Well, fuse blew again. Called Service Tech...he basically said he needed to look at it to see what is going on. I'm not certain myself...which is exactly why I asked him to wire it up (he charged me for it and I happily paid for it). He didn't run the compressor more than once to make certain it worked. I can't say I blame him as I'd likely do the same thing. However, now I'm stuck with fixing it. I don't have time to keep running up there. I moved the compressor to Upfitter #4 and so far so good. I shut the truck down several times, cycled the compressor to the point that it needs to cool down. I'll report back in a couple of hours, but it appears that wiring it to #4 is the way to go. Not saying that he should have foreseen this, but I know I should not have had to rewire this compressor. It's just one of those things that a lot of people would bitch about. I just want it fixed and move the heck on with my life.
I'm sure you're frustrated to a degree.
Not sure if you've got these or not but they may help:
I just checked it again and it is really strange...
#4 is still working fine. I will likely go grab another fuse from the Ford garage (they only sell 20 and 30amp fuses in town) and see if that one blows with nothing hooked up.
