CREWCAB ONLY
Old Jul 1, 2014 | 01:11 PM
  #226
Truck Guy99's Avatar
Truck Guy99
ptut42, do you have a build thread on the truck or the cummins swap? Looks sweet
Old Jul 1, 2014 | 01:18 PM
  #227
ptut42's Avatar
ptut42
sure dont just pop in here every now and again when i need help or ill troll a little and give my advice sometimes really like what eveyone is doing with this forum and the help you can acquire from some of the really smart guys on here
Old Jul 1, 2014 | 01:26 PM
  #228
Oscello's Avatar
Oscello
My Crew Cab and the Crew Cab Dana 60 donor shortly before a trip to the scrap yard.
Old Jul 1, 2014 | 03:41 PM
  #229
Crewcabber's Avatar
Crewcabber
Please tell me you saved the rear door panels out of that cab before it went to the scrap yard.
Old Jul 1, 2014 | 06:52 PM
  #230
Diesel_Brad's Avatar
Diesel_Brad
Do you need some? I have 3 sets
Old Jul 1, 2014 | 09:18 PM
  #231
Crewcabber's Avatar
Crewcabber
I want a pair of rear grey power window panels. Plus as hard as it is to find good rear door panels, to see a pair go to the scrapper kills me.
Old Jul 2, 2014 | 10:02 AM
  #232
Oscello's Avatar
Oscello
Yes they went to the scrap yard. It was a bare bones work truck (plow truck) so it had manual windows, non-tilt column, tons of rust, etc....... I had a ad on here and craigslist but no one wanted any of what was left.
Old Jul 2, 2014 | 11:44 AM
  #233
gentrykm's Avatar
gentrykm
1997 F350 460ci, 6" Skyjacker lift, 37x12.5x16.5
Need a set of front door panels grey, pair of power side mirrors, and also lock actuators and window motors/regulators for rear doors.
Old Jul 2, 2014 | 06:45 PM
  #234
00Boss's Avatar
00Boss
Gentrykm thats a great lookin truck. You have the tires Ill be using once I have a truck again.
Old Jul 8, 2014 | 08:40 AM
  #235
liftnw8z's Avatar
liftnw8z
Thought I would pop in and check this thread out
I will be joining the crew cab club in a couple weeks when I pick up my "new to me" 96 F350 XLT CC 4x4 with a 7.3L. Has 266k on the clock and is pretty clean for the year. No pic on my phone or I would post one lol.
Old Jul 16, 2014 | 12:13 PM
  #236
liftnw8z's Avatar
liftnw8z
Originally Posted by Diesel_Brad
-Dana 60 added w PMF 2.25" RSK, V code SD springs, and factory front sway bar
-Rear dually axle added, SD B code rear springs, AirLift air bags and factory rear sway bar
Curious question, Brad. Did you use a different block for the "B" code rear springs, and how much overall lift did this give, approximately?
I'm considering the same RSK and V/X code springs up front for my CCLB as it's a 7.3L PSD.
Old Jul 16, 2014 | 04:50 PM
  #237
Diesel_Brad
Yes, I used 5" Ready Lift block kit for a SuperDuty. I HIGHLY recommend U or D codes instead of V codes for a better ride.
X codes are the Heaviest spring available. They are snow plow prep springs and the standard f450/F550 springs . Also ride like CRAP.
Also, remember a SuperDuty crewacb diesel weighs about 8600lbs.
And OBS crewcab diesel weighs about 7400lbs.
So there is NO need for as heavy as a spring
Old Jul 16, 2014 | 05:11 PM
  #238
liftnw8z's Avatar
liftnw8z
Thanks for the info. I hadn't considered the difference in weights of the two trucks but my mind automatically went to assuming the OBS diesel would be heavier than a newer similar truck.
Old Jul 16, 2014 | 05:27 PM
  #239
Diesel_Brad
No. Those SDs are STUPID heavy
Old Jul 16, 2014 | 09:52 PM
  #240
Crewcabber's Avatar
Crewcabber
Found this sitting outside the movie theater in Redlands the only night I didn't drive my crew. Nice truck flush mount tool box 5th wheel plate. Rsk with neg. Arch springs pretty clean truck.
