Emergency ford excursion x code swap
Old Sep 9, 2013 | 11:01 AM
  #91
2002exPSD's Avatar
2002exPSD
Old Sep 9, 2013 | 11:03 AM
  #92
2002exPSD's Avatar
2002exPSD
Old Sep 9, 2013 | 11:13 AM
  #93
2002exPSD's Avatar
2002exPSD
Ok pictures are up. Adjustable trac bar came in as soon as I got to the shop. That will work. The pitman arm is way too short, steering arm hits the leaf spring at full right turn. Gotta order a drop pitman arm. F250 shocks are way way too short. 1/2 inch longer than excursion shocks. Shocks need to be 27 inches long. Excursion shocks are 24 inches f250 are 24 1/2 inches. Distance from hole to hole on the trac bar is 31 inches.
Old Sep 9, 2013 | 11:32 AM
  #94
2002exPSD's Avatar
2002exPSD
Is the f250 pitman arm longer than the excursion?
Old Sep 9, 2013 | 12:11 PM
  #95
LivingLarge's Avatar
LivingLarge
Has he loosened the eye bolts and re torqued with full weight of truck?
Please measure total length of shackles.
Old Sep 9, 2013 | 12:13 PM
  #96
wrxin's Avatar
wrxin
I'd be curious about both shackle and hanger length.
Old Sep 9, 2013 | 12:17 PM
  #97
wrxin's Avatar
wrxin
Also, I know its not the issue at hand, but the steering stabilizers look a bit out of whack to me. One looks fully extended and the other fully pushed in while the steering is straight. Yes I know it won't help with ride height but since the car is in the air...
Old Sep 9, 2013 | 12:28 PM
  #98
2002exPSD's Avatar
2002exPSD
Those pictures were of the steering turned all the way to the right. So makes sense one would be longer than the other.
Old Sep 9, 2013 | 12:31 PM
  #99
LivingLarge
I agree, can someone with a stock 4x4 chime in with the measurements of there STOCK front spring shackle both front and rear of forward spring.
I would myself, but my new to me EX has too many changes, so I may not be stock.
Old Sep 9, 2013 | 12:36 PM
  #100
2002exPSD's Avatar
2002exPSD
He told me he did that the first time. We did it again when I got there. Still no change.
Old Sep 9, 2013 | 12:44 PM
  #101
wrxin's Avatar
wrxin
Cool! I couldn't tell from the pics. The steering looked fairly straight.
I will take some pics and measurements of my totally stock front hangers and shackles within the hour.
Old Sep 9, 2013 | 12:52 PM
  #102
2002exPSD's Avatar
2002exPSD
Ok so I need 27 inch shocks from hole to hole. Looking for 5100 bilsteins unless someone thinks something is better. Had rancho 9000's that were terrible. Wore out in 10,000 miles. Can't seem to find any specs on shock length just what it's made for like 4-6" lift hight shocks.
Old Sep 9, 2013 | 01:13 PM
  #103
2002exPSD's Avatar
2002exPSD
Just looked up bilsteins specs and found that shocks for my truck with a 4-6 inch lift only gives me 26 inches fully extended and I need 27 inches max. So I'm guessing I have 6 1/2 - 7 inch lift on the front
Old Sep 9, 2013 | 01:24 PM
  #104
LivingLarge
2002exPSD, Go measure your shackles in the meantime.
Old Sep 9, 2013 | 01:34 PM
  #105
2002exPSD's Avatar
2002exPSD
Back home now. Shop is an hour away
