Block heater ?
Old Nov 28, 2007 | 10:52 PM
RockyMtnRanger's Avatar
RockyMtnRanger
Block heater ?
I bought a replacement block heater and cord set to replace mine that recently stopped working. My question is..... is this a heater that heats up the metal of the block or is it immersed in the coolant fluid? I thought they were heating up the metal, but the end of this thing looks as though it would go into liquid. It looks like one of the portable coffee heaters with the copper looking element. Is this right? All the numbers match up so I'm sure it's the right part. Any help is appreciated.
Marty
Old Nov 28, 2007 | 10:58 PM
dmunns's Avatar
dmunns
It is immersed in the water, goes in the block on the drivers side. takes longer to reroute the new cord than to install the heater unit. Watch out when you pull the old one, lots of antfreeze that doesn't drain from the drain plug in the radiator. just changed mine last week
Old Nov 28, 2007 | 11:01 PM
RockyMtnRanger
Thanks for the info. That is what I was thinking too, but wanted to make sure. Rep points to you for the extra atifreeze shower tip.
PS Ok I feel like an idiot... how the hell do you give someone REP points????
Marty
Old Nov 29, 2007 | 12:00 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Marty, go to the upper R/H corner of his post next to the post #, click that scale looking thingy, the rest is self expanatory.
Old Nov 29, 2007 | 12:03 AM
RockyMtnRanger
Duh got it...thanks a bunch....
Old Nov 30, 2007 | 12:42 AM
dmunns's Avatar
dmunns
Good luck make sure you run the engine to get the air out before you plug in the new heater, that is after you fill it again with antifreeze. I you have lots of miles it is a good time to flush your cooling system before you change the block heater
Old Dec 3, 2007 | 09:03 AM
RockyMtnRanger
Thanks for the tip. Had the fluid changed little less than a year ago, so should be ok.
Marty
Marty69F250
Dec 18, 2014 10:07 PM
Oxfordrider
Dec 30, 2012 09:19 AM
tje2015
Jan 26, 2012 07:09 AM
FSJ-EARL
Jan 4, 2010 06:43 AM
Learath
Dec 4, 2006 10:18 AM
