boss9f100 Projects page
Aug 15, 2015 | 02:32 PM
The much shrunk '11 dash
Seat lowering
Inspiration for the 65-66 F Series trucks.
This was '66 my dad bought new october 10th 1965. Many many moons ago!
Aug 15, 2015 | 02:34 PM
Fired it back in March. 1st startup
Aug 15, 2015 | 02:38 PM
Aug 15, 2015 | 02:40 PM
Modified the stock "11 core support to frame mounts. A bunch shorter now in order to make it all fit.
Aug 15, 2015 | 02:42 PM
Home built complete CAC/Intercooler system.
Started off with a blank core and a pile of pipes
Aug 15, 2015 | 02:43 PM
Steering turned out being much simpler than I thought.
Using all stock '11 pieces I was able to make a adapter and find proper spot in firewall.
Cut a hole and weld and bolt it in place . .
Aug 15, 2015 | 05:24 PM
Glad to hear your health has improved and you are back working on the EcoSlick.
Aug 15, 2015 | 11:02 PM
Love seeing the progress you're making on this truck. Very cool work you got going. Glad to hear that your health is holding up as well.
Aug 16, 2015 | 10:56 AM
Other than a "bad case of awesome"... What the heck is wrong with you!
I've been following this from the start, and this is freakin unreal man.
Fantastic job.
Aug 16, 2015 | 11:04 AM
Aug 16, 2015 | 03:25 PM
Thanks All!
Its been a touch one but finally making progress.
Another reason the core support has to be in exact location is so I could use the '11-14 remote hood latch.
Turns out I just needed to make a loop to fit the latch and it aligns perfectly.
I will of course have to make a cover of sorts so it cannot be tampered with.
Video so not sure if it will imbed or not.
Aug 16, 2015 | 03:27 PM
Aug 16, 2015 | 03:31 PM
I was hoping to use the inner structure from the '11 but angles area all wrong. mostly because I dropped the cab so much over the chassis.
Test fit on front clip. in pic the I/C is in stock '11 position. That is why I ended up starting from scratch just building one.
Also note the computer is in stock '11 location in cowl area. Another chore to get it to fit yet have the HVAC fit too.
Aug 17, 2015 | 12:58 PM
Quote:
Originally Posted by
Boss9F100
Nice air-flow in that configuration!
Aug 17, 2015 | 01:52 PM
You're going to have to give us all a ride in it when it's finished
