ESOF question
Old Nov 2, 2016 | 06:10 PM
RV_Tech's Avatar
RV_Tech
ESOF question
I have my vacuum system back up and working and using my vacuum pump I determined my lines are all good. They hold a vacuum fine, but my ESOF isn't engaging my hubs. I guess that leaves either the selector on the dash or the seal at the hubs.
If it is the selector, I should just be able to just disconnect the vacuum line at the selector and use my pump to engage my hubs. Anyone know how much it is supposed to take to activate the hubs?
Steve
Old Nov 2, 2016 | 06:25 PM
DieselDenny's Avatar
DieselDenny
Steve.
If you have a good hold on vac. Chances are your hubs are shot. Does the 4x work when you manually select at the hubs? If it does, therein lies the problem.
I went thru this for 12 years and finally decided the bother-hood of FTE was right and went with Mile-marker premium hubs. If you need to shift on the fly, leave them locked in. Otherwise, I run open until an event and I've scrubbed that problem off my sheit list.
Denny
Old Nov 2, 2016 | 06:35 PM
pirschwagon's Avatar
pirschwagon
Steve
The PVM (Pulse Vacuum Module) momentarily pulses 15 Hg which activates the Hub Locks.
1. Disconnect the Connector and see if there is 12 vdc when the switch is activated. If no, the problem is the (+), fuse/wire/Switch. Easily diagnosed with a Test Lamp or DVOM. If this test passes,
2. Place your vacuum Gauge / Pump on the output side and see if there is vacuum pulse when the switch is engaged. No, replace the PVM. If passes,
3. Do the same at each Vacuum Line at the Hub. No, bad vacuum line. Passes,
4. Pull your Hubs and clean, grease, new seal and reinstall using Guzzles Procedure (Google Search). The only other Gasket is the Yellow Hub Gasket which requires removing the Wheel Hub to replace.
Just curious, do the engage manually?
Old Nov 2, 2016 | 06:37 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by DieselDenny
Steve.
Denny
4x4 is great when manually selected
Old Nov 2, 2016 | 06:42 PM
RV_Tech's Avatar
RV_Tech
Since I have a dash light when selected does that not indicate the switch is working?
2. Place your vacuum Gauge / Pump on the output side and see if there is vacuum pulse when the switch is engaged. No, replace the PVM. Is PVM pump vaccuum motor? If passes,
Lines at both hubs hold a vacuum
They work fine manually. Here is the part I am shooting at. The hubs work find manually and are not hard to engage at all. If the vacuum lines are good to the hubs all the way from the solenoid, doesn't my problem have to be ahead of the solenoid.
It seems to me, the test for that would be to activate the hubs using my vacuum pump. If I can, I am upstream from the solenoid to the selector switch.
Steve
Old Nov 2, 2016 | 06:49 PM
SpringerPop's Avatar
SpringerPop
The rubber diaphragm inside the hub, that's actuated by the vacuum pulses, works on a little piece that works a lot like a ball-point pen mechanism.
Click-on, click-off.
There's a plastic component that is caught by a couple of tiny wires each shaped in an "L". The wires eventually wear out the plastic and the whole thing no longer operates.
It's pretty futile to attempt to make it work again once it stops.
When all that happens, the usual failure mode is "won't dis-engage". That means your front axles are always turning, even if the transfer case isn't driving them.
That creates a drive-line drag that will kill about one MPG of fuel economy, and contributes to excess wear.
Pop
Old Nov 2, 2016 | 06:58 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by SpringerPop
The rubber diaphragm inside the hub that's actuated by the vacuum pulses works on a little piece that works a lot like a ball-point pen mechanism.
That creates a drive-line drag that will kill about one MPG of fuel economy.
Pop
So, if I am following this correctly, it is possible to pull a good vacuum, verify the selector and the pulse and still have an inoperative system? That is kind of a pisser. I have checked and I know it is not engaged.
Steve
Old Nov 2, 2016 | 07:05 PM
SpringerPop
Also remember that the depth of the vacuum pulses is different from click-on than from click-off. It's pulling that little click mechanism different amounts.
I don't remember which utilizes "more" (deeper) vacuum, but if it's click-off that's deeper, and you're drawing more vacuum than that, it may just stay off.
Pop
Old Nov 2, 2016 | 07:12 PM
RV_Tech's Avatar
RV_Tech
Pop
You are just a wealth of happy news!
Any idea where I can track that pulse info down (I'll search the Internet unless there is an obvious) and if it is stuck off, if I work it manually should that not release it?
Old Nov 2, 2016 | 07:15 PM
DieselDenny
Correct!!! You can sweep your whole house and still hold vac even if the hubs are shot.
Depending on where you live (mountains) and need the f-off. (that's what I call the system) you can try to repair your stock hubs. I've bought many new and (a few used (when available) . I've also shipped out to fellow FTE bro's everything in stock for free including the shipping :'). If you use 4x4 rarely and your not big on working on the system regularly, my addy is go maual hubs and turn them when u think u need them.
Warn, Milemarkers, whatever. Just get the bulletproof one. Sorry I can't pinpoint your solution. Many tried on my failures, and many lost. Just cheaper and easier and when u need it, it's engaged.
Denny
Old Nov 2, 2016 | 07:20 PM
RV_Tech's Avatar
RV_Tech
Hey, I appreciate all the feedback. I love diagnostics, but I don't want to fall down the rat hole of no return. They work fine manually now and I only need them to back our fifth wheel up into the lot next to the house.
I'll likely chase it a bit further, but understand I have been warned.
Old Nov 2, 2016 | 07:22 PM
DieselDenny
A few years, but with the vac gauge...........should be an initial loss of less than next to nothing (can't recall) when the esof is triggered. And then an immediate stabile reading of prior. Never a plus or minus when the system was good.
Old Nov 2, 2016 | 07:24 PM
DieselDenny
Steve,
Just lock and unlock if that's what u use it for.
But, I just bought a fifth wheel and I know where to find you!!! LOL
Denny
Old Nov 2, 2016 | 07:42 PM
RV_Tech's Avatar
RV_Tech
I much better with RVs than my truck. I am just learning my truck.
Steve
Old Nov 2, 2016 | 07:52 PM
SpringerPop
Take a look at the second half of Post #8 in this thread:
https://www.ford-trucks.com/forums/1...b-problem.html
Though it's a four-year-old post, Greg's still around, and you could PM him if necessary.
Pop
