Emergency ford excursion x code swap
Old Sep 7, 2013 | 02:37 AM
  #76
2002exPSD's Avatar
2002exPSD
Originally Posted by rockcrawler_101
im wondering if the previous owner had put on the suspension drop brackets you can get where it drops the leaf mount points down.
Nope. Even if she did put drop brackets then the ones I took out should be longer than the ones I just purchased to do the Xcode swap. I like new everything when I do something.
Old Sep 7, 2013 | 02:54 AM
  #77
Stewart_H's Avatar
Stewart_H
You have got to please take a BUNCH of pictures of your front end, from different angles. And please make sure you aren't so close that we can't discern possible angle problems with a part when it's viewed in relation to other front end items items.
Did you happen to take pictures of the new springs side by side with the old springs? Do you still have the old springs?
Stewart
Old Sep 7, 2013 | 11:07 AM
  #78
2002exPSD's Avatar
2002exPSD
Going to the shop Monday morning. He's closed today and Sunday. Will get lots of pictures Monday morning. The Ranger is down right now so I have to use one of the cars off the car lot.
Old Sep 7, 2013 | 10:15 PM
  #79
MalwareDRay's Avatar
MalwareDRay
subscribed...
Old Sep 7, 2013 | 10:25 PM
  #80
2002exPSD's Avatar
2002exPSD
Stewart
Sorry did not take pictures of the springs side by side. Didnt think of doing it. Yes I still have the old springs.
Old Sep 8, 2013 | 07:16 AM
  #81
enormiss's Avatar
enormiss
Originally Posted by LivingLarge
I have to ask, did he loosen the eye bolts again on the leafs with the ex on the ground and re-torque.
Be sure to follow up and make sure mechanic left spring bolts loose until axle was supporting load of vehicle.
Old Sep 8, 2013 | 09:39 AM
  #82
2002exPSD's Avatar
2002exPSD
What is that going to do?the whole axle is moved to one side by about 5 inches from the trac bar pulling it over.
Old Sep 8, 2013 | 09:52 AM
  #83
LivingLarge's Avatar
LivingLarge
Think it may be to late for this since your axles have shifted...
If he torqued everything with vehicle up in the air, this would create a resistance and not allow for vehicle weight to line everything up. Front eye on springs tq to 203lbs rear eye to 185lbs. These values would carry the weight of the truck. That would be a possible explanation of why you thought the springs gave you more of a lift than expected.
That is all I'm saying...
Old Sep 8, 2013 | 09:56 AM
  #84
2002exPSD's Avatar
2002exPSD
Ahh. I see what your Saying. Didnt even think of that. Will try that first thing in the morning
Old Sep 8, 2013 | 10:05 PM
  #85
Stewart_H's Avatar
Stewart_H
Even if he said he did it with the weight of the Ex on the springs, MAKE him loosen the bolts and re-torque with all four wheels on the ground.
Stewart
Old Sep 8, 2013 | 10:24 PM
  #86
2002exPSD's Avatar
2002exPSD
Going in the am will have pictures and mearsurements.
Old Sep 8, 2013 | 10:55 PM
  #87
Restlesswildman's Avatar
Restlesswildman
I have never seen a shackle bent like that!!
  #88
Stewart_H's Avatar
Stewart_H
Take your old shackles with you.
Stewart
Old Sep 8, 2013 | 11:03 PM
  #89
2002exPSD's Avatar
2002exPSD
Old shackles are bent too. Twisted leaf springs from the accident. That's why I bought new shackles.
Old Sep 8, 2013 | 11:26 PM
  #90
Stewart_H's Avatar
Stewart_H
Crap, that's right. I forgot.
Stewart
