Sync 3 3.0 - Issues
Old Oct 29, 2017 | 09:29 PM
  #76
ruphianh's Avatar
ruphianh
Originally Posted by Karl4Cat
3.0 does add the heated steering wheel button to the home screen if you have it.
Same way FORScan adds it and the seats to 2.0 or differently?
Old Oct 30, 2017 | 05:52 AM
  #77
Xwild's Avatar
Xwild
DId the same update as Jax yesterday as well. Went from original 2.0 to the latest 3.0 So far so good..Seems to boot quite a bit faster.
Old Oct 30, 2017 | 08:27 AM
  #78
System's Avatar
System
Prolocutor
AFAIK it's the same, but I never did the Forscan one so I'm not 100% sure.
Old Oct 30, 2017 | 09:00 AM
  #79
Texmudder's Avatar
Texmudder
I have installed the new build for the 3.0 and it too tells me to connect to WiFi networks. No change in that behavior at all.
Old Oct 30, 2017 | 04:20 PM
  #80
Xwild's Avatar
Xwild
Texmudder - Connect to a wifi and tell it to scan for updates, and it will stop prompting everytime you startup.
Old Oct 30, 2017 | 04:50 PM
  #81
jaxf250's Avatar
jaxf250
I saw no notable issues today while using the new update. The menus respond faster to the touch, and seeking through the channels is faster as well. I already did the heated steering wheel modification in forscan before the sync update, so I can't comment on whether or not the heated steering wheel icon comes up on the homepage now with this update by default. I'll keep testing this week and let you know if I see any issues. It is not asking me to connect to my wifi repeatedly, so I don't think that bug is present anymore. Making and receiving Bluetooth phone calls works just fine, but I didn't have a chance to test out any of the voice commands yet.
Old Oct 30, 2017 | 09:30 PM
  #82
Biggsy90's Avatar
Biggsy90
Did the latest 3.0 update from 2.2. Went smooth, but took a while 20 min or so. Works better and responds faster. Mine still randomly switches to AM on startup. Annoying. Haven't had the connect to WiFi issue, but did look for updates right after install.
Old Oct 31, 2017 | 07:56 AM
  #83
~erik~'s Avatar
~erik~
Is there any trick to doing this? Mine is connected to WiFi and I click "yes" when it does the WiFi prompt, but nothing happens. Is there some manual way to go in and tell it to scan for updates?
Thanks!
Old Oct 31, 2017 | 09:11 PM
  #84
jaxf250's Avatar
jaxf250
Here's the first bug I see, and I think it was reported in an earlier release too: when you have the radio on to Sirius and shut the truck off without turning the radio off first, when you restart the truck the radio switches to the FM band instead of Sirius. Doesn't occur of course if you shut the radio off prior to shutting the truck off, but is a bug nonetheless.
Old Oct 31, 2017 | 09:16 PM
  #85
~erik~'s Avatar
~erik~
Loading the latest release of Sync 3.0 didn't fix that bug for me. However I can work around it on my Lariat with the old fashioned key start. I just turn on the ignition, listen for Sirius to start playing, then turn the key the rest of the way to start the engine. It takes a few seconds for the audio to play again, but when it does it's playing my Sirius station.
I guess if you have keyless start you'd push the START button with your foot off the brake to turn on just the ignition, then push it again with the brake pedal depressed to start the engine. Bit of a pain in the @ss.
Old Oct 31, 2017 | 10:41 PM
  #86
jaxf250's Avatar
jaxf250
Lol yeah I have the pushbutton start and it's enough for me to remember to press the brake before the button, so reversing that now would cause an embolism. Can't teach an old dog new tricks, or something like that lol!
Old Nov 2, 2017 | 11:47 AM
  #87
Biggsy90's Avatar
Biggsy90
I'm in the same boat. I think about turning off the stereo as I'm pulling into a parking spot, then have forgotten 10 seconds later when I shut the truck down!
Old Dec 29, 2017 | 04:06 AM
  #88
PSM 6.4's Avatar
PSM 6.4
Anyone have a link to the latest sync v3.0 build?
Old Dec 29, 2017 | 06:16 AM
  #89
System's Avatar
System
Prolocutor
Go back one page in this thread.
Old Jan 2, 2018 | 10:43 AM
  #90
Texmudder's Avatar
Texmudder
Build 17276 is still asking for WiFi connection upon every start. I have connected to WiFi and was able to check for updates. It still asks for this.
