My first Ford pickup....
Old Oct 13, 2014 | 12:08 PM
  #256
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I haven't done my pivot bushings, but I have done the radius arm bushings twice.
Old Oct 13, 2014 | 01:08 PM
  #257
FordFETruck's Avatar
FordFETruck
When you do the pivot bushings. Just take the whole assembly out and do it. Don't do it under the truck on the floor like I did.
Old Oct 16, 2014 | 02:16 AM
  #258
Trackerrrr's Avatar
Trackerrrr
Did the left side bushings today, no pics. I managed to put a nasty gash in my pinkie when the pry bar slipped while I was aligning the pivot bushing hole with the frame. But it's all back together now and seems to 'sit' a bit better. My neighbor loaned me his Snap On electric impact gun which made things go faster. The right side outer tie rod end is pretty worn but not sloppy so I'll be working on those shortly.
I used the impact on the ball joint press kit to push the pivot bushing in pretty quick. Man, I do love me some power tools.
I took the entire I Beam, radius arm, and steering knuckle/rotor out as one unit again. Way easier than trying to get that damn bolt out that holds the spring in.
Old Oct 17, 2014 | 03:04 AM
  #259
Trackerrrr's Avatar
Trackerrrr
Did a quickie alignment on the toe in with a tape measure, wheels were toed out about 1/2". A bit of tweaking with the tie rod and now they are dead on straight. Also changed out the two power steering pump belts. Drove 16 miles to work tonight and she cruised down the highway at 65 mph with no problems. Could use a fourth gear though....
  #260
Trackerrrr's Avatar
Trackerrrr
And I burned up a 1/4 tank of gas round trip to work and back. Dang.
Old Oct 17, 2014 | 03:13 AM
  #261
FordFETruck
According to my fuel gauge I've used 3/4 tank in 110 miles. Although I'm not so sure I got the tank filled exactly as full as I did the time before last, as it came off F faster than usual. Also, my sender drops faster when you get to 1/2 tank and lower. Your sender might not be that accurate lol.
Old Oct 17, 2014 | 04:34 AM
  #262
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ford senders are notorious for being inaccurate.
That said, 4 1/2 gallons at 8 mpg = 36 miles.
What's the distance to work and back?
You're driving a dually with 4.10's and a C6, right?
I'm happy if I see double digits in my SRW truck with an OD 5 speed.
Old Oct 17, 2014 | 03:34 PM
  #263
Trackerrrr's Avatar
Trackerrrr
30 mile round trip. I don't know what rear gear I have yet. Haven't decoded the door tag.
Old Oct 17, 2014 | 03:39 PM
  #264
FordFETruck
What carb do you have?
Old Oct 17, 2014 | 04:13 PM
  #265
Trackerrrr's Avatar
Trackerrrr
The stock Motorcraft/Holley four barrel emission carb.
Old Oct 17, 2014 | 06:16 PM
  #266
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 4180 is jetted about as lean as you can get to have that truck run and drive without trouble.
Take a look at the tag on the pumpkin.
Often the first number of the ratio is obliterated by the bolt head. but it is easy to figure out.
Often Dually's will have a 3.53 gear for highway towing.
I'm not sure what they put in the Dana's.
More familiar with the '85 and on Sterlings.
Old Oct 18, 2014 | 02:12 AM
  #267
Trackerrrr's Avatar
Trackerrrr
I'm heading to California Saturday morning on at 400+ mile round trip with the truck to pick up some family heirlooms so this'll be the litmus test to see how good my repairs have been. I plan on taking some tools and my floor jack in case I have troubles. As good as the truck's been running I think it'll be uneventful.
Old Oct 18, 2014 | 02:39 AM
  #268
FordFETruck
Good luck! hope you don't have to stop at every gas station.
Old Oct 18, 2014 | 11:27 PM
  #269
Trackerrrr's Avatar
Trackerrrr
Talking
Made it back. According to the first half of the trip I got 8.04 mpg if my odometer's accurate. Had no problems at all with the truck. Filled both tanks in Henderson and made it to Phelen with 1/2 tank left in the rear tank. On the way back I filled both again and made it back to Henderson with 3/4 tank left in the rear tank.
The truck really likes to cruise at 55 mph too.
Old Oct 18, 2014 | 11:39 PM
  #270
FordFETruck
Pretty decent for a crew cab dually with a 460. If you ever look in to replacing the carb, look in to the Summit racing 600 CFM carb that I and a few other members on here have.
