Yeah, the first time I truly laid into Black with that Extreme tune, it was a little scary! Not something you want loaded in during the winter, I'm thinking it wouldn't be a good idea on ice and snow!
Not gonna lie, I laid on it a few times on the way home... rolling burnout on dry pavement from like 25 MPH. I also had fun shooting smoke at the Prius next to me.
Got home, turned it back. Not worth blowing something up.
My street tune (that I'm on now) is from DP. Good tune, no smoke, about 100 extra horse. Good tow tune, keeps the EGT's down, no hard shifting, etc. Still has a nice little kick when I need it, though.
Vinyl wrapped front bumper? Whats this about?
I have used flat black plastidip paint on my grill/rims and it holds up fine.
Just an alternative to paint... Much cheaper, and will hold up to rocks on the highway well too. Also can be removed (if you ever wanted to for any reason).
I'm looking for glossy to match the paint - easy with vinyl. Tough with plasti-dip.
The plastics will be getting satin black (instead of the gray factory plastic look)
Not much to say here, besides I finally got it installed. Hit it with a coat of flat black so the brass wouldn't stand out like a sore thumb - left the ***** red because hey, it looks nice and there's already some red under the hood.
As per most people's recommendations, I'll be changing the filter at 500 or so miles, then after another 1000. Can't wait to see what is inside.
3 of 4 connected and working. Fuel pressure sensor is dangerously close to the upper radiator hose. I need to make it a remote sender with a little length of hose and some fittings. Nice to be keeping a closer, constant eye on things. Trans temp just needs to be installed physically and it's done.
Thanks! Maybe not as clean looking as the kits, but functional (maybe even more with heavier lines and fittings), and cheap. I'm not building a show truck here, it's a daily driver.
