1978-1979 Crew Cab build thread
The idea of the expedition rack was for that exact purpose. More storage over the cab plus room for additional lighting.
As tall as this truck was getting, I didn't want to risk a top heavy vehicle, thus raising my center of gravity, plus minimizing the overhead height for going to camping spots (tree branches are stronger than they look).
Enter the Pelican. Dust proof, weather proof, etc. Great for tools, guns, etc. The measurements are perfect in this case, as it fits in the expedition basket, does not protrude over the basket, and is easily secured.
Now I just need to buy one more of these to go on the other side, and all is well in the world...for now.
Hoping to mock up the mounting frame for the King Ranch buckets. Pictures to come. Do not mock my welding skills, I am aware they are minimal at best.
Once we got the seating situated, I will then be pulling the stock steering column still in the truck to mount the 1996 steering column so we can measure the length needed for the fab job to extend the steering shaft.
Found a guy locally who has a 1996 diesel dash, and its corresponding wiring, and other various diesel parts that I may or may not need. This dash, my hope anyway, will expedite the process of understanding all what plugs go to what
Been saving my pennies. Just sold the spare sterhling axle I had last night, time to go order my 1 ton, 4 inch lift springs.
I could only find three options:
1. skyjacker
2. atlas
3. Superlift
I have used both #1 and #3 historically, and never had an issue with either company's product. Having said that, I am more than likely going to go with Superlift due to the $ savings, seeing as neither company has let me down before.
Does anyone else have an opinion on these brands, or are there other brands I am missing?
Another to check out is rough country.
1. skyjacker
2. atlas
3. Superlift
Hope you got a hook up on those Pelican cases, them things are $$. Great idea, I would make a VERY secure very lockable hinged double strap for them things.Rack/spare tire mount/mod ideas maybe you can trim some of the rear support to get a little more bed space if needed.
I did think about the add a leaf type set up, but since Eleanor is going to be used as a daily driver- ish, definitely trying to stay away from the set up like that, as it does add considerable amount of noticeable stiffness.
Most of the lift spring kits are advertised as "smooth" or "soft ride", I can't expect too much out of this set up, but as long as my fillings will stay in place, life will be good.
Love that rack! Is that yours?
I like those ideas on the spare tire mounts... I will add that to my list of possible designs.
Truth be know, I wanted a rack like that with the spare tire mounted in the bed (a la Baja Style), but then I would have no room for my intended slide out "tool" storage box.
left side is for Jerry Can style carrying...but replace and modify for another spare tire holder...
And Still have access to my bed...
But that swing out set up off the bumper is a good one too. You could make is a swing out and then hinge down tire to the ground with a pull of another pin and a "timber" call.
And a swing out gas can X2 cool, if you can't pack it in in the bed, hang it off the sides.
Are you running a converted a/c compressor for air, or getting 12V HD underhood set up?
Tools are like bullets, you really can't have enough when you are in a jam.
IMO Rough Country is a waste of time and $. I am pulling the RC set off the front of blue truck and scrapping them.
Another idea for you.
Yea, we thought about doing another drop on the swing out to lower the tire, as they are not light. We also looked at collapsible crane style mount in the bed. Not sure yet, seen them on service trucks, would be handy. but we shall see. although yelling "timber" sounds more appealing to me.
looking at the 12V HD underhood set up, just will be dependent on the room I have left after I modify the air cleaner box.
I appreciate the feedback on the rough country stuff. I will be sure to keep that in mind before I pull the trigger on my springs.
I love those built in boxes. Dodge or not, cool stuff right there.
For my truck I was hoping to stand the tire vertically against the inside of the bed on the driver side, in front of the wheel well. Having a short bed and 35's the tire won't fit well here, so I'm looking at putting it behind the wheel well. I've thought about a mount that swings up & down so as to lay the tire flat in the bed when the bed is empty, but then swings up vertically & latches when the bed is being used. Not sure if I'll take the time to make this or not, but I like the idea.
I also really dig the idea of those in bed tool boxes on the dodges. That would be a LOT of work to make something like that.
On the same lines I have a pic somewhere of a utility bed that looks almost like a normal bed on a superdoodie. There are cabinets & panels, etc. in the bedside like a normal utility bed, but the bed itself isn't a big box like most utility beds. Kind of cool.
If you will stick with the vertical mount that swings off the bumper & holds the tire behind the tail gate be careful, depending on what you will do with the truck. I know a bunch of guys with broncos & even with 35's those racks tear themself off of the truck in the desert. 37's or 39's compound the problem. Most guys who run that type of rack on a desert rig have the cage running all the way to the back of the bronco & tie in an upper part of the mount through the body to the cage to keep the thing from shaking itself to death & cracking. If you won't be going fast much then the tire may not shake itself to death like we see in the desert.
