Emergency ford excursion x code swap
Old Sep 9, 2013 | 03:54 PM
  #136
2002exPSD's Avatar
2002exPSD
So bump steer is??
Old Sep 9, 2013 | 03:56 PM
  #137
LivingLarge's Avatar
LivingLarge
Originally Posted by 2002exPSD
I'm gonna leave the front brackets and probably get the extended rears now that I've basically built a custom lift. Always wanted to fit 35's or 37's.
Do yourself a favor, measure from center of hub to bottom of fender. Compare that to a stock ex, that will give you your exact gains.
Just FYI, before you start your next thread... I have a 5in lift and had to trim a little off my wheel well cause my 35's rubbed a bit. 325/60/20
Old Sep 9, 2013 | 04:04 PM
  #138
2002exPSD's Avatar
2002exPSD
Already trimmed my wheel wheels when I had the 305/60/18's
Old Sep 9, 2013 | 04:09 PM
  #139
LivingLarge
Lol, yeah but now you have a bunch of us curios... So, please measure it
Old Sep 9, 2013 | 04:13 PM
  #140
2002exPSD's Avatar
2002exPSD
As soon as my guy is done changing the condenser, FOT, and accumulator ill go pick it up and give y'all some measurements.
Old Sep 9, 2013 | 04:17 PM
  #141
rockcrawler_101's Avatar
rockcrawler_101
Bump steer is where you hit a bump and the car turns like you turned the wheel even when you keep the wheel strait.
Old Sep 9, 2013 | 04:19 PM
  #142
wrxin's Avatar
wrxin
So bump steer is??
This gets into complicated steering geometry but basically if one of your front wheels hits a bump and things under the car are not aligned correctly, the bump causes an unintended "steering action" where the wheel will steer the car without any steering input from you. It makes the car unstable and a handful to keep under control.
Old Sep 9, 2013 | 04:26 PM
  #143
2002exPSD's Avatar
2002exPSD
So I need a drop bracket for the trac bar and the pitman arm. I've never heard of a drop bracket for the pitman arm. I have heard of a drop pitman arm.
Old Sep 9, 2013 | 04:45 PM
  #144
rockcrawler_101
Drop bracket for the trac bar and a new drop pitman arm
Old Sep 9, 2013 | 04:52 PM
  #145
2002exPSD's Avatar
2002exPSD
Only drop pitman arm I could find was a 4-8 inch drop. I'm guessing that will work. As for drop trac bar brackets, any particular company?
Old Sep 9, 2013 | 05:06 PM
  #146
Stewart_H's Avatar
Stewart_H
This is what it looked like when I bought it.
What the heck! Why didn't you tell us it had already been lifted? That explains so freaking much!
Originally Posted by wrxin
Holy crap that is higher than stock!
Stock? That Ex looks to be sitting higher than one that has had the X code mod done to it.
No friggen wonder he's been having problems.
Stewart
Old Sep 9, 2013 | 05:11 PM
  #147
wrxin's Avatar
wrxin
Stewart
Tell me about it!
Old Sep 9, 2013 | 05:22 PM
  #148
rockcrawler_101
The fabtech lift I had on my super duty was nice because it had multiple options for the 5.5 lift and 8. What ever option you go I would get both pitman arm and drop bracket from the same company for the same lift.
Old Sep 9, 2013 | 05:29 PM
  #149
Stewart_H's Avatar
Stewart_H
There are four reasons I can think of right now as to why you're having problems:
1. Ford drastically changed the specs of the spring part number you ordered, because you did indeed order an X code.
2. Your invoice shows the correct part number, but the spring is the incorrect part.
3. Something is out of whack with your front end.
4. Your mechanic is doing something wrong.
5. You aren't starting with a stock 4x4 suspension, and are modding one that's already been modded.
I just thought I'd add number 5 to the list....
Stewart
Old Sep 9, 2013 | 05:30 PM
  #150
2002exPSD's Avatar
2002exPSD
I didn't know it had a lift. The woman I bought if from told me the mods she did. A lift wasn't one of them. Unless it was dealer installed when she bought it new? I have all the paperwork and receipts since the day she bought it. There wasn't a receipt for a lift.
