Sync 3 3.0 - Issues
Old Oct 3, 2017 | 01:26 PM
  #46
Texmudder's Avatar
Texmudder
Found it through the search.
Old Oct 3, 2017 | 01:31 PM
  #47
RugbyRef's Avatar
RugbyRef
Originally Posted by Texmudder
Have you got a link to it? I wasnt smart enough to save it and this wifi thing is not worth the hassle.
Here you go!
https://www.ford-trucks.com/forums/1...load-site.html
Old Oct 3, 2017 | 01:38 PM
  #48
pickerdd's Avatar
pickerdd
Thanks for the link to the update to v 2.2!
Old Oct 6, 2017 | 12:25 PM
  #49
1956Fatfenders's Avatar
1956Fatfenders
Update on the reverting to FM on restart...
As mentioned previously, with 3.0, upon restart, the radio reverts to FM, instead of XM where I left it. Using the remote start, XM is default once I put the key in the ignition.
What's new? Found if I turn the radio off before shutting down, when restarted with key and I turn the radio back on, XM is default. No a big deal for me, just a minor annoyance.
Anyone found a way to turn off AM/FM in Forscan? I know XM can be turned off...
Old Oct 6, 2017 | 01:16 PM
  #50
~erik~'s Avatar
~erik~
I tried loading Sync 2.2 (non-NAV) over 3.0 and it's not doing anything other than telling me something has been plugged into the USB drive. The download consists of two zipped files and a read me file. Unzipping skips over the read me file, and I also can't open it to read it. Should it install with just the two zipped files unzipped and on a USB drive?
Thanks!
Old Oct 9, 2017 | 09:23 AM
  #51
RugbyRef's Avatar
RugbyRef
Thanks!
Erik - I had to unzip the files before I could load it.
Old Oct 9, 2017 | 09:25 AM
  #52
~erik~'s Avatar
~erik~
Thanks. I'll try again. I did unzip them, but to the same USB drive as the unzipped ones. Perhaps if I now delete the zipped versions it'll load the unzipped ones....
What about the readme file? Could not read it, could not unzip it...
Old Oct 21, 2017 | 09:26 PM
  #53
Stroking2017's Avatar
Stroking2017
Just reverted back to 2.2 from 3.0...got tired of the "wifi" message everytime I start the truck.
where did you gwt version 2.2? Thanks
Old Oct 24, 2017 | 07:55 PM
  #54
biggfranx's Avatar
biggfranx
Does anybody know how to delete old texts with 2.2 installed?? 2017 F-150
Old Oct 24, 2017 | 11:21 PM
  #55
ruphianh's Avatar
ruphianh
Originally Posted by wb6anp
remember the down loaded 3.0 is supposedly sill in "beta" it is not the official release yet. As far as I know so it will be buggy.
Does upgrading from 2.0 allow displaying Apple maps from the Ford sync home screen. Example, Apple maps would show the actual map where”maps” is shown on the picture
Old Oct 25, 2017 | 10:23 AM
  #56
ruphianh's Avatar
ruphianh
Bump. I’d like to know since this is tr only thing that would matter to me.
Old Oct 25, 2017 | 10:53 AM
  #57
nuctrooper's Avatar
nuctrooper
Negative - car play still does not show the map on the Ford sync home screen. I started with 2.0, upgraded to 2.2 and then to 3.0, and carplay does not show the map. I sure wish it would - I leave carplay disabled now, and will check again with each software update.
Old Oct 25, 2017 | 12:54 PM
  #58
ruphianh's Avatar
ruphianh
So I have 2.0 but the traffic works just fine. What is the actual benefit to 2.2 or 3.0? i can't actually find a definitive reason to upgrade.
Old Oct 25, 2017 | 01:02 PM
  #59
nuctrooper's Avatar
nuctrooper
No definitive reason I know of. I did the 2.2 and 3.0 hoping to gain carplay map functionality on the sync screen (which neither did). I'd say there is no solid reason to update the software. If you periodically watch this forum, a new update will flag quickly and prompt looking into an update. Otherwise just keep on truckin'.
Old Oct 25, 2017 | 02:11 PM
  #60
shawnw17's Avatar
shawnw17
3.0 is "snappier"....
And buggier. I wouldn't do the upgrade again given the opportunity.
