Console swap
Old May 14, 2018 | 04:36 PM
Chase4R's Avatar
Chase4R
Console swap
Those that have swapped the console, where did you get the best deal on parts? Was the swap easy for the most part? Any pointers? Thanks
Old May 14, 2018 | 05:25 PM
Tricon's Avatar
Tricon
I bought my console off eBay. Came out of a wrecked platinum for $250 shipped to my door. Its a super easy swap, 4 bolts out, 4 bolts in.
Old May 14, 2018 | 08:13 PM
h20camper's Avatar
h20camper
I'm purchasing the parts to assemble one as I didn't want an used one. Its quite a few parts and isn't cheap but it is cheaper than the $900 MSRP option listed for a XLT. As Tricon states above, and he told me as well, it should be an easy swap and looking at things, I'm in agreement. The dash bezels will probably be the roughest part and I've had those apart before. No big deal there. If you're interested in parting one together, I'd need your trim level and trim color.
Old May 15, 2018 | 11:18 AM
Chase4R's Avatar
Chase4R
That would be perfect! Thanks a million!
XLT
medium earth gray
Old May 15, 2018 | 08:19 PM
h20camper's Avatar
h20camper
Here ya go. The prices are approximate. Shop around online. The console is the killer on shipping. I found at a fairly close dealer for $225 with another 5% off. These prices are from FordPartsGiant. I bought all less the console from Varsity Ford in Ann Arbor. They are great!!!
  • HC3Z-25043C36-AA = <043C36 Rear Cover/Support $11
  • HC3Z-2504567-BA = <04567 Rear Cup Holders with chrome trim $44
  • HC3Z-25045A36-CA = <045A36 Console (Medium Earth Gray) $233
  • HC3Z-25045A76-AB = <045A76 Front Cup Holder and Trim (Medium Earth Gray) $117
  • HC3Z-25045E24-BA = <045E24 Rear Vents (Armor / Medium Earth Gray) $76
  • HC3Z-2504608-CC = <04608B Side Trim (Medium Earth Gray) $21
  • HC3Z-2504609-CA = <04608B Side Trim (Medium Earth Gray) $25
  • GL3Z-1506024-BB = <06024 Armrest $129
  • HC3Z-2513546-AA <13546 Tray $12
  • HC3Z-2504608-AA <04608A Slider Door $68
  • FL3Z-1504338-DC - Dash Bezel RH (Armor) $38
  • HC3Z-2504339-DA - Dash Bezel LH (Armor) $40
  • FL3Z-15046B32-BA -Sync Dash Opening for Slider door $20
  • FB5Z-19A495-AB - Rear USB Hub $28
  • HC3Z-25672A40-BA Cap $5
  • HC3Z-25672A40-AA Cap $5
  • HC3Z-14A318-AH Wiring Harness $19
  • (6) M6x25mm Bolts
  • Some misc screws I didn't list.
Old May 15, 2018 | 09:18 PM
fordboy2's Avatar
fordboy2
Need pics of this swap
Old May 15, 2018 | 09:47 PM
brandontolentino's Avatar
brandontolentino
I recently did this. I spent $450 on the console from Ebay. Needed a few other dash parts to make it work. I followed the youtube video but used the right dash parts. All in, I'm in it about $650. I did it mostly because I don't use the middle front seat, wanted more storage space, and really wanted the rear vents (the floor registers under the seats really don't kick out enough air to the back seats and I have 2 young kids.
It was literally plug and play for me. However, two of the 12V ports don't work because I don't have the right harness toward the front of the console. The one on the side of the console - for me - only powers one of the 12V connections in the big storage, and the 120V plug in the rear. So one of the 12V plugs in the big storage doesn't work and the 12V in the rear doesn't. I think there might be LED lighting that doesn't work either. I haven't had the chance to figure out the pin out of that front connector to try and enable all that stuff.
Old May 15, 2018 | 09:50 PM
briangp's Avatar
briangp
Damn, wish I knew you could give the breakdown like that earlier. I'm not sure its offered in my interior trim color though, XL problems.
Kinda happy I've only spent roughly 80 bucks on a home made center console though. (minus the cost of the sander that finally bit the dust)
Old May 15, 2018 | 09:51 PM
briangp's Avatar
briangp
h20camper, do you have any idea the pinouts for the console harness on the floor? I'm debating if I should tap into that or run my own wires.
Old May 15, 2018 | 09:52 PM
brandontolentino
What color is your interior?
Old May 15, 2018 | 09:58 PM
briangp's Avatar
briangp
I honestly haven't quite figured it out. I believe its considered the 'armour' color. I'm an STX so none of the fancy stuff. It's a really rough finish gun metal, and black. I honestly like it though.
Old May 15, 2018 | 10:10 PM
brandontolentino
I would think an all black console would work.
Old May 15, 2018 | 10:14 PM
briangp's Avatar
briangp
That's basically what I'm building. Black leather on the sides and black wood grain on the top.
Old May 16, 2018 | 08:42 AM
h20camper's Avatar
h20camper
Yes, I do but would need to know what all you are looking for. There's 21 pins on it. Many would not be applicable to your truck (XL/STX). Ambient Lighting, Rear Heated Seats, Keyless Antenna, etc
Old May 16, 2018 | 09:04 AM
briangp's Avatar
briangp
I'm a fluent electrician, and I like to tinker and add things, so I'll take whatever you have, assuming you have the schematic. You can PM me if you need.
