Emergency ford excursion x code swap
Old Sep 9, 2013 | 03:23 PM
  #121
2002exPSD's Avatar
2002exPSD
There are blocks in the rear.
Old Sep 9, 2013 | 03:25 PM
  #122
rockcrawler_101's Avatar
rockcrawler_101
Longer won't help. You need a drop pitman arm and a drop bracket for the pan hard bar. You have a 5 inch lift now
Old Sep 9, 2013 | 03:26 PM
  #123
rockcrawler_101
How big are the blocks. They all have blocks on the back
Old Sep 9, 2013 | 03:30 PM
  #124
wrxin's Avatar
wrxin
Beat me to it!
Old Sep 9, 2013 | 03:34 PM
  #125
LivingLarge's Avatar
LivingLarge
Guess you never know unless you are the original owner... Are you replacing with original mount? Or now that you have all the parts are you staying with your super lift? Thanks, wrxin for the pics. Reps sent.
Old Sep 9, 2013 | 03:35 PM
  #126
2002exPSD's Avatar
2002exPSD
What is a pan hard bar?? Ill measure the blocks when I go to pickup the truck. My guy said it sits almost level. Maybe 1-2 inches higher in the front.
Old Sep 9, 2013 | 03:37 PM
  #127
wrxin's Avatar
wrxin
pan hard bar = track bar. Same same.
Old Sep 9, 2013 | 03:39 PM
  #128
2002exPSD's Avatar
2002exPSD
I'm gonna leave the front brackets and probably get the extended rears now that I've basically built a custom lift. Always wanted to fit 35's or 37's.
Old Sep 9, 2013 | 03:40 PM
  #129
wrxin's Avatar
wrxin
The level thing doesn't make any sense to me. Your car looks level in the picture of what the car looked like when you bought it before you started all. Now you supposedly have a 5-6" lift (given all the issues with the track bar and pitman arm and shocks) and you're saying its only 1-2" higher in the front?
Do you have before and after measurements of the height?
Old Sep 9, 2013 | 03:42 PM
  #130
2002exPSD's Avatar
2002exPSD
Bought a fabtech adjustable trac bar (pan hard bar)
  #131
wrxin's Avatar
wrxin
LivingLarge, thanks for saying thanks about the pics.
I would sort have expected a thanks from the OP but oh well.
Old Sep 9, 2013 | 03:46 PM
  #132
2002exPSD's Avatar
2002exPSD
Nope. It was level when I bought it 6 years ago. It was squatting when I decided to do x codes. My bump stops were all chewed up.
  #133
wrxin's Avatar
wrxin
What rockcrawler is trying to say is that longer bars (pitman and track) are not the only thing you need. You need to keep the track bar and pitman arm aligned (see my pics) or you will have terrible bump steer. You've raised the car up enough that the two bars will no longer be lined up and simply making them longer won't bring them back into alignment.
You might actually longer bars than your old stock one but shorter than the ones you just purchased once you get the proper drop brackets.
Old Sep 9, 2013 | 03:48 PM
  #134
2002exPSD's Avatar
2002exPSD
Thumbs up
Sorry about that. Thanks for the pictures.
Old Sep 9, 2013 | 03:51 PM
  #135
LivingLarge
Actually, he's probably only 2-3 inches higher than when started. That would be the gain of the X code... Total now with leveling kit and x codes probably in the 5 inch range.
