Building a 2012 EXcursion
Old Jan 9, 2014 | 05:30 PM
  #166
pdombrowicki's Avatar
pdombrowicki
Originally Posted by wrxin
Thanks, that's really cool. I guess the axle isn't dead center on the spring? If it was, the axle would be 4 inches off (roughly) if the new spring is 8 inches longer. Or the math isn't that simple and once the shackles are taken into account and the other geometry, it works out ok.
The old springs are not centered on the axle. They are 8" of compared to the new ones.
Old Jan 10, 2014 | 07:36 AM
  #167
Snowseeker's Avatar
Snowseeker
Awesome!
Is the new axle still a sterling 10.5"? Are the brakes much different between the older X axle and newer axle?
Old Jan 10, 2014 | 11:27 AM
  #168
Forest's Avatar
Forest
Paul,
I really enjoy watching your work. I'm particularly impressed at how quickly you are going at this project. It would take me forever (plus, I can't weld)!
As I understand this, as far as structure, suspension, and chassis hardware, you are only retaining:
1) Back 2/3 of Excursion frame.
2) Excursion fuel tank.
3) Excursion hitch.
4) Back 2/3 of Excursion body sheet metal, including all of roof from w/s pillars, center pillars, and rear doors.
From the 2012, you are using everything except back 2/3 of frame, the bed, and the cab from w/s pillars back. I am assuming you are keeping 2012 front doors(?).
The 2012 gives this "2012 Excursion" the full F-250 front suspension, wider axles with appropriate gear ratios, the F-250 rear suspension with longer rear springs, and all of the engine/transmission/cowl/dashboard with all control electronics. Keeping virtually all of the F-250 is one of the biggest advantages and truly makes this what Ford should have sold in 2012 for an Excursion.
Excellent work!
Old Jan 11, 2014 | 10:21 AM
  #169
pdombrowicki
Spring perches moved forward and all tided up. Gas tank and Shield back in. Start messing with the Euro tank.
Old Jan 11, 2014 | 10:28 AM
  #170
Technologiq's Avatar
Technologiq
What bumpstops are those?
Old Jan 11, 2014 | 11:08 AM
  #171
Splash67's Avatar
Splash67
pdombrowicki
Dude it looks awesome so far!
I envy you MAD SKILLS!!
  #172
pdombrowicki
They are off the 2012 F250.
Old Jan 11, 2014 | 11:23 AM
  #173
jayjjcc's Avatar
jayjjcc
I really appreciate the pictures... this summer I'm hoping to remove the body and sand/sandblast the entire frame and have it repainted. It's still nice since it's a BC truck but 2 Quebec winters have already taken their toll on the frame.
Old Jan 11, 2014 | 10:45 PM
  #174
wrxin's Avatar
wrxin
The spring perches that you relocated. That doesn't look "that hard"? No welding? I would love to put some newer springs in the rear. I've seen a relocation kit but it was around $300. What you did looks pretty straight forward. Am I missing anything or was it not too bad to do?
Old Jan 11, 2014 | 10:49 PM
  #175
wrxin's Avatar
wrxin
Ooo one other thing. Will those springs provide any lift?
Old Jan 11, 2014 | 11:07 PM
  #176
pdombrowicki
Right how as it sits with out body is about 2" higher in the rear.
Spring conversion is pretty straight forward. Burn off old rivets with torch, air hammer out the rest of the rivet. Weld up mild hole on front most set of holes. Use front set of holes to relocate. Get 1 1/4 inch 1/2 inch grade 8 bolts and nuts. Bolt everything tight, cut off part of bolts that stick past end of nuts and weld the nuts to the bolt so they can't ever come lose.
Old Jan 11, 2014 | 11:14 PM
  #177
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I like your method of doing this much better than the $300 conversion brackets
still not sure how I'd like having those soft 08+ leafs out back
Old Jan 11, 2014 | 11:34 PM
  #178
wrxin's Avatar
wrxin
Are they a softer spring? Lower payload capacity?
Old Jan 12, 2014 | 06:17 AM
  #179
fordboy2's Avatar
fordboy2
Should not be a soft spring. They are longer which is what provides the better ride.
Old Jan 12, 2014 | 09:12 AM
  #180
fsmt's Avatar
fsmt
Awesome!
I know it is work but it must be great to be involved in building custom creations such as this... Keep up the good work and thanks for taking the time to update us... Your work inspires the rest of us.
BTW... I see you have both fuel tanks in the frame... Are dual tanks in the works?
