John, I have a set of Altmans sitting on the shelf. What dont you like about them without the power feature?
What I don't like is the only way to lock or unlock them is with the key, lets say you unlock the drivers door start the truck and drive down the street to pick someone up and the passenger door is locked you have to go and unlock the door from outside because they can't be unlocked from the inside and why I put the power feature in..
Makes sense to me. Is the adding power to Altmans in your thread?
No , just those pictures you quoted me on..I bought that kit from Midfifty but didn't wire it with the bells and whistles to eliminate some of the wiring..
Sorry Marv, I missed your post. I'm going with crank windows now but will switch to electric if the cranks give any problems, also going with the solid side glass too..
Before the hood was put on , this shows why I have to repaint the doors and running boards..This paint does look different shades depending on the light but I messed up on the this parts..
