The Excursion frame is different from 250/350 Laid to rest.
FWIW, I have taken the dimensional drawings Available from Ford Fleet of the 2004 Excursion and the 250/350, and stripped out the frame outlines.
The Drawings are available in my gallery for you to peruse. I changed the format from pdf to jpg and then modded the drawings.
Also in the gallery are isometric drawings available from Genuine Ford Parts.
Please peruse the drawings, and examine them side to side. You will see that it is as Monsta and I thought, the Excursion is basically the same as a 250/350 up to the drivers feet, and then it changes quite a bit going back.
Add to that th edifference in metal thickness, the web height, and crossmember differences, This is a different critter.
I think maybe this will end some confusion.
OK, just for the 'ell of it, I figgered out a way to get some better images on here.
Excursion Frame:
F250/350 Frame:
I think this makes for a better comparison. This should help.
By the way, the F250/350 drawing was of the 137 inch wheelbase, same as the Excursion.
Excursion Frame:
F250/350 Frame:
Here are the original drawings. You can print them out for yourselves to compare.
Excursion:
http://www.fleet.ford.com/truckbbas/non-html/2002/108.pdf
F250/350:
http://www.fleet.ford.com/truckbbas/non-html/2002/164.pdf
The two drawings are NOT to exact scale. The f250/350 drawing in the post above is slightly larger.
Excursion:
F250/350:
Here is some more stuff:
F250/350 detailed frame drawing:
https://www.fleet.ford.com/truckbbas...bb_pdf/132.pdf
Artists cutaways of the Excursion:
The isometric drawings from Ford parts:
Excursion:
F250/350:
Excursion:
F250/350:
Im pretty sure all 250's or 350's do not carry the same bends. Is the truck frame a regular cab Super Cab or a Crew Cab? That will make a differance and of course if its an Excursion. The floorboards will be longer as the truck gets longer. Hence the longer streight portion in the Excursion frame.
The F25/350 frame above is of the standard cab 137" wheelbase pickup. for comparison, I have the F250/350 Crew Cabe frame stripped out below.
The frame or the excursion is based on the Superduty frames, but it is not the exact frame of the 250/350 that many have claimed. It is designed differently in the back half as nessesary for a different body style and a different mission.
Excursion Frame top view:
Super Duty Frame top view:
I accept that there are some differences between the Excursion frame and the different Super Duty truck frames. What I am seeing here is that the differences are due to floor plan differences. I think that you are saying that this is the case, and that you are not saying that the Excursion frame is not as robust as the Super Duty truck frame. Is this correct? Or are you saying that the Excursion frame is not as robust?
