Official "leveled" thread
Old Aug 4, 2017 | 04:10 PM
  #226
kylant's Avatar
kylant
Originally Posted by natpark
It would be nice to know who has the adaptive steering and who does not that is experiencing issues after a leveling kit is I stalled. I would assume that the platinum and king ranch trucks as well as lariat ultimate all have adaptive steering but many of the others do too. I have lariat value package and have adaptive steering on my truck. Just a thought as I know there a few threads about the possibility of issues with these. I don't really see how it would matter as I understand it the AS is mostly speed dependant .
i have adaptive steering. after my carli 2.5" kit, the steering felt a little "light", minimally noticeable though. I installed the carli 2* caster shims. The steering feels good now, except if the truck is in tow/haul mode. the steering is significantly lighter. take it out of T/H, and the steering firms up.
I just ordered the SPC caster shims noted in the other thread. I hope they correct the right pull I have now
Old Aug 4, 2017 | 04:43 PM
  #227
Tricon's Avatar
Tricon
Doesn't that pretty much prove its the adaptive steering? I don't even have my cams in yet and the steering it's nice and tight. TH mode changes the responsiveness of the adaptive steering didn't it? I don't have it so I'm not sure, but I have no steering issues after my lift either.
Old Aug 4, 2017 | 06:28 PM
  #228
kylant's Avatar
kylant
yes, but really only noticeable in T/H mode. Like I said, the steering was minimally light without the caster adjustment, there just wasn't enough positive caster after the lift
Old Aug 4, 2017 | 08:38 PM
  #229
Tricon's Avatar
Tricon
So you just never going to use TH mode again?
Old Aug 5, 2017 | 09:38 PM
  #230
Tommy Levy's Avatar
Tommy Levy
Originally Posted by Beeg250
I have adaptive steering and the Icon 2.5 level and my steering is all over the place also. I am having a dual steering stabilizer installed this week. According to the shop that installed my leveling kit the stabilizer should fix my problem. I will report back with my findings.
how do the Carli 2.5" spring ride compared to stock? Thanks
Old Aug 5, 2017 | 09:51 PM
  #231
Beeg250's Avatar
Beeg250
I have the Icon springs, to me the trucks rides the same as it did with the stock springs. The difference I notice is in handling, the truck feels a lot more stable with the Icon springs and shocks.
Update on the steering issues: I had the BDS/Fox dual steering stabilizer installed last week. I'm still on the fence whether or not it fully fixed my steering issues. It definantly made the steering stiffer at lower speeds, but I still feel like the truck "walks" some at higher speeds when you hit a bump in the road. Also, I noticed that the steering wheel doesn't return to center when you turn it. I guess the added stabilizers are causing resistance. I guess the next thing I will try is either an adjustable track bar or drop bracket and see if that helps.
Old Aug 5, 2017 | 10:39 PM
  #232
Tommy Levy's Avatar
Tommy Levy
Originally Posted by wfedwar
Anyone using springs instead of spacers to level--is there a benefit to one vs the other?
i am wondering about this too and will need to decide which route to take by next. Any input is much appreciated. I'm looking for a full 2.5". Of lift and the best ride possible. Softest smoothest
Old Aug 5, 2017 | 10:43 PM
  #233
Tommy Levy's Avatar
Tommy Levy
[QUOTE=Beeg250;17377634]I have the Icon springs, to me the trucks rides the same as it did with the stock springs. The difference I notice is in handling, the truck feels a lot more stable with the Icon springs and shocks.
Update on the steering issues: I had the BDS/Fox dual steering stabilizer installed last week. I'm still on the fence whether or not it fully fixed my steering issues. It definantly made the steering stiffer at lower speeds, but I still feel like the truck "walks" some at higher speeds when you hit a bump in the road. Also, I noticed that the steering wheel doesn't return to center when you turn it. I guess the added stabilizers are causing resistance. I guess the next thing I will try is either an adjustable track bar or drop bracket and see if that helps.[/QUOTE
good deal. Appreciate it. Did the Icons lift it a full 2.5" and level it off?
Old Aug 5, 2017 | 11:21 PM
  #234
FlyinAg's Avatar
FlyinAg
Has anyone left the front end alone and just brought the rear end down a bit? I really don't need to level the front, and I tow as well, so I really don't want a pre-runner style front rake.
What I am really interested in is upgraded shocks and some sort of spring solution like the carli add a packs to improve the rear end ride when not towing. The roads here suck. Its interesting because large bumps don't seem to be much of an issue, the expansion cracks and undulated roads are killer.
I've done some looking around. The full deaver packs reduce load capacity so those are out... The add a packs look promising, but still seem to raise the back end? Could a smaller block be used with those?
Old Aug 5, 2017 | 11:23 PM
  #235
FmaxTurboSi's Avatar
FmaxTurboSi
I have the Carli 2.5" springs and absolutely love them!!! My buddy also has a 17, and he just ordered the same setup as me because he also really liked the new ride characteristics.
Old Aug 5, 2017 | 11:31 PM
  #236
FmaxTurboSi
Little update.......Painted parts and rear shocks installed. Still waiting on the fronts to arrive!!!
Old Aug 6, 2017 | 07:06 AM
  #237
Tommy Levy's Avatar
Tommy Levy
Originally Posted by Shreve T
I have adaptive steering with an ICON 2.5 spring level and do not feel nothing different in my steering what so ever... Feels just like the day i drove it off the lot..
how do you like the ride of the icon's and did they lift you a full 2.5"?
Old Aug 6, 2017 | 09:02 PM
  #238
Beeg250's Avatar
Beeg250
Yes truck sits level. The ride is better because the springs and shocks give the truck a more controlled feel, if that makes sense. The truck has less bounce than it did when it was stock, but still rides like a truck not an F150. Cornering is a lot more planted no body roll. This is the third Icon level I've had, had it on my 08 and 12 Super dutys and had good luck with them. If I could only figure out this crazy steering on the 17 truck it would be perfect.
Old Aug 6, 2017 | 09:04 PM
  #239
Beeg250's Avatar
Beeg250
Size:  3.14 MB Here is a picture of mine
Old Aug 6, 2017 | 10:04 PM
  #240
Flooringit's Avatar
Flooringit
I hAd a icon lift on my 07 outlaw. It was a 4.5'lift. It rode ok for a truck but the shocks squeaked like crazy. Never could get them to warranty them. They did it first day I put them on. I'd stick with carli springs and fox shocks if it were me. I plan on putting on 295s I may not get completely level may keep 1/2'rake
