Building a 2012 EXcursion
Old Dec 27, 2013 | 09:25 PM
  #61
sammie0126's Avatar
sammie0126
Guess I should have read the 1st post in more detail, I get it now the 6.7 is going onto what was the EX frame/body. So what happens to the V10?
Old Dec 27, 2013 | 09:26 PM
  #62
pdombrowicki's Avatar
pdombrowicki
Getting rid of it.
Old Dec 28, 2013 | 07:30 AM
  #63
fordboy67's Avatar
fordboy67
that's a ton of progress in just a few days! How many guys working on it?
Old Dec 28, 2013 | 07:34 AM
  #64
pdombrowicki
I has been just me.
Old Dec 28, 2013 | 08:12 AM
  #65
Snowseeker's Avatar
Snowseeker
Exciting stuff!
Old Dec 28, 2013 | 09:25 AM
  #66
enormiss's Avatar
enormiss
Originally Posted by pdombrowicki
Frames are totally different on a super duty compared to and EX.
Is that dependant on years or is it the whole line of SD / excursion?
Old Dec 28, 2013 | 09:44 AM
  #67
Snowseeker's Avatar
Snowseeker
Thats all years. the excursion frame is ONLY an excursion frame in all years.
Old Dec 28, 2013 | 10:49 AM
  #68
Stewart_H's Avatar
Stewart_H
What Snow man said: https://www.ford-trucks.com/forums/5...ml#post4003621
Stewart
Old Dec 28, 2013 | 04:40 PM
  #69
Apocalypse's Avatar
Apocalypse
Getting rid of it.
To bad you're so far away, I would scoop that up if I could get help with the install
Old Dec 28, 2013 | 05:36 PM
  #70
wrxin's Avatar
wrxin
Body and frame need to be cut and spliced. Frames are totally different on a super duty compared to and EX.
Thanks for taking the time to reply to all us curious folks.
So you use the rear portion of the Excursion frame from where you chopped it and then the front part of the truck frame?
You use the Excursion roof and body, the truck front end (hood and fenders).
What about doors? Are all four the truck doors? Are all four the Ex doors? I saw the comment about the Ex doors being different.
The donor Ex had pretty dented up doors.
Thanks for all the updates! This project shows what Ford should have kept in production!
Old Dec 28, 2013 | 06:16 PM
  #71
pdombrowicki
Yes on the frame we weld both frames together and than channel the inside.
We use the Ex rear body and the truck body from the middle of the front seat forward Fire wall and all.
We will use the 12 front doors and the rear doors from the Ex. The rear doors are different between the Ex and CC. Ex doors are curved at the top and a little bit wider then a CC which is straight up and down.
Excursion Doors
Pickup Doors
Old Dec 28, 2013 | 07:06 PM
  #72
cameeks's Avatar
cameeks
Question on the frame. If you are making an ex with a front end of a 12 super duty why would you need to splice the front part of the frame on? Is it for upgrading the suspension?
Old Dec 28, 2013 | 07:07 PM
  #73
pdombrowicki
It is for the upgrade suspension and the frames are made way different in the front. They swoop down lot farther.
Old Dec 28, 2013 | 07:14 PM
  #74
cameeks's Avatar
cameeks
Ok I knew they were different but only thought it was the rear.
Old Dec 28, 2013 | 07:47 PM
  #75
Apocalypse's Avatar
Apocalypse
I can't believe how different the doors are, there is practically no way to use the CC doors on the rear and it look right. Your work looks top notch my friend
