Rusty
Old Apr 23, 2012 | 06:12 PM
  #331
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by Gary Lewis
What do YOU think? . Would you give up maybe some acceleration for 2 MPG? For a something like a 15% increase? And better drivability? I would!
That's a pretty big improvement in MPG, for such a simple swap. I know what I would go with......
Old Apr 23, 2012 | 07:26 PM
  #332
Gary Lewis's Avatar
Gary Lewis
Yes, that's a big improvement. Second tank came in at 14.4 at the same pump. Average for the trip of 250 miles: 14.25.
Old Apr 23, 2012 | 07:37 PM
  #333
bruno2's Avatar
bruno2
Rusty's motor which ever it may be when sold could very well come back around to you before too long. If I remember correct you are going to put Dad's motor in Rusty and vice versa. If Dad's motor has never been overhauled then it should have a stock bore. If it has then I am sure it would have to have .030 taken out of the cylinders to get it back to right. If it has already been bored then it probably isnt more than .030 over now. What I am saying is that you could possibly even use the .060 pistons in another build.
Old Apr 23, 2012 | 07:41 PM
  #334
truckertrav's Avatar
truckertrav
Gary,I've been following your progress on Rusty and Dad's truck. I am working on my 85 f150 XLT lariat 4WD. It has a 1406 Edlebrock 600 and I just put kit in it. It gets around 13 to 15 mpg depending on the heavy foot.
I am a fan of the E-brocks. Good Luck and keep the cards and letters going. Thanks again for all the Input. travis
Old Apr 23, 2012 | 10:44 PM
  #335
Gary Lewis's Avatar
Gary Lewis
If the readers haven't figured out heretofore what the disposition of Rusty might be I think you might have just tipped your hand.
That is a good idea you are suggesting. A way to have my cake and eat it as well. I like that. But, it might also involve the small-block C6 that I have in the attic. And, maybe even parts of the 351W that's up there as well. Good thinking!
Travis - Thanks for the note. The Carterbrock carbs are one of my favorites as they can be made to do just about anything. However, and unfortunately, both the expertise as well as the parts to make that happen are hard to come by.
Old Apr 24, 2012 | 10:53 AM
  #336
Gary Lewis's Avatar
Gary Lewis
#5 Plug
Just pulled the #5 plug (easiest to reach) to see what it looked like after the trip. Obviously need to pull the others to see what each cylinder looks like, but this is a good start. And, for the record these aren't the Champion extended tip plugs, but the standard Autolite ones.
I'm going to change oil (Conoco Super All Season Synthetic Blend 10W30) and filter (Motorcraft FL1-A) today so's I can see how much oil he's burning. Looks like he used 1/4 pint yesterday in 250 miles. IOW, the level went from about the 3/4 mark between Safe and Full to the 1/4 mark.
Actually, that begs a question: What is the range, in pints, between Safe and Full?
Old Apr 24, 2012 | 11:01 AM
  #337
ctubutis's Avatar
ctubutis
Who measures oil in pints?
To my knowledge, quarts have been used since the invention of the internal-combustion engine but I guess you must predate that era.
I believe the area covered by the hash marks (the "SAFE" area on the dipstick) represents one quart. I won't get into U.S. vs. Imperial measurements.....
Old Apr 24, 2012 | 11:05 AM
  #338
Gary Lewis's Avatar
Gary Lewis
I don't like that answer as it means Rusty used a pint in 250 miles. But, it is who-knows-how-used oil of unknown quality and viscosity. So, the hope is that it'll be much better with new oil.
And, that suggests pulling the other plugs to see if I can find the culprit. Still questions to be answered........
Old Apr 24, 2012 | 12:39 PM
  #339
Rogue_Wulff
Burned, or leaked? That's the question that needs answered.....
Old Apr 24, 2012 | 01:31 PM
  #340
Fordzilla80's Avatar
Fordzilla80
This.
Hopefully leaked.
Old Apr 24, 2012 | 05:20 PM
  #341
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Fordzilla80
This.
Hopefully leaked.
I would have thought that a leak of a pint in 250 miles would make a big mess. I do have a drip from the bell housing area after a drive, so the rear main is probably leaking a bit. But, surely it can't account for that much lube. Anyway, I've now changed the oil so we'll see how it goes with new 10W30.
And, while under/over things I snapped the attached pictures. I also snapped something else - the plastic line to the aftermarket oil pressure gauge. Unfortunately I don't have the right size of ferrule, so I'm got a plug in it now. And, I'll use this opportunity to put an oil pressure sending unit on there so the factory gauge works. Were all the sending units on the back of the block? I ask because the wire is up front in the Windsor location.
Looks like Rusty has the truck block, although the D7TE-A23 (at least that's what it looks like to me) doesn't quite fit with what I've read. And, I can't figure out the foundry mark. Instead of what I see on The M-Block site it just looks like a partial 5 in a circle. Am I looking in the right spot?
Old Apr 24, 2012 | 06:14 PM
  #342
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Rusty
Gary, that plug, if is the correct heat range, looks to be a bit too lean (look at the end of the center electrode).
Old Apr 24, 2012 | 06:25 PM
  #343
Fordzilla80
Your casting identification code is correct, you've just mistaken the "B" for a "3". Your actual ID is D7TE-A2B.
The foundry code is right smack dab next to the oil sending unit. The oil sending unit is on the back of the motor, right above the transmission bell housing.
Here's a picture of mine. You can see the MCC for Michigan Casting Center, which was where my block was cast. You can also see the date of casting, 8B28, which decodes to February 28, 1978. The hole you see on the right is where the oil pressure sending unit goes, I just had mine out.
And with the sending unit still on the motor, you can see that it's quite hard to see, so if you have a mirror, you may want to use it. You may need to clean the area up as well.
Old Apr 24, 2012 | 07:46 PM
  #344
Gary Lewis's Avatar
Gary Lewis
Bill - That's the Motorcraft standard plug for the 351M - as well as several other engines. And, I do see that the very end of the center electrode is different than the rest - like it has been running hot. What problems could that cause? I'm not seeing/hearing any pinging, but isn't that or detonation what a hot plug could cause?
I'll look again tomorrow. But, mine seems to look different than yours. The pic I took is of a "land" on the passenger's side of the top back of the block. However, there is a recessed area that is full of goop, so that must be where the casting marks are.
Old Apr 24, 2012 | 07:52 PM
  #345
Fordzilla80
Here's a picture of my block from the back. I think the landing you are talking about is on the right side of the block. If you look a little to the left, you can see the recessed area where the Foundry stuff is. There will probably be loads of grease to clean out, which is probably why you didn't see it.
