Duallys Only
Old Apr 20, 2016 | 09:04 PM
  #1561
Lawrencew's Avatar
Lawrencew
I had a very hard time removing my rear caps
Old Apr 20, 2016 | 09:16 PM
  #1562
AzSuperDuty's Avatar
AzSuperDuty
I'm in the hard time to remove the rear caps crowd. But now that I am running the Cat-Eye system I can't put them on anyway.
Old Apr 24, 2016 | 04:08 PM
  #1563
BCooke's Avatar
BCooke
For my front and rear hub caps I have to use a common screw driver with a 1/2 inch tip or a small pry bar (with handle). Oh and a rag or it scratches the rim.
Old Apr 24, 2016 | 09:22 PM
  #1564
santafedave's Avatar
santafedave
I got a question for Dually owners. What product do you guys recommend when it comes to valve stem extenders? Amazon has the wheel masters 4 inch straight extenders but I looked at my valve stems a they look a little off angle. I see that they have the braided 7" stainless steel ones and I was wondering if anybody has used them on their rig. Thanks.
Old Apr 24, 2016 | 09:35 PM
  #1565
cyncwby's Avatar
cyncwby
If you look on ebay you'll find some 135 degree extenders, might be what you .... and I need. I've heard pro's and lots of con's on the long stainess braided ones ....leak, come loose......duuno.
Old Apr 24, 2016 | 09:39 PM
  #1566
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Many folks use the braided SS hose system.
I got mine from eTrailer.com
Make life easier.......
Old Apr 25, 2016 | 05:00 AM
  #1567
senix's Avatar
senix
I don't seem to have a problem using what is already on there. My air compressor has the right chuck to fill them up.
Old Apr 25, 2016 | 12:46 PM
  #1568
Joe/GA's Avatar
Joe/GA
I got external TPMS sensors and had to use the braided hoses for the inner duals. I used the 135 degree extenders to add the TPMS sensors on the other 4 stems. I drilled into the plastic hub covers to mount the hose and sensor. Before adding sensors, I was able to get to all 6 valve stems with this: Milton Window Inflator Air Gauge — Dual-Head Straight Chuck, 1/4in. Inlet, Model# S-516 | Air Chucks Gauges| Northern Tool + Equipment
Old Apr 25, 2016 | 03:17 PM
  #1569
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Joe,
Can you shoot a photo of your setup on the wheel ?
Thanks
Old Apr 25, 2016 | 06:02 PM
  #1570
Joe/GA's Avatar
Joe/GA
Originally Posted by ZooDad
Joe,
Thanks
Sure ZooDad. I recently took them off when I found that the batteries in the sensor were being used as long as there is air pressure on them. Each sensor is coded and has to go back on the correct tire so I made this board in a hurry, one day.
I found out that I don't have the SS braided hoses, I have the regular brand "X" hoses! Note a heavy coat of pollen and dust.
And, now I have to be embarrassed at how dirty my truck is!
This is the extension that I have for the rear outer:
I didn't have extensions for the fronts, but that proved to be a pain. I couldn't find the ones like I had on the rear, so I got these:
Bad case of brake dust, huh? Anyway, I hope this helps.
Old Apr 25, 2016 | 07:32 PM
  #1571
ZooDad's Avatar
ZooDad
Yep that does it thanks for posting the photos.
Old Apr 27, 2016 | 07:34 AM
  #1572
Lawrencew's Avatar
Lawrencew
Equipment is kinda ready to roll. Now for the planting equipment
Old Apr 27, 2016 | 12:47 PM
  #1573
cyncwby's Avatar
cyncwby
Lawrencew......that's a pretty good load, by the way, do you have air bags on your truck rear?
Old Apr 27, 2016 | 12:57 PM
  #1574
Lawrencew's Avatar
Lawrencew
No air bags , factory springs with 2.5" blocking under the leaf
Old Apr 27, 2016 | 10:11 PM
  #1575
AzSuperDuty
Cat Eye and wheel balance
Those of you using the Cat Eye or similar dual tire pressure balancing systems... have you experienced any tire/wheel balance issues?
I am getting a vibration over 75mph and I suspect it is my Cat Eyes... tho I have no idea how I will address the issue if it is in fact the Cat Eyes.
