Sync 3 3.0 - Issues
Old Feb 7, 2018 | 11:18 AM
  #106
JohnnyMarauder's Avatar
JohnnyMarauder
I'm usually pretty good with the googles... but this one does not come up.
Old Feb 8, 2018 | 11:03 AM
  #107
Anibal Medina's Avatar
Anibal Medina
I got the file from that German website but my radio does not start with the update, maybe need new usb drive, or I am not doing it right I did it putting the folder on drive and nothing, and I tried putting files from folder on root of drive and nothing too.
Old Feb 8, 2018 | 07:14 PM
  #108
Anibal Medina
Originally Posted by PSM 6.4
New build out
3.0.18025
:sound quality improvement over older versions especially build 17276
:improvements/bug fixes for voice recognition
:bug fix over ios 11.2.5 with applink connectivity issues
got what I needed but can't figure out how to install the file looks different.
Old Feb 8, 2018 | 08:15 PM
  #109
PSM 6.4's Avatar
PSM 6.4
This file is test at your own risk.
Old Feb 8, 2018 | 08:19 PM
  #110
System's Avatar
System
Prolocutor
From what I've been told, it's a generic Sync three update and needs to have an auto install file created. It's beyond my tech ability or I would have done it already.
Old Feb 8, 2018 | 09:22 PM
  #111
Anibal Medina
Yeah when I posted v2.2 I provided the info for everyone to do but some don’t want to share the knowledge, oh well, when I figure it out I will post the steps so we can install it.
Old Feb 9, 2018 | 08:20 AM
  #112
GABAR's Avatar
GABAR
You guys better be careful.
Ford has been cracking down on individuals and Forums who are posting these unreleased updates.
Old Mar 27, 2018 | 02:57 PM
  #113
System's Avatar
System
Prolocutor
The official V3 is now available from the Ford owner's site. The problem is, if you updated to the previous V3 beta version, your truck won't accept the new official version. About a minute into the install it will tell you that your system is already updated. It would appear from some research that there is a version checker in the official releases from version 2.3 forward. So, the installer is checking the current version not the current build. If it sees you already have any build of V3, you can not install a later one. Now the question is... do I try and downgrade to version 2.2 and then re-try the official 3 V3 update or just wait it out for the next version... Hmmm.....
Old Mar 27, 2018 | 03:56 PM
  #114
hinsong's Avatar
hinsong
This issue was resolved by SoylentSaxgod in the thread linked below (Post #81). I had the same issue and this worked perfectly.
https://www.ford-trucks.com/forums/1...-update-6.html
Old Mar 27, 2018 | 04:12 PM
  #115
System's Avatar
System
Prolocutor
Thanks Greg! Will try now!!! What program did you use to edit the text?
Old Mar 27, 2018 | 04:39 PM
  #116
k7lvo's Avatar
k7lvo
I used Notepad. Everything went just fine. 👍
Old Mar 27, 2018 | 05:05 PM
  #117
System's Avatar
System
Prolocutor
Thanks Lewis. That was super easy and it's now updating to the official V3. Thanks again guys...
Old Mar 27, 2018 | 06:24 PM
  #118
~erik~'s Avatar
~erik~
I'm tempted to try it to see if it'll cure my "default to FM" audio system, and the persistent pop up asking if I want to connect to Wifi.
Do the text edits work on a non-nav system? I believe someone also asked that on the other discussion thread, but I don't recall a confirmation.
I'm worried about making it worse than it is. I have the unofficial V3 and it works fine except for the two snags I mention in my opening sentence.
Thanks!
Old Mar 27, 2018 | 07:18 PM
  #119
Spoojr's Avatar
Spoojr
Boo! I tried a reboot, and a re-install, and it still gets stuck on “Updating Software”. I’m at a loss...running version 2.3 currently with no issues.
Old Apr 8, 2018 | 08:31 PM
  #120
Michael Bell's Avatar
Michael Bell
3rd Gear
I too am having the issue with defaulting to FM and it seems to have started for me after the ver. 3 update. I guess no one has a solution?
