Toyhauler modifications thread
Old Apr 19, 2022 | 01:02 PM
  #481
MKrenn's Avatar
MKrenn
Looks awesome Jim. where did ya get the extendable pole? Hoping that would hold a DTV dish? Guessing it weighs around 12 pounds....
Old Apr 19, 2022 | 01:06 PM
  #482
HRTKD's Avatar
HRTKD
The pole came with the Weboost Destination RV kit, but you can buy just the pole. 12 pounds seems like a lot of weight to put on that pole. I have no idea what it's rated for.
Old Apr 20, 2022 | 10:08 AM
  #483
MKrenn's Avatar
MKrenn
Found this on Amazon.
Amazon Amazon
Old Apr 20, 2022 | 10:23 AM
  #484
HRTKD's Avatar
HRTKD
That'll work, as long as the antenna mast is small enough. Mine has a diameter of 2.5". You have to dig through the Q/A section where the vendor says that it should fit 2.5".
I'm going to play around with my ladder attachment. I was planning to create something like in that product. This part.
Old Apr 20, 2022 | 08:19 PM
  #485
HRTKD's Avatar
HRTKD
I tried my hand at bending some aluminum for a bracket. The plate on the right will fit on my 1" ladder tube. I pressed my luck trying for a 90° bend and my aluminum flat bar - on the left - just broke. If I want a 90° I'll have to weld two pieces together.
Old Apr 21, 2022 | 03:48 PM
  #486
MKrenn's Avatar
MKrenn
Sorry, didn't mean to create extra work for ya! I do some fabricating and have a couple buddies that can do it for me as well. But, I'm sure there's already something out there that is premade and you can purchase. Finding it is another story..... Thanks for the info Jim!
Old Apr 23, 2022 | 10:36 PM
  #487
HRTKD's Avatar
HRTKD
Version 2.0 of the ladder brackets. Bending was fun but wasn't a good plan. These are welded.
Old Jul 4, 2022 | 04:21 PM
  #488
stephen.osborne1's Avatar
stephen.osborne1
Added some modular shelves to the interior. Needed a place to put clothes,shoes,etc. These are Gladiator brand from Lowes. You mount the rails to the walls and can install any combination of wire shelves, baskets, or different hooks. Easy install and we can remove/ shuffle shelves and baskets to suit our needs. Getting ready now for a trip to Henry's Lake and Yellowstone. Taking the Ural and one side by side.
Old Feb 24, 2025 | 11:44 AM
  #489
HRTKD's Avatar
HRTKD
This thread fell off the map.
In my new toy hauler the OEM tie downs were in a terrible location. The OEM tie down is located at the three o'clock position. I added two new tie downs (6 o'clock position) that are as close to inline with the tires as I could get and still secure the tie down into the frame. Adding tie downs for the front is going to be very interesting. I suspect that the fresh water tank will be in the way.
Old Feb 24, 2025 | 03:15 PM
  #490
Dakar Dad's Avatar
Dakar Dad
Installing front wheel tie-downs over water tank.
In my new toy hauler the OEM tie downs were in a terrible location. I suspect that the fresh water tank will be in the way.
On mine they were in a terrible location also, and located over the water tank.
What I did was follow the pattern of the originals after replacing the one that was in the floor with a newer heavy duty style using the same bolt. and then installed one next to it in line with the tire.
The originals had a large bolt going through the frame so I used that same pattern with four wood screws in the floor for more strength.
New vehicle tie-down points.
Old Feb 24, 2025 | 04:21 PM
  #491
HRTKD's Avatar
HRTKD
Originally Posted by Dakar Dad
The originals had a large bolt going through the frame so I used that same pattern with four wood screws for strength.
Is your frame made out of wood? LOL!
When I say I went into the frame, I mean I went into the structural I-beam frame.
Old Feb 24, 2025 | 09:39 PM
  #492
Dakar Dad's Avatar
Dakar Dad
As I remember, the center bolt that was in the original tie-down was screwed into a metal cross beam, but the other 4 I installed only went into the wood floor.
fire240
Idaho Chapter
53
Jan 1, 2020 07:42 PM
tjc transport
New Jersey Chapter
233
Nov 1, 2016 07:06 AM
bpounds
S. California Chapter
189
Apr 1, 2014 01:58 PM
hav24wheel
North Dakota Chapter
222
Jan 7, 2014 10:52 PM
R1_Demon
Nevada Chapter
200
Oct 15, 2011 03:02 PM
