passanger seat for a lighting module if one is present you truck may be pre wired. Another place to look is behind the glove box to the right it there may be a small back conector with a cap inside of it.
These are the part numbers for the lighting modules. Some of these parts have been discontinued so some of you 19 guys may be out of luck.
FL3Z-13C724-D left hand door front
FL3Z-13C724-E right hand door rear
FL3Z-14A318-Y right hand front
fL3Z-13C724-F left hand door rear
FL3Z-14A411-F right footwell front
FL3Z-14A318-Q left footwell lamp c
FL3Z-14A318-L front seat passenger
FL3Z-14A318-N front seat driver
HC3Z-14A318-E cup holder light
These are the changes i made in forscan to enable it on my lariat value package.
7D0-01-02 xx 0B xx xx xx xx
726-31-01 xx 02 xx xx xx xx
726-39-01 xx xx xx 01 xx xx
I have a 2019 lariat ultimate and i actually prefer the ice blue but it is like barley on. If I make these changes through forscan will it give me the ability to change intensity of the current lighting? TIA
Old Feb 7, 2020 | 11:51 PM
  #163
jonathanjr1
you'll get the brightness control but I'm not shure if you'll get much more light out of the lighting modules. i have the color ones and the don't put out much light.
Old Feb 7, 2020 | 11:56 PM
  #164
2013powerstroke6.7
perfect. Are these changes in the BCM? Or a different one?
Old Feb 8, 2020 | 12:25 AM
  #165
jonathanjr1
there 1 in the apim and the other 2 are in the bcm. Once you changes those addresses in forscan (rember to save your original value for thoes addresses incase you want to change it back), the ambient light option will show up in the settings menu, you'll get the option to change colors in that menu, changing the color won't work but you'll be able to change the brightness by holding on one of the colors and sliding up or down.
