Block Heater
Old Dec 11, 2017 | 08:30 AM
  #106
Colorado350's Avatar
Colorado350
If I saw it but didn't know what it was I'd guess it was new oil aka a caramel color.
Old Dec 11, 2017 | 08:32 AM
  #107
MTP55's Avatar
MTP55
So are you suggesting that there is oil in that coolant?
Old Dec 11, 2017 | 08:37 AM
  #108
Colorado350
Honestly, it's hard to say...depending on what coolant they used it could be the natural color. IIRC, weren't you going to rebuild your oil cooler? If you did, did you flush everything?
Old Dec 11, 2017 | 08:39 AM
  #109
MTP55's Avatar
MTP55
That is what I'm in the process of at the moment. Still have to drain the block as of yet. I've been working on it before and after work.
Old Dec 11, 2017 | 09:10 AM
  #110
MTP55's Avatar
MTP55
If you shine a trouble light through it, it look yellow or green. Any hint of brown disappears.
Old Dec 11, 2017 | 09:30 AM
  #111
Walleye Hunter's Avatar
Walleye Hunter
I can't figure out what color you have there but I can tell you that if there is oil in the coolant it sits on top, it won't mix in, oil and water are not the least bit soluble with each other and oil is less dense than water so it rises to the top.
Old Dec 11, 2017 | 09:38 AM
  #112
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The color is hard to tell what it might be. It could be green mixed with gold, or dirty gold, or dirty green, you see where I am going with this...
I don't really see any signs of oil, but a picture may not be telling the full story.
Old Dec 11, 2017 | 09:57 AM
  #113
MTP55's Avatar
MTP55
It looks like a yellow/green with the light shown through. There wasn't any skim stuff sitting up top. Just a little sand at the bottom but I am installing a filter for that. I know my coolant I just put in my tractor was a gold color.
Old Dec 11, 2017 | 02:15 PM
  #114
Bonanza35's Avatar
Bonanza35
I agree with this. If your rebuilding the oil cooler, I just flush and add new of your choice. Should be fine.
Old Dec 11, 2017 | 05:01 PM
  #115
MTP55's Avatar
MTP55
Question. How do you get to the plug on passenger side of block to drain coolant? I know it's behind the starter but I can't see it no matter which way I go.
Old Dec 11, 2017 | 05:31 PM
  #116
Sous's Avatar
Sous
FTE Emeritus
Once you see it, you will think that it is a good thing it was not a snake...
Old Dec 11, 2017 | 05:35 PM
  #117
Chevota_72's Avatar
Chevota_72
You can reach it easy enough with the starter installed with about 6" worth of extension.
Old Dec 11, 2017 | 05:44 PM
  #118
MTP55's Avatar
MTP55
Haha. I hate snakes.... The plug on my driver's side is all goofy. 1/4" is too small 3/8 too big. If I flush repeatedly can I get away with not removing them? It was have already been tampered with and be stripped.
Old Dec 11, 2017 | 05:46 PM
  #119
Chevota_72's Avatar
Chevota_72
That is the plug for oil you are trying to remove. Look up higher on the block and you will find the coolant one.
Old Dec 11, 2017 | 05:49 PM
  #120
Sous's Avatar
Sous
FTE Emeritus
I was not able to get the passenger side plug out either. After 18 years of running the engine, it was not budging.
I had 40 gallons of distilled water ready to go through the system to flush it. I have well water, so no chance of running that through the cooling system. I think about 20ish gallons in the water was being returned to the bottle as clear as it was going in.
The short answer is you should be fine, just remember to turn on the heater in the truck in order to get the coolant out of there too!
Also...
