CREWCAB ONLY
Old Nov 22, 2014 | 02:08 PM
  #331
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by F350-CC-LB-DRW-4X4
Wow, yes! The truck did have an aluminum brush guard.
The fuel doors on mine are 6-1/4" × 6-3/4".
Currently only stickers in jam are the nameplate, one in red writing about ambulances, and one about 4x4 roll-over and handling characteristics.
Then that is a factory dually bed out on your truck. Another way to tell for certain is the fenders. Is there an flat flip to screw wheel well trim to or is there no lip?
Originally Posted by Pappawheely
Brad, Where did you get the spacers? I am thinking of widening my rear track.
ARROWCRAFT. All billet steel and hub centric. $220
Wheelspacer.com sell the EXACT spacer for $370
I am running the 2" ones in the rear of both my truck to even out the track
Old Nov 22, 2014 | 02:41 PM
  #332
Pappawheely's Avatar
Pappawheely
Thanks. I am putting a uhaul box on mine and would like a little more width. I have a dually axle too but don't know which one is wider hub face to hub face. I thought I read where the dually axle is narrower. I want to stick with SRW. I know I would have to change the spring pads, the axle is from a C&C.
Old Nov 22, 2014 | 04:58 PM
  #333
Diesel_Brad
Dually PICKUP axle is 6" wider than the SRW. and a cab-n-chassis axle is...... IIRC 3" wider than SRW BUT the perches are 4" narrower due to the narrower frame on the cab-n-chassis. If you have a Dually Pickup axle, there would be no doubt that is how I would go about it
Old Nov 22, 2014 | 07:12 PM
  #334
Pappawheely
I only have the C&C axle. Spacers seem like a better choice.
Old Nov 22, 2014 | 07:55 PM
  #335
Diesel_Brad
How much do you have to lengthen the frame to put the Uhaul body on, 2 feet?
Old Nov 22, 2014 | 08:18 PM
  #336
Pappawheely
Yes, The box floor is 10 feet. I will build a section that extends the frame and holds the rear winch. The subframe that will attach the box to the chassis will go the full length of the frame & help tie the new section in.
Old Nov 22, 2014 | 09:13 PM
  #337
Fastback460's Avatar
Fastback460
That is a really nice truck, I'm thinking about using the same colors when I repaint mine.
Old Nov 22, 2014 | 09:42 PM
  #338
LeoJr's Avatar
LeoJr
If you notice in the photo, I have rubber bushings on both sides of the heim to keep it parallel.
Ah, I think I do, are they tapered?
Does that mean you did have a roll issue that you resolved or an issue you knew beforehand and addressed it during your installation?
I am thinking of going to a heim front end and am looking at a different layout that puts the drag link from the pitman arm connecting to the top of the drag link or the knuckle end.
Thanks for responding!
Old Nov 23, 2014 | 06:12 AM
  #339
Diesel_Brad
So you think you are just going to lengthen the BACK of the frame? Not cut and section in a 2' piece?
Old Nov 23, 2014 | 09:42 AM
  #340
Pappawheely
Yes, That's the plan.
Old Nov 23, 2014 | 09:58 AM
  #341
Diesel_Brad
That is going to be A Lot of weight hanging off the tail
Old Nov 23, 2014 | 10:36 AM
  #342
Pappawheely
No, not really. All the heavy items like the water tank, (actually that's about it) are mounted between the axles. When I haul a motorcycle it will be inside sitting right over the rear axle. The back of the box will be empty and the rear extension will be tied into the length of the frame. The box is made of FRP and aluminum and it's only 24 inches. I don't plan on towing anything with much tongue weight.
Old Nov 23, 2014 | 11:31 AM
  #343
tomahawk869's Avatar
tomahawk869
nice vintage trucks
Old Dec 22, 2014 | 02:43 AM
  #344
Insane 1's Avatar
Insane 1
My 96.. I built it in 05 it's not a Centurion.
Here is how it is most of the time with a car behind it....
Old Dec 22, 2014 | 07:28 AM
  #345
Fastback460
I usually don't like lowered trucks, but that is cool.
And I like that grill, did you make that yourself? If not, where did you get it?
