Emergency ford excursion x code swap
Old Sep 9, 2013 | 01:35 PM
  #106
wrxin's Avatar
wrxin
I just measured my front stock shackles (whatever the brackets are called at the rear of the front springs). They are 5" center of bolt hole to center of bolt hole.
I forgot the front end of the front springs just bolts to the frame, duh! So ignore my earlier question.
I have 1" of space between the springs and bump stops. That's with original stock springs under full weight of the car.
I have some pics I'll post shortly. Perhaps some pics of the stock front suspension will help.
Old Sep 9, 2013 | 01:36 PM
  #107
2002exPSD's Avatar
2002exPSD
Looks like ill need these bilsteins 33-104652 28 inch fully extended 17 inch compressed. Does that sound about right?
Old Sep 9, 2013 | 01:37 PM
  #108
rockcrawler_101's Avatar
rockcrawler_101
If you get a drop pitman arm you will also have to get a drop bracket for the track bar other wise you will get massive bump steer. The steering and track bar should be at the same angle. Your bump stops are not the stock ones or at least different then the ones i have. mine are much larger. What is the measurement from the bottom of the frame to the area where the bump stop hits? Nothing looks out of place from the pictures
Old Sep 9, 2013 | 01:39 PM
  #109
2002exPSD's Avatar
2002exPSD
Mine isn't bolted to the frame it bolts to a big bracket.
Old Sep 9, 2013 | 01:48 PM
  #110
rockcrawler_101
yeah all them have brakets in the front and you can buy a kit to raise the front suspension. here is a kit to give you an idea of what it is Ford Leveling Suspension Lift Kit
Old Sep 9, 2013 | 01:53 PM
  #111
2002exPSD's Avatar
2002exPSD
The bottom of my leaf spring towards the front where the front shackle is is level with the bottom bumper valance if that means anything.
Old Sep 9, 2013 | 02:05 PM
  #112
2002exPSD's Avatar
2002exPSD
The front shackles are 6 3/4 inches. That's from the bottom of the frame to the bolt hole. Is that stock?
Old Sep 9, 2013 | 02:41 PM
  #113
wrxin's Avatar
wrxin
My bad description of how they bolt in... pics in a few.
Old Sep 9, 2013 | 02:50 PM
  #114
2002exPSD's Avatar
2002exPSD
Here's the picture of the front drop down brackets.
Old Sep 9, 2013 | 02:51 PM
  #115
wrxin's Avatar
wrxin
As promised, just some boring pics of my stock front suspension. Might help with how to align things like the pitman arm and track bar.
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/iGj1FoziDwoYOnPDG70bB2B6GfB6QFKe-pzhPKdg5gg?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-OqI7cMrD6PE/Ui4kO7OMupI/AAAAAAAAvx4/isiasHT4wZU/s800/image%2520%25281%2529.jpg" height="800" width="600" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/mandvcoleman/ExcursionFrontSprings?authuser=0&feat=embedwebsite ">Excursion front springs</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/up55EeBynelpzVWpELBwm2B6GfB6QFKe-pzhPKdg5gg?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-NOOBxdnJ-98/Ui4kNUTnAPI/AAAAAAAAvx0/4-nZ9nIDpyQ/s800/image.jpg" height="800" width="600" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/mandvcoleman/ExcursionFrontSprings?authuser=0&feat=embedwebsite ">Excursion front springs</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/Kfl1ibrNxKHxYl8RWKl4NWB6GfB6QFKe-pzhPKdg5gg?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-OlYepmK06VI/Ui4kQmVFV0I/AAAAAAAAvyE/H073HK3n4XQ/s800/image%2520%25282%2529.jpg" height="800" width="600" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/mandvcoleman/ExcursionFrontSprings?authuser=0&feat=embedwebsite ">Excursion front springs</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/ciK0yCWynfIsw_eApYhsIWB6GfB6QFKe-pzhPKdg5gg?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-T0eZ0tW7BSk/Ui4kSObVF_I/AAAAAAAAvyI/EuV9Cguuws8/s800/image%2520%25283%2529.jpg" height="600" width="800" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/mandvcoleman/ExcursionFrontSprings?authuser=0&feat=embedwebsite ">Excursion front springs</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/MDuNZj4I3XP17k2WdhmH-GB6GfB6QFKe-pzhPKdg5gg?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-ZRl43HXCumY/Ui4mN7wqDWI/AAAAAAAAvyc/m8fsr29jt_Q/s800/image%2520-%25205.jpg" height="600" width="800" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/mandvcoleman/ExcursionFrontSprings?authuser=0&feat=embedwebsite ">Excursion front springs</a></td></tr></table>
Old Sep 9, 2013 | 02:53 PM
  #116
wrxin's Avatar
wrxin
That does not look anything like mine. Remember way earlier in this thread when I questioned your tire size combined with your "stock" suspension. To my untrained eye, a PO added a kit to the front to raise it up to fit the tires. That could be your whole issue.
Old Sep 9, 2013 | 03:03 PM
  #117
2002exPSD's Avatar
2002exPSD
Hmmmm. So I geuss she put a leveling kit on it. This is what it looked like when I bought it.
Old Sep 9, 2013 | 03:10 PM
  #118
rockcrawler_101
Yeah that is the leveling kit I was talking about
Old Sep 9, 2013 | 03:12 PM
  #119
wrxin's Avatar
wrxin
Holy crap that is higher than stock! Even the back looks higher.
If you had posted that picture first, we'd all know what was going on.
The PO obviously raised up the car to accommodate the larger tires. That makes sense to me because when you said it had 35" tires and stock suspension I was suspicious...
You're going to want to investigate how the rear was raised too. Are there blocks or something?
In the mean time, you're need some stock front brackets for your springs I think if you want to have the "normal" lift from x-code springs or just keep going with the pitman arm stuff, the new shocks, and the adjustable track bar.
Old Sep 9, 2013 | 03:22 PM
  #120
2002exPSD's Avatar
2002exPSD
Truck is all back together. Drove it. Was really bouncy cause its missing shocks in the front. Pitman arm needs to be a tad longer. Won't turn all the way to the right. Steering rod hits the passenger leaf spring.
