Block Heater
"When I drain it out of the block and radiator to do this job, do I need to flush the system?"
__________________________________________________ ______________________
Depends on if the previous flush and replace was done properly. IE: Per Gooch's procedure or equivalent. Otherwise it might be worth the effort to do so just so that YOU know.
thermostat, housing, any rad hoses that look suspect (recommend the upper rad hose that routes around the belt if not already equipped). All inexpensive parts that give you peace of mind it's all new and won't be needing attention and further disruption in the cooling system for a long time. I did water pump too when I flushed and went to ELC. I regretfully went with a reman that leaked like a sieve and grinded bad. Did it all again the next day with a new pump. Fail.
Oh and degas reservoir too if bottle is showing it's age. Mine was leaking at the seal a little so I went ahead and did that too.
Something to consider... RR makes a nice billet t stat housing with Allen wrench head bolts which is nice if you encounter a common rounded off oem bolt head like I did.
I know the radiator hoses were replaced shortly before I bought it as well. Not sure on thermostat. I'll take a look in the morning. I'll probably skip on the water pump for now. Just dropped 1400 on new tires and new brake pads, rotors and a caliper. The cap looks new but the tank itself is a little dark/dingy looking.
Good looking rig. I like that color. Are those extended cab running boards and mounted backwards???
Not a clue. They do look a bit short. They were on there when I got it last spring. Driver side is about ready to be removed before the Michigan environment removes it for me. I want to fix the rust and replace the box next year when I get my mechanical issues resolved over winter. Nothing major but things like what this thread is on. I like to get ahead when I can. I knew I should have put something else on my last Riffraff order. Haha. I normally don't care for the crew cab short box but it's grown on me.
