Rusty
Old Mar 11, 2012 | 08:55 PM
  #181
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Your wife will be happy Gary.
Old Mar 11, 2012 | 09:00 PM
  #182
Gary Lewis's Avatar
Gary Lewis
Originally Posted by bruno2
The bucket O diff parts served its purpose well. You should be proud. Glad to hear the parts truck is doing the same. Whenever you are ready to be rid of it call me and I will bring the trailer out. We can load it up and take it to the scrap yard. Sounds like it will be bare bones before too long.
Well, given that the cab, bed, fenders, and doors will probably go to Dad's 'cause they are better, and the frame may go since I could have it powder-coated while still driving Dad's, I'd say it may be down to a lot of nothing. In fact, I may pull other parts like the radiator support and lots of other things and powder-coat them myself to be ahead of the game.
However, there will be the leftovers from Dad's truck to go to the salvage/scrap yard, so I may well take you up on that.
Old Mar 11, 2012 | 09:09 PM
  #183
bruno2's Avatar
bruno2
Have you made a move towards building the rotisserie yet?
Old Mar 11, 2012 | 10:07 PM
  #184
Gary Lewis's Avatar
Gary Lewis
No. I don't know whether I will do it before swapping the engines and installing the ZF5, or not.
Old Mar 11, 2012 | 10:27 PM
  #185
bruno2's Avatar
bruno2
That makes sense. I agree with not getting too many projects started at once.
Old Mar 12, 2012 | 08:23 AM
  #186
micdzy's Avatar
micdzy
hey gary
mr lewis someone recommended i talk to you. Im looking for a part for my 81 f100. It has the inline 6 motor. Im looking for the set of wires between the icm and distributor and ignition coil. Or the entire harness...any recommendations from you?
Old Mar 12, 2012 | 08:34 AM
  #187
Gary Lewis's Avatar
Gary Lewis
Mr? Thanks for the compliment or respect, but that's not needed on here.
I may have that harness - let me check. I need to make sure that the one I think I have, from a V8, will work but I think it is the same. I'll do that today and get back.
But, could you go to User Control Panel and fill out the info, including location? Who knows, maybe you are close to me.
Old Mar 12, 2012 | 11:26 AM
  #188
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Gary Lewis
RW - I am hoping to test that. However, it might be on Rusty's engine in Dad's truck as I'm planning to make that swap awa the ZF5 installation the next major project. Of course, this is assuming that Rusty's engine checks out with a leak-down and compression test.
And, if it is getting roughly as good mileage as Dad's M is currently getting. However, if it isn't I'll be very disappointed since one runs a C6 and the other the NP435.
Looking at the Holley 4180 this morning that I got from the '85 HO I got to wondering if the carb test should include a box stock 4180 as well as the 1460 and E'brock 1406. Doesn't look like it would take much to put that carb on, when the time comes, and see if what people are saying is right - that the boosters on that carb have advantages.
And, I should also do some acceleration testing at the same time. Not standing-start testing as that's hard on the driveline, and not including a shift as that's too much of a variable, but maybe something like 15 to 50 MPH in 3rd gear?
Let me hear from y'all about the testing, both on the carb end as well as the acceleration as it should be well thought out. Eliminate as many of the variables as possible, like shifts, highway variations, etc. Thought?
Old Mar 12, 2012 | 12:47 PM
  #189
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Those boosters help a lot with atomization.
The 4180's were very lean from the factory.
If your EGR was inoperable you would know right away.
They also had a 2-stage Powervalve that didn't come full open until vacuum dropped below something like 3-4".
From back in the days of my H.O. notch, I can tell you that
FLEMWORLD has a good look inside the 4180 if you follow -> '85 How To's -> modifying The 4180 Carburetor.
I'd like to see a comparison of carbs and think your ideas of pulling one gear from low rpm's (1500?) is about as fair as you could get.
Old Mar 12, 2012 | 01:05 PM
  #190
Gary Lewis's Avatar
Gary Lewis
I'll follow that link later, thanks. But, if the 4180 is lean the test may need some modification or extension. For the Holley's I could try running the same primary jets between the two carbs, like maybe the 66's in the 4160, as well as the stock jetting. (Just tried to take the primary bowl off the 4180 to check jetting, to no avail. Any tips?)
And, probably RPM runs would be the best. Maybe 1500, but I wouldn't mind starting a bit lower. And, going to 5000? In fact, if I could get/borrow one of the accelerometer testers that would be nice as we might see differences in the top vs the bottom end. I wonder if there is an app for that?
  #191
Rogue_Wulff's Avatar
Rogue_Wulff
Yeah, a test of say 30-60 MPH in a single gear (4th?) would be a pretty good way to compare the acceleration difference (if any) between the 2 carbs.
Personally, I'd accept a slightly slower acceleration time, if there was enough of a MPG gain to offset it.
I have my suspicions as to which carb style will give the better MPG, and the better acceleration. I even suspect it will be the same carb.....
Granted, having both carbs tuned well is key to getting the most accurate results.
Old Mar 12, 2012 | 01:08 PM
  #192
Rogue_Wulff
Gary, there are apps for an i-phone to do exactly what you are wanting. One of the ones I know of, is called "Dyno-licious" or something very similar.
The i-phone has a decent accelerometer built in.
IIRC, you have an i-phone.......
Old Mar 12, 2012 | 01:13 PM
  #193
Gary Lewis's Avatar
Gary Lewis
Yep, I have an iPhone. Sounds like fun.
Old Mar 12, 2012 | 01:22 PM
  #194
micdzy's Avatar
micdzy
im on my phone during the day but tonight i will update my profile. Im actually in duncan ok.
Old Mar 12, 2012 | 01:34 PM
  #195
Rogue_Wulff
Duncan is a bit of a drive from NE Ok. 150-200 miles in most cases.
