Ideas on problems starting?
i know the truck won't start with that low voltage.
i turned headlights back off and voltage climbed slowly back to 12.3 volts after another minute.
If i am confirm I'm doing my pvc testing correctly, my voltage drop test is garbage and will need to buy a new voltmeter, as all my voltage drops are incorrect.
with that being said, I also ordered a new motorcraft sw1951c solenoid (with 3 posts as I still have mechanical fuel pump, and will wire the solenoid up the way I was told, without running a lead wire to the solenoid on the starter, instead, I'll put on the jumper terminal. I'm sure the Chinese solenoid won't last, as it never did in the past....
Keep in mind a resistance ohms test is useless here, high current circuits (like a starter circuit) are tested for voltage drop, while energized, under load. There is no other way. Why?
Because the circuit carries about 200 amperes through it. So even a tiny bit of corrosion, even invisible - is enough to cripple an alternator or slow down a starter. That little resistance isn't enough to measure with consumer gear, we're talking a few hundredths of an ohm. That's why the name of the game with electrical connections is clean, bright, and tight.
Most all consumer DVOM's have a fine enough scale to measure the resistance. And it is far far more accurate then measuring for Volt drop as you see will the resistance increase before you pick up the volt drop.
You are absolutely right...................
Cause you have the meter set on DC Volts instead of Ohms
http://www.aa1car.com/library/voltage_drop_testing.htm
"It doesn't take much of an increase in resistance to cause trouble. Let's say a 120 amp alternator operates in a circuit that has a normal resistance of 0.11 ohms. If that resistance were increased to 0.17 ohms because of a bad wiring connection, the alternator's maximum output would be limited to 80 amps. In other words, an increase of only 0.06 ohms (almost nothing!) would reduce the alternator's maximum output by almost a third! Under light load, the drop in charging output might not even be noticeable. But in a high load situation, the alternator wouldn't be able to keep up."
Keep in mind it helps to read the task at the link here for the OP. We're measuring a cable or connection in parallel, with the voltmeter set on its lowest setting. Since voltage always seeks the path of least resistance, any voltage loss will be displayed as a positive number.
(Oftentimes people misunderstand the term "voltage drop", thinking it means the voltage across the battery terminals. That is a specific type of testing, but not what's referred to here.)
You want to see 12.80 volts, surface charge removed on a sealed, maintenance free battery. That's at 77° F; turn headlights on for five minutes. Turn off then wait at least 10 minutes before measuring. It should "bounce back" to 12.80 volts.
There is a correction factor applied when temperature is lower, for both charging and open circuit measurement.
Voltage Drop Testing
You are not saying anything I don't know I'v been doing this sort of diagnostic testing for over 4 decades and what do know went to shcool got a masters in this sort of stuff and specialized in tracing QA QC faults for serveral years. Ijust might happen to know a thing or 2 about this sort of stuff.
All you are suggesting is doing the same as has been done that has resulted in NO SOLUTION. Doing the same stuff over and over is not going to fix this. There is a reason to OHM out the cables and connections that will been needed later on to verify other checks.
So instead of jumping to conclusions maybe ask why I asked for this.....
Seriously any time something new is brought this board you lot have not seen or heard of it is the same old crap. You all think you know it all already and have nothing to more to learn........
Oh and BTW standard lead acid batteries generate 2.1Vs per cell, in a standard 12V auto battery the at rest voltage should be right around 12.6V, Not 12.8V. 12.4V is perfectly fine and falls with in serviceability. This battery is NOT a mait free battery, AGM, or other is it is standard low mait group 31 battery.
The $64 dollar question: You later said everything tested good. How did the parts store test the starter? This is very important. Did they just apply power to it and watch it spin? Or did they have a special machine that puts a load on it and makes it work hard?
Spinning the starter without a load on it is practically worthless. You'd catch one that is totally dead, but it wouldn't fault a starter that fails only under load.
