CREWCAB ONLY
Old Nov 16, 2014 | 08:33 PM
  #316
97ccsb's Avatar
97ccsb
Old Nov 16, 2014 | 10:40 PM
  #317
Pappawheely's Avatar
Pappawheely
Originally Posted by LeoJr
Pappawheely-
Nice truck!
You changed to heim joint steering though the connection points appear about stock. Is this an upgrade over the ball joints or is there another reason?
Revised the whole steering system. Saginaw pump, ram assist, remote cooler and fabricated linkage.
Old Nov 20, 2014 | 05:50 AM
  #318
maxherb's Avatar
maxherb
here is my old girl
[/URL]
Old Nov 21, 2014 | 09:44 AM
  #319
LeoJr's Avatar
LeoJr
Looks great!
Does your tire rod roll up and down?
Old Nov 21, 2014 | 11:46 AM
  #320
Pappawheely
Looks great!
If you notice in the photo, I have rubber bushings on both sides of the heim to keep it parallel.
Old Nov 21, 2014 | 02:46 PM
  #321
F350-CC-LB-DRW-4X4's Avatar
F350-CC-LB-DRW-4X4
Crew dually 4X4
Old Nov 21, 2014 | 02:53 PM
  #322
F350-CC-LB-DRW-4X4
Crewcab dually 4x4
Anybody know where I can find some POINTED lug nut covers???? And some little nuts to go under them for my dually? I'm 1-1/16" nut, 9?16 thread..
Old Nov 21, 2014 | 03:44 PM
  #323
Diesel_Brad's Avatar
Diesel_Brad
Are you sure they are 1-1/16"? they SHOULD be 7/8"(I guess conversion company did not use era correct lug nuts) Who and how did the conversion get done?
Could not find any 1-1/16 spike covers but did find these 1 1/16" Nut Covers | Iowa80.com
Sorry, no luck on 7/8" spike either but here are 7/8" domed 7 8" Ford Stainless Steel Lug Nut Covers Set of 20 Lugnut Brand New | eBay
Old Nov 21, 2014 | 04:32 PM
  #324
Trombogon's Avatar
Trombogon
Originally Posted by Bob Gervais
What's with the trailer?
That whole picture just screams "redneck ingenuity" to me.
Old Nov 21, 2014 | 05:40 PM
  #325
F350-CC-LB-DRW-4X4
Thanks diesel_brad, Iowa80 has a TON of lug covers..i'll try and find one that'll work.
Truck was originally cab and chassis. I'm pretty sure ford made 4x4 drw in chassis cab only back then didn't they?.. if not i suppose it would have been Centurion, western hauler, or Quigley. It had a service bed until 2003, i bought it in 2005 second owner. I put the Alcoa's on it.
Old Nov 21, 2014 | 06:16 PM
  #326
Diesel_Brad
Crewcab pickups have a 168" wheel base with 3" wide leaf springs.
The closest wheel base for a cab-n-chassis is 161" and only have 2.25" wide leaf springs
So that tells me it was originally a pickup. And someone made it into a utility truck. Same person may have made it a dually. Does it have a true dually rear axle? How about the front? Ford hubs(that go on with the wheel bearings) or aftermarket bolt ons
Old Nov 21, 2014 | 07:40 PM
  #327
F350-CC-LB-DRW-4X4
4x4 dually investigation
Dana front axle
Front dually extension?
went out to investigate.... it does have 3" wide leafs just like you said. Also, behind the front wheels there is a sort of extension, but i'm not sure if that's normal for duallys? Seems like it was always 4x4, so i'm starting to think it came SRW. Thinking back, there used to be those weird handles bolted on the side, has power sliding rear glass, probably was a Centurion conv.
Old Nov 22, 2014 | 07:31 AM
  #328
Diesel_Brad
[IMG]
Yup looks like it was a Single wheel truck. That last pic shows a nut holding on an adapter. The OEM ford ones were all one piece. You will most likely find a 3" spacer that bolt on in the rear to make the rear axle wider too.
if you measure your fuel door I will tell you if the dually bed is OEM of aftermarket. Yeah I see the plugs for the grab rails and I see the brush guard is removed too. All the tell take signs of a centurion conversion. There "should" be a sticker in the door jam saying that too.
Factory front ford dually hub. Top of pic. you can see where the bolts would come thru from the backside to hold the rotor on with no nuts. and 2" spacers at bottom of pic I used between my duals
Old Nov 22, 2014 | 10:15 AM
  #329
F350-CC-LB-DRW-4X4
Wow, yes! The truck did have an aluminum brush guard.
The fuel doors on mine are 6-1/4" × 6-3/4".
Currently only stickers in jam are the nameplate, one in red writing about ambulances, and one about 4x4 roll-over and handling characteristics.
Old Nov 22, 2014 | 11:09 AM
  #330
Pappawheely
Brad, Where did you get the spacers? I am thinking of widening my rear track.
