Man down...
Old Jul 10, 2012 | 04:35 PM
  #106
SavageNFS's Avatar
SavageNFS
Originally Posted by railrode1
Did they check the harness where i mentioned in a earlier post?
I don't know. I mentioned my suspicions of ground issues, chaffed wires or bad connectors and they have said they have exhausted those options.
Old Jul 10, 2012 | 04:37 PM
  #107
rob92761's Avatar
rob92761
Not this has to do with SavageNFS problem.
I had a 2000 7.3 that the engine would shut down and restart going down the road (reason for re start it was a manual transmission). This went on for years and would only happen once every three to four months took it to the dealer to get fix. They could not produce the same problem and would never throw a code so they could not fix it. Finally one day truck shut down started back up and the battery light came on. The alternator was change about one year prior to this so I take alternator off and had tested at the parts house. Turned out the alternator was good. So frustrated took truck back to dealer told them to fix it. Mechanic calls me and say alternator was bad. I told him that I had it tested at parts house, but if you say it bad change it. Mechanic calls me back says changed alternator still not working. After about an hour he calls me back again says the fuseable link fired and puts old alternator back on. Go to pickup truck and the mechanic says did you get the recall yet on your truck. I said no. He says that a recall came out two days ago to replace the cam senor (which he did). Ever since that date truck never shut down while going down the road.
So basically for years I had a bad or faulty cam senor the would not throw a code.
  #108
SavageNFS's Avatar
SavageNFS
Originally Posted by Hdslider
Man that stinks. Is your hometown dealer your selling dealer?
No...the selling dealer is a private used truck center. The home town dealer is a large Ford dealership that I happen to be furnishing the steel for an addition of the service department in the upcoming weeks.
Old Jul 10, 2012 | 04:49 PM
  #109
Tomahawk's Avatar
Tomahawk
That really stinks. I feel for you, we had to postpone our vacation in 2010 from June to August because my dealership didn't have an allocation for my truck so I had to wait 14 weeks for it to be built. If they don't get it fixed by Friday I would tow it to another dealership.
Hang in there, it'll get fixed.
Old Jul 12, 2012 | 05:01 PM
  #110
2006lariat's Avatar
2006lariat
Any New's? Or is Savage camping with the scouts already?
Old Jul 12, 2012 | 09:25 PM
  #111
my_crib_too's Avatar
my_crib_too
Originally Posted by SavageNFS
definitely TOO SOON
Sorry, Good luck with your truck...
Old Jul 13, 2012 | 08:24 AM
  #112
jdadamsjr's Avatar
jdadamsjr
Savage - how many miles you got on your truck and how long you had it ?
(and how many days has it been in the shop total the first year?)
I would try to 'encourage' them to give you a comparable loaner for your vacation !
good luck !
Old Jul 13, 2012 | 08:40 AM
  #113
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
good luck !
I agree....
To me it's just good customer service.
Old Jul 13, 2012 | 10:12 AM
  #114
Marauder92V's Avatar
Marauder92V
Ford may be behind the delay as well. My truck's AC started throwing warm air. I knew they had issues with the evaporators from this forum. I told them it was a bad evaporator but they told me Ford wanted it refilled with a dyed refrigerant (that process took 3 days). Took it home on the afternoon of day 3. Next morning, guess who had a nice colored dye stain on their garage floor?
Called and they told me to bring it in that afternoon. I got the truck back 7 business days later (+1 weekend). The explanation was that part had to be removed, Ford wanted to inspect it before Ford would approve the ordering of a replacement part -- the evaporator!
My truck was down for 10 days, when I knew exactly what was wrong and I suspect they did as well once they saw where the dye came from.
Good luck Savage!
Old Jul 13, 2012 | 05:40 PM
  #115
kper05's Avatar
kper05
But they'll replace a PCM like an air filter.
I can't imagine an evaporator is more.
Old Jul 14, 2012 | 10:08 PM
  #116
SavageNFS's Avatar
SavageNFS
I was camping and we had a great time! I received a txt from my wife on Friday morning that my truck was done and that we could pick it up when I got home from camping. I was very relieved. Long story short...PCM failed because the alternator was faulty due to what they thought was a negative draw from the main wiring harness. They put NEW PCM, Alternator and main wiring harness to the on board computers. Still had a negative draw...this was sending a command to the PCM for the alternator to charge at maximum capacity (which the original alternator was more than the system could handle and fried the OCM causing the catastrophic failure).
Service Tech at that point was very frustrated. He never told me if he was frustrated with Ford or not, but I know he took it upon himself to start at the fuse box under the hood and started testing every circuit. He found a negative draw through the fuse box, but not an individual circuit (which is VERY strange and difficult for me to understand, but I have seen some unexplainable things in electronics). He ordered a completely new fuse box and replaced it. Truck instantly ran perfect and alternator performed as it should.
I picked it up today and put 150 miles on it already. We just got home to be honest. Beat the snot out of it too. Ford covered everything except the alternator. I didn't argue it. The alternator was covered under my extended warranty from United Car Care. I paid the deductible of $250 (a one time lifetime deductible for all future purchases) and they covered it. Dealer took care of all of the payment BS. I was very happy obviously.
Thanks to Brad and Scott at VandenBrook Ford for taking care of my truck. I appreciate it very much. I also appreciate the kind words and support in this thread. I really needed the support as I really missed my truck. Trip to South Dakota to go wheeling t-minus 6 days. I pumped again!!!
Old Jul 14, 2012 | 10:13 PM
  #117
Tom's Avatar
Tom
First of all I'm really glad to hear that you got your truck fixed.
Secondly, WTH??? YOU had to pay your deductible because something wasn't covered by Ford? That's wrong on so many levels, because none of this is your fault. It sounds like the dealer replaced the alternator without approval from Ford, and because you had an extended warranty they had an easy way to get paid rather than having to eat the cost of the repair. That just ain't right; this whole fiasco should have been covered under warranty. And because FoMoCo can't blame this on someone else I'm pretty confident that the dealer is to blame here.
Old Jul 14, 2012 | 10:14 PM
  #118
DevotedDad's Avatar
DevotedDad
Right on, Savage ... a great outcome! This, too, is a good one for the ole knowledge base.
DD
Old Jul 14, 2012 | 10:18 PM
  #119
SavageNFS's Avatar
SavageNFS
While I suspect you might be correct, I'd rather focus on the positive that my truck is in my garage and not in theirs. I was worried about our trip and don't want to sweat deductible. I was over the B2B by 2000 miles with 38,400 on the odometer. Thanks though...you are likely spot on. I'll take one for the team. If I have anything else go wrong in the next 61,600 miles it will be free as I paid the deductible already
Old Jul 14, 2012 | 10:29 PM
  #120
powerstroke72's Avatar
powerstroke72
Fantastic news Savage!! I'm super glad they got it fixed. Also, thank you for giving props to the staff at the dealership. Most of the time we only hear the bad so it's refreshing to hear about a good servicing dealer and one of our members here recognizing it.
