boss9f100 Projects page
Old Mar 19, 2018 | 10:11 PM
  #406
Boss9F100's Avatar
Boss9F100
I made a bunch of changes to it and kinda changed direction. Instead of this being a garage queen with little use I plan on driving it a LOT!
I built the headers of course then fabbed up a 304 Stainless exhaust system for it. 1st one but gotta learn some time . .
Also quite visible is the Gear Vendors OverDrive unit. THat should really help at cruising speeds to help tame the 482" FE
Old Mar 19, 2018 | 10:13 PM
  #407
Boss9F100's Avatar
Boss9F100
This short video will show the system a bit better. Really getting excited to fire up this engine for first time.
https://www.youtube.com/watch?v=npZDMwMClTc
https://www.youtube.com/watch?v=Lqc0nkIMYik
Old Mar 19, 2018 | 10:15 PM
  #408
Boss9F100's Avatar
Boss9F100
Also switching over to a Dual Quad EFI system
Old Mar 19, 2018 | 10:19 PM
  #409
Boss9F100's Avatar
Boss9F100
Because of wheel fitment issues I pulled the dropped beams, installed the stock ones so I could install my dream wheel which were custom made. Because I could only get wheels with bolt pattern smaller than the stock 5 x 5.5 I opted for better brakes too. These busy AZ freeways are not kind to not being able to stop.
Old Mar 19, 2018 | 10:22 PM
  #410
Boss9F100's Avatar
Boss9F100
I went with 14" 6 Piston power brakes on all 4 corners. Bolt pattern was switched to 5 x 4.5 so I could use the wheel I wanted.
Note the new rotor inside a stock wheel. Not much room for the caliper!
I had the 73-79 Disc brakes up front but they too were simply too wide (2" per side) for proper wheel fitment
Old Mar 19, 2018 | 10:33 PM
  #411
Boss9F100's Avatar
Boss9F100
The 540" Twin Turbo Boss9 build:
Have pretty much what's needed to finish including the heavy wall stainless to build the Turbo Manifolds/Headers
Awaiting final machine work on block and balancing. Should be done hopefully this week.
Few component pics
Old Mar 19, 2018 | 10:46 PM
  #412
Boss9F100's Avatar
Boss9F100
The 1966 F100 Ranger has become my daily driver
Old Mar 20, 2018 | 07:23 AM
  #413
cjcocn's Avatar
cjcocn
Beautiful work as usual.
Old Mar 20, 2018 | 10:03 AM
  #414
Roger Carter's Avatar
Roger Carter
Couldn't help but notice the odd placement of the vacuum advance can. I assume that you are using crank triggered / coil on plug ignition and the vacuum advance can is for vacuum variable cam timing?
On a serious note...Really like those tall pent roof Mercury valve covers, as well as everything else in the pictures. Congratulations on your daughters wedding. Three weeks is over 500 hours. Plenty of time.
Old Mar 20, 2018 | 10:09 AM
  #415
KO1960's Avatar
KO1960
Awesome work, as usual. I don’t believe that I have ever seen dual tbi’s on an engine. Is it difficult to get them to work together? Please keep the pics coming. Thanks.
Old Mar 20, 2018 | 10:49 AM
  #416
Boss9F100's Avatar
Boss9F100
thanks!
Wish old age had not kicked in so I could actually get something done...
Old Mar 20, 2018 | 10:54 AM
  #417
Boss9F100's Avatar
Boss9F100
the vacuum advance is there to keep projected oil pressure on target. It will be run by the pcm thru the primary side vacuum circuit of the secondary throttle body.
In reality there is only 50 minutes per day avail for 23 more days. Less week days. So it’s simply not happening. It will need to be the ‘66 no paint ranger or gasp: the ‘56 Chevy as it’s only thing close to done.
Old Mar 20, 2018 | 11:01 AM
  #418
Boss9F100's Avatar
Boss9F100
the Dual Quad EFI system is way over my pay grade but gotta be easier than the 540 boss Engine will be!
All the goodies are inside of primary unit.
Plan is to run a 1000 HP mechanical pump that will feed a reservoir with a hidden high pressure pump inside. So fuel to mechanical pump then in line to EFI pump then line to TB’s. Return line back to reservoir then a return line back to tank from reservoir.
Most difficult part will Be fuel system. Rest is plug n play. Turn key, start engine after inputting base stuff like cu in, desired idle etc.
Old Mar 20, 2018 | 11:09 AM
  #419
Boss9F100's Avatar
Boss9F100
I know it’s a Chevy but it’s been over 20 yrs restoring this car. So, unless I can round up some volunteer it looks like this will be drive away veh.
related because a slick in background. Lol
Old Mar 20, 2018 | 04:26 PM
  #420
Roger Carter
Always thinking outside the box (or Slick, in this case). That is why I enjoy all your posts, even the ones with a Chevy in the picture. Keep those updates coming.
