Toyhauler modifications thread
Old Oct 9, 2017 | 11:14 AM
  #391
Tricon's Avatar
Tricon
Originally Posted by scraprat
Nice nothing wrong with free, quite power.
Seriously though, this 320w kit I bought from Solar Blvd really has me looking Elon Musk's way...solar tiles, a power wall, and a new Tesla for the wife...but honey, think of all the money we'll save! haha.
Old Oct 9, 2017 | 11:41 AM
  #392
Big-Foot's Avatar
Big-Foot
Love it!!!!
Old Oct 9, 2017 | 11:52 PM
  #393
Dakar Dad's Avatar
Dakar Dad
Yup, they were a little tall for my current boxes but they are perfect fit on the other dimensions. I bought the Costco variety GC-2's, the boxes came with the trailer, I can look later for the manufacturer, but if I were to buy again I'd look for a GC-2 sized case anyways.
Just my suggestion, but I had purchased two Trojan 6v batteries and had to get new boxes a year ago.
They are great batteries but a different shape than most. After alot of searching I got these boxes at Amazon and they fit great now.
Old Oct 10, 2017 | 12:25 AM
  #394
HRTKD's Avatar
HRTKD
I was hoping to put both batteries (Trojan T-125's) in the same box. NOCO produces a dual battery box.
Amazon link: http://a.co/4HeWZEB It's on my to-be-considered list. But at more than twice the cost of two single battery boxes I'm not sure a dual box is worth it. But I don't want to have to secure two boxes and coordinate cables between boxes.
Old Oct 10, 2017 | 12:39 AM
  #395
Dakar Dad's Avatar
Dakar Dad
I do remember seeing that box. It has been awhile but I think the base wasn't going to fit on my welded on angle iron on my battery mount.
Plus the cost was kind of high, but it does look like a tough box.
There is only one wire from one box to the other to make the connection, and so I made a new one on mine so that I could rotate one battery from the way it was before for a cleaner install.
Old Sep 11, 2018 | 07:55 PM
  #396
Curt's05's Avatar
Curt's05
Wiser by FTE
changed the clumsy keyed storage locks to tumblers! Added double usb port and color changing led lights over the countertop;
Old Sep 11, 2018 | 09:21 PM
  #397
pjones1969's Avatar
pjones1969
Made my own sewer storage box. I was looking at the Lippert crossbody undercarriage box systems, my rear jacks are offset so a double wouldn’t work and a single was very expensive. I started with this box from Global Industrial https://www.globalindustrial.com/p/s...8-x-7-3-4-gray
I cut the lid and screwed the back section to the sides of the bin, added some hinges, used 2 large stainless washers for the spring latch pin guide and then built a frame and bolted it across the frame. It holds everything we need.
Old Sep 11, 2018 | 10:45 PM
  #398
Dakar Dad's Avatar
Dakar Dad
Love your storage idea with the tub.
Don't see any storage containers that look like the one you used on that page with a lid.
Would you put a link to the direct page to the one that you used?
Old Sep 11, 2018 | 11:20 PM
  #399
HRTKD's Avatar
HRTKD
pjones1969, nice solution for the sewer hose. Did your toy hauler not come with place to put the hose? Mine didn't and the brochure says there was one. I can't find it. I cram it into the area where the fuel nozzle is stored. It's a very tight fit so it can be difficult to get it in there.
Old Sep 12, 2018 | 06:45 AM
  #400
pjones1969's Avatar
pjones1969
Here you go, its model KW-4L, item number WQ239928GY, my work computer isn't letting me link it properly for some reason
Old Sep 12, 2018 | 06:55 AM
  #401
pjones1969's Avatar
pjones1969
No factory storage, I was carrying 40-50 foot of sewer hose and accessories due to some places we go, I had one section of just what I use when dumping in a small bin, more in a larger bin and then I had one each extension in the doors that access the valve handles. I wanted to get all sewer related items out of the front storage compartment so I came up with this.
Old Sep 12, 2018 | 05:54 PM
  #402
CarterKraft's Avatar
CarterKraft
I love that DIY storage tote.
Old Sep 30, 2018 | 08:04 PM
  #403
HRTKD's Avatar
HRTKD
Guests have complained that the console switches that control the lights inside and outside of the cabin are hot to the touch. I suspect that the lights in the switches weren't LED which means that the lighted switch may actually use more amps than the LED light fixtures do. Today I replaced the old switches with new ones. The new switch bar isn't quite big enough to cover up the old hole. I need to find a sheet of plastic to go behind the switch bar.
Old switches
New switches
Old Oct 4, 2018 | 08:39 AM
  #404
CarterKraft
Those switches look great, where did you have those made. I have used Rockerswitchpros.com but am always looking for more options.
A cheap easy to source of 1/4" plus thick plastic type material is a cutting board. They can be had in many colors and are really handy for mods.
Old Oct 4, 2018 | 09:33 AM
  #405
HRTKD's Avatar
HRTKD
My switches came from Otrattw (link: https://www.otrattw.net/Contura-V-Se...dent-Lighting/). I have the Contura V series of switches.
Thanks for the tip on using cutting board. I bought some diamond plate aluminum that I'm going to try first.
