My 56 pickup build thread
Old Aug 20, 2015 | 05:56 PM
  #106
56panelford's Avatar
56panelford
touching up a few spots with metal to metal filler where there was a few pit marks under the sprig perches before I apply the epoxy primer and top coat.
Old Aug 21, 2015 | 08:53 PM
  #107
56panelford
The main frame rails were painted today as well as a few bolt on parts but still a few more left to do.
Old Sep 9, 2015 | 09:05 AM
  #108
56panelford
I did manage to get some of the front sheet metal sand blasted and covered in epoxy and the frame has been re-assembled but still need to install the rear diff but waiting for new backing plates to arrive. My shop is rather cluttered now and hard to move around in. I need to start cleaning up the motor and get it looking fresher, it is a stock 5.8 motor out of an 83 F 150 with less than 60,000 miles on it according to the owner I got it from, it's not a power horse but think I'll run it as is for now and maybe upgrade later, money is tight now that I'm retired.
Old Sep 24, 2015 | 07:53 PM
  #109
56panelford
I put some lipstick on a pig today, poor mans chrome...lol
Old Sep 25, 2015 | 08:35 AM
  #110
56panelford
It was a running motor when I pulled it from the truck it came in and has just over 55,000 miles on it. It should move this project just fine, not spending money under the hood will help with the other things needed. It does look better than this
Old Sep 25, 2015 | 08:46 AM
  #111
56panelford
Thinking of throwing the cab back on today and start the final body work soon. Still need to clean up the layer of rust on the hood and will blast it on the next nice day we have. I'm still in need of a box and will likely order a new one sometime before spring.
Old Sep 25, 2015 | 08:43 PM
  #112
56panelford
cab back on the painted frame
Old Sep 25, 2015 | 08:45 PM
  #113
56panelford
Old Oct 25, 2015 | 09:03 PM
  #114
56panelford
Just to bring this up to date I've assembled the front end again and will soon start spreading filler over these fenders and hood in preparation of primer.
Old Oct 25, 2015 | 09:05 PM
  #115
56panelford
I cut back the fan shroud so it gave a bit more clearance to the pulleys.
Old Oct 25, 2015 | 09:06 PM
  #116
56panelford
Made a simple tool to bend over the edge to stiffen the opening again.
Old Oct 25, 2015 | 09:07 PM
  #117
56panelford
Fits perfectly centered.
Old Oct 25, 2015 | 09:09 PM
  #118
56panelford
Continued with the assembly of front sheet metal.
Old Oct 25, 2015 | 09:11 PM
  #119
56panelford
Just need to do the wiring, complete an exhaust system, purchase a radiator and should hopefully have it running sometime this winter.
Old Oct 25, 2015 | 09:15 PM
  #120
56panelford
My battery tray was rotten so modified one pulled out of a scraped Chevy pickup and used the original side bracket and added an extension to the other end of the tray so it bolted to the running board bracket like the original set up.
