CREWCAB ONLY
Old Dec 27, 2014 | 03:35 PM
  #361
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Fastback460
I did see that, but I was under the impression that they would have a billet grille that already had the factory surround trim already attached in one piece.
I just wanted to see if they had something that didn't require cutting up my original grille.....but I guess there is no way around it.
And there is why you don't see many
Old Dec 27, 2014 | 08:26 PM
  #362
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
LMC Truck sells one you don't need to cut up your grille to install, I bought one for my 93 Bronco.
Jim
Old Dec 28, 2014 | 07:44 AM
  #363
Diesel_Brad
Jim
Apparently you missed the part of the conversation where it was stated he wanted to keep an outer surround around the billet grill
Old Dec 28, 2014 | 04:01 PM
  #364
Insane 1's Avatar
Insane 1
Yes, you will have to cut an original shell, and it is a total PITA to do.
Old Jan 1, 2015 | 01:26 AM
  #365
MARC96's Avatar
MARC96
I have a question for you guys. does anybody know here to find the weather stripping for the rear door windows, the strip that goes on the inside and out against the glass. I have looked at lmc, npd, blue oval parts, jc whitney, and many others with no luck. the inner one's are not bad but the outer one's are very weather cracked as you mite expect from a 91. my truck is 91 f350 cclb, drw. I've lurked here for a long time, it amazes me with the shear volume of information that is shared here. thank you in advance.
MARC
Old Jan 1, 2015 | 08:04 AM
  #366
Diesel_Brad
MARC
I bought mine thru ford
Old Jan 1, 2015 | 11:49 AM
  #367
MARC96's Avatar
MARC96
I've gotten so used to going with aftermarket or pick n pull because of cost I forgot that some stuff is dealer only. thanks. HAPPY NEW YEAR . MARC
Old Jan 9, 2015 | 02:30 PM
  #368
RustyTub's Avatar
RustyTub
Bought this a week and ahalf ago,
1990 F350 CC DRW
460 with Banks Power Pack
It is a project but will be being used the whole time it is being fixed up
Old Jan 9, 2015 | 02:32 PM
  #369
Nighteyez's Avatar
Nighteyez
Lookin' good! Is it black or dark blue?
Jim
Old Jan 9, 2015 | 02:38 PM
  #370
RustyTub's Avatar
RustyTub
Jim
Its Black The paint needs some serious Buffing, but this was also taken after 900 miles of traveling and some not nice weather.
Old Jan 13, 2015 | 06:46 PM
  #371
ottoparts's Avatar
ottoparts
Here's some older pictures of mine. I have a matching raised roof canopy in it now. I also acquired some factory Alcoa's that are going to go on it when both the Toyo's wear out and I rebuild the suspension.
Old Jan 13, 2015 | 06:56 PM
  #372
ottoparts's Avatar
ottoparts
Here's a current one as of two weeks ago when we bought my youngest son a bug. His older brothers both have Ford trucks (79 F150 2wd and 73 F250 4x4).
Old Jan 13, 2015 | 07:11 PM
  #373
RustyTub's Avatar
RustyTub
Nice CC and not to bad of a beetle, If you have any need for peices for the Bug let me know I am over here in Bend and have a stock pile of VW Parts and pieces.
Old Jan 15, 2015 | 12:30 PM
  #374
OkieFromMuskogee's Avatar
OkieFromMuskogee
We have similar trucks Mine isn't quite as nice however.
1988 F-350, 4x4, 460 EFI
Old Jan 16, 2015 | 02:39 PM
  #375
ottoparts's Avatar
ottoparts
Pretty damn close.
Same fogged over headlamps, same tinted windows, single style step on the front doors only, and no fancy tailgate cover. But to be fair, mine has one and I took it off. And the white to boot!!!
What color is your interior?
Mine is light brown (sand, camel, IDK).
