Block Heater
Old Dec 24, 2017 | 11:35 AM
  #166
MTP55's Avatar
MTP55
It's been soaked repeatedly plus heat and some tapping with a hammer. Everything I put on there starts to try and round the corners. I'm thinking bolt extractor might be the way to go.
Old Dec 24, 2017 | 02:05 PM
  #167
hydro man 17's Avatar
hydro man 17
A proper sized (may be metric) 12 point socket will fit that plug "head" if it is not too buggered up. Been there, done that.
Old Dec 24, 2017 | 02:23 PM
  #168
Colorado350's Avatar
Colorado350
Post up a pic of the head itself. What are you using for penetrating fluid? The other option besides a bolt extractor would be a quality vice grip. Do you have any CO2 that you could spray on it a freeze it? Another option I've had good success with is using a soldering gun and holding the tip on the bolt until everything is HOT!
Old Dec 24, 2017 | 02:33 PM
  #169
MTP55's Avatar
MTP55
Liquid wrench or pb blaster. My boss has shaffers. I have co2 for paintball guns.
Old Dec 24, 2017 | 02:40 PM
  #170
Colorado350
I'm partial to PB blaster or Kroil. Try the CO2, and/or the soldering iron and see if those work .Good Luck!
Old Dec 24, 2017 | 11:00 PM
  #171
Jaime74656's Avatar
Jaime74656
Short story: yes your block heater is toast (pun intended) replace it and the cord they both will come off anyway
long story: replace the block heater and it’s course, no need to Risk a flaming hot ride(or house if parked in a garage at night) I would also if replaceing the Tatar grab the built housing and new coolant lines and tank, but that is me and my thought process if if I’m taking off multiple items already for a flush I might as well replace with new/cleaning parts to make it faster/easier on me.
Old Dec 31, 2017 | 01:06 PM
  #172
Impcon1966's Avatar
Impcon1966
Heat element removal
Originally Posted by MTP55
I am trying to remove the heater element. It is a 02 and never replaced. I have put alot of force on this with no luck. What if any tricks to getting this out?
Old Dec 31, 2017 | 01:57 PM
  #173
Colorado350
Several days of KROIL or PB BLASTER and allow it to work! Remove the cord so you can get a socket on it .
Old Dec 31, 2017 | 02:00 PM
  #174
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
What John said and a breaker bar may be of use.
Old Dec 31, 2017 | 02:23 PM
  #175
Impcon1966's Avatar
Impcon1966
Thanks guys. I was just curious because of the material the oil cooler is made of. Didn't want to break the housing if the was some kind of trick. Thanks again for the help. Happy New Year.
HRSHAULER
25
Jan 11, 2009 01:46 PM
maevans
Jan 1, 2009 11:56 AM
RockyMtnRanger
Dec 3, 2007 09:03 AM
Tazzmann
Oct 28, 2006 06:45 AM
dsldandually
Feb 22, 2005 11:50 PM
