if the 4180 is lean the test may need some modification or extension. For the Holley's I could try running the same primary jets between the two carbs, like maybe the 66's in the 4160, as well as the stock jetting. (Just tried to take the primary bowl off the 4180 to check jetting, to no avail. Any tips?)
I would just go with the stock jetting in the 4180.
Thinking the comparison would be between an "as delivered" truck and the same with an aftermarket vacuum secondary carb.
The new Holley kits have the blue 'stickless' gaskets.
Not knowing when that 4180 was last opened up it may take a sharp rap with a screwdriver handle to break it loose if it has cork.
im on my phone during the day but tonight i will update my profile. Im actually in duncan ok.
See, it is good to put the location in. We are having an FTE get-together here at my place in Skiatook this Saturday starting about 1:00. In fact, ctubutis is planning to come from Denver, so you won't be coming the furthest distance. RW, Bruno2, and lots of others are supposed to be here as well, probably about 10 in all.
And, the '85 that I mentioned in the WHYDTYT thread may well be here - the one the guy says he's put $45K into but will sell for $25k. He came back yesterday and said he might well come.
Several bows from a rubber mallet didn't faze it. And, the gaskets on the 4180 aren't blue as the ones on the 4160 are, so are probably cork. When it comes time I may saturate it with carb cleaner - not inside the bowl, but on the gaskets. But, I'll wait 'til about time to test it.
Concerning the "as delivered" test, according to the charts I've seen I would have to put 68's in the 4160 instead of the 66's that are in it. So, I may pass on that as it runs great with these jets.
No, no Gary,
I meant the 4180 set up as the truck was when delivered to the dealer.
The 4160 would be expected to be tuned. And if that means leaner mains or a different spring, so be it!
Got it - delivered to the dealer. Makes sense, and I assume this 4180 is stock, although if/when I get it apart we can verify that. And, I suspect the 1406 is box stock as well, but its one of those "expected to be tuned" universal carbs like the 1460. Hmmm, same digits just different order. Interesting.
I was lost trying to figure out the 4160/4180 part of the convo, till I read back and saw where Gary mentioned the addition of a 3rd carb into the equation. I guess I either missed it the first time thru, or simply failed to retain that info...... Intercrainial flatulence (brain fart) would be a good suspect.
The 4160/4180/1406 side by side test would be very interesting. It could reveal quite a few things.
Yes, I added that one (the 4180) in this morning because someone was asking choke questions on those carbs so I grabbed it to look. Realize it would be an easy swap for the 4160, and the rest is history - brief, but history.
thats true. If if find whatever parts i need from someone online ill most likely have to have it shipped
Yep. But, unfortunately I don't have the harness you are looking for. Sorry. However, are you looking for other parts? If so, shoot me a list and I'll bet I've got many of those pieces. Maybe it would make your trip worthwhile.
You can email me on janeyandgary@gmail.com so we don't clutter this thread up too much. Having said that, I've done a bunch of cluttering so don't worry about it.
Yeah, a test of say 30-60 MPH in a single gear (4th?) would be a pretty good way to compare the acceleration difference (if any) between the 2 carbs.
Personally, I'd accept a slightly slower acceleration time, if there was enough of a MPG gain to offset it.
I have my suspicions as to which carb style will give the better MPG, and the better acceleration. I even suspect it will be the same carb.....
Granted, having both carbs tuned well is key to getting the most accurate results.
I, too, would give up a bit of acceleration for a decent MPG gain. And, I'd be willing to run a Holley even given all the bad things I've said about them over the years, to get that. But, I'm guessing that won't be necessary. Somehow I can't see those metering rods losing to a power valve - even one with two steps and good boosters. But, we shall see.
Originally Posted by Rogue_Wulff
Gary, there are apps for an i-phone to do exactly what you are wanting. One of the ones I know of, is called "Dyno-licious" or something very similar.
The i-phone has a decent accelerometer built in.
IIRC, you have an i-phone.......
It is Dynolicious. Sounds good and has a 4+ out of 5 star rating. May just have to do that when the time comes.
I know a lot of the local autocrossers use the dynolicious app, as it can record accel/decel and cornering g-forces. With the right mount, the phone can also record video at the same time......
There's others, but that one seems to have a good rating among folks I actually know......
Good to know. While $12.99 is expensive for an app, it is really pretty inexpensive - especially if it captures all that I'm wanting. Tnx!
Gary, what you and a number of others forget here is that the metering rods are actually called "step up rods" by Carter and work just like a Holley power valve, there is a vacuum point at which the raise, and by doing so make the jet "larger". Some are 2 stage like some Holley power valves. True "metering" rods are found in SUs and a lot of motorcycle carbs. Ford VV carbs and Zenith Stromberg CD carbs also.
Actually, Bill, what I forgot is that you are reading this thread. Didn't forget at all that they are step-up rods, and thought about it when I typed it.
