boss9f100 Projects page
Old Jan 18, 2016 | 10:37 PM
  #331
Boss9F100's Avatar
Boss9F100
Old Jan 19, 2016 | 12:42 AM
  #332
dank4120's Avatar
dank4120
Amazing work there, nice to see your project moving forward again!
Old Jan 19, 2016 | 06:03 AM
  #333
jthorngate3's Avatar
jthorngate3
I could definitely see becoming overwhelmed during a project of this magnitude, but you're doing some incredible work. I hope your health is holding up as well!
Old Jan 19, 2016 | 08:14 PM
  #334
KO1960's Avatar
KO1960
You make the process look easy which is a testament to your skills and problem solving. I really enjoy your posts, because I can somewhat see into your thought process. Thanks.
Old Feb 17, 2016 | 09:36 PM
  #335
Boss9F100's Avatar
Boss9F100
Thanks All! Still a work in progress.
It showed up here today:
A Labor of Love ? Building a 1966 Ford F-100 EcoBoost - Ford-Trucks.com
Recently made it here too:
http://speedsociety.com/1966-ecoboos...ve-cool-build/
More Update soon.
Old Feb 25, 2016 | 03:11 PM
  #336
Boss9F100's Avatar
Boss9F100
Ecoboost Engine Swap 2
I have started another EcoBoost Engine Swap.
This one will be 180 deg from the other
Very simple task now after wiring issues have been ironed out.
Keep stock body no mods needed
Keep frame stock no mods needed
Keep twin I beam suspension no mods needed
Keep stock steering no mods needed
Pick up a eco engine and transmission, You will be able to buy a harness for your truck very soon. Taylored to fit your Truck!
Remove front clip. Drop in Eco and transmission 4x4 or 4x2.
Plug in harness, add just a different gauge cluster,
Keep your headlight switch, ignition etc. Sock dash with exception of a Standard cap type center cluster. Plug n play.
Should work on all 65-72 trucks.
Double the power, double the MPG.
I am not selling this combo but heads up it will be avail soon.
Old Feb 25, 2016 | 03:30 PM
  #337
cjcocn's Avatar
cjcocn
I have to start saving up!
Old Feb 25, 2016 | 09:08 PM
  #338
UNTAMND's Avatar
UNTAMND
We are waiting....
Stilllllllll waiting!!!!
I'm very interested in this new project. Let's hear more please.
Old Feb 26, 2016 | 12:25 AM
  #339
Boss9F100's Avatar
Boss9F100
Originally Posted by UNTAMND
We are waiting....
EcoBoost Engine Swap 2
Well, I kept checking my SkyHook and today gave SkyHook number 1 a good tug and next thing I knew a 2015 F150 3.5L with Twin Turbo's fell out of the sky soon followed by a :
6R80 6-Speed Automatic along with a Transfer Case, A bit of wiring and and Computer.
In case y'all have not guessed its going into my 1966 F250 Deluxe Camper Special Ranger.
A HUGE difference in the builds will be.
1) Stock Body no mods
2) Stock Frame no mods
3) Keeping the Twin I-Beam Suspension
4) Since the F250 comes with a HD Brake System it will also be kept as they are factory Power Brakes
5) The Entire Factory Bucket Seat Interior Will Be kept stock with exception of dash Cluster. Still trying to come up with a design but want it to look very stock.
6) The Special Order Paint Color will be kept
7) Exterior will be restored to Original (eventually, get it running for now)
8) Stock Front Sheet Metal Including Core Support & Inner Fenders
9) Whoa, just gave too much information
10) This will be my parts hauler and daily driver
11) Stock front suspension for now but will be turned into a 4x4 as time allows and I get caught up on other projects
12) And the BIGGIE is:
"A Ford Supported Project through Drivers Talk Radio"
Starting off with a 2015 3.5L Eco, 6R80 from a 4x4
Its going into my 1966 Deluxe Camper Special Ranger
352 was pulled
The Ranger engine was taken down to long block, gaskets, seals replaced and dropped into the '66 F100
Front clip removed as the Eco/6R80/Tcase very long.
Old Feb 26, 2016 | 12:30 AM
  #340
Boss9F100's Avatar
Boss9F100
Simply amazing rust free truck to start with.
Engine/Trans/TC came in at 768 lbs. Includes all accessories.
A bit dirty so a few squirts of Magic Soap and a rinse.
pre-checking inner sheet metal fit.
Fits like it belongs there!
Old Feb 26, 2016 | 12:34 AM
  #341
Boss9F100's Avatar
Boss9F100
Initial test fit a total no go . .
I knew ahead of time cross members 2 & 3 would need to be removed. THey were unbolted and moved out of the way.
Another try and it plopped right in like it belonged there!
My question from the start was will the left turbo clear the steering gear box. Looked like it would be close by eyeball.
Right turbo? No problem, the factory indent was in perfect spot!
Old Feb 26, 2016 | 12:36 AM
  #342
Boss9F100's Avatar
Boss9F100
For proper clearance on drivers side turbo to steering box I will only have to rotate a clamp slightly. Fits fine touches clamp.
Once I knew it would fit blew apart the other sheet metal. Took around 2.5 hours total to remove front clip, cab and box. maybe not that long.
Old Feb 26, 2016 | 12:40 AM
  #343
Boss9F100's Avatar
Boss9F100
The 2015 Eco was upgraded to a gear driven vacuum pump, clears that too. Makes the swap much easier as factory 2015 will pretty much plug in to stock '66 Booster!
I removed cab and box so I could show better photo's of what I am up to.
A few here to show final resting spot. Trans cross member will be here tomorrow.
Old Feb 26, 2016 | 12:42 AM
  #344
Boss9F100's Avatar
Boss9F100
I will need to sell this truck to proceed if anyone is in market . .
Old Feb 26, 2016 | 10:01 AM
  #345
UNTAMND's Avatar
UNTAMND
Awesome job buddy. Awesome job.
I wish I could come spend some time with you and help out, get some inspiration, and learn some new things.
