1978 - 1996 Big Bronco
Project TGM
Old Oct 10, 2012 | 03:05 PM
  #556
GruesomeJeans's Avatar
GruesomeJeans
You might have to post some pictures of it I am currently running at 35 and don't have complaints besides that it seems too little. I just don't want to over pressurize. I also think my rear tires have some sort of tiny leak. They seem to drop down to 30 psi after a few months.
Old Oct 10, 2012 | 03:44 PM
  #557
arctic y block's Avatar
arctic y block
I have never heard of 60psi in a passenger car or light truck tire. Maybe in a 10 or 12 ply 1 ton hauling 3 cord of wood. 60 to 90 in my Log truck. But 32 has always been the norm for empty highway driving. And after 3 spinal surgery's 28 feels better. At 35 or more don't it wear the center of the tread out first? I have 24 in my 33's with even wear and a smooth ride. And they crawl over the rocks better without chewing up the side walls.
Old Oct 10, 2012 | 06:20 PM
  #558
GruesomeJeans
Um i'm not sure really... I figured 40 and above would wear the tire but i guess even a little could wear it. Maybe i should try running in the 20s..
Old Oct 10, 2012 | 06:32 PM
  #559
arctic y block
Much below about 22 on most tires wear the outside. But Damn they ride and handle good. I like em low in the snow. Wow!! that Rhymed.
Old Oct 10, 2012 | 06:36 PM
  #560
GruesomeJeans
Hmm well i will try that some day and see if about 25 is nice. Softer is a good thing i guess.
Old Oct 10, 2012 | 07:09 PM
  #561
1_ton_bronco's Avatar
1_ton_bronco
OMG my f100 is drop dead gorgeous!!!
But ford f250 says 50 psi on door.. so i went in between.. 60 -70
and it is a mud terrain tire.
Old Oct 10, 2012 | 08:34 PM
  #562
bigzirb's Avatar
bigzirb
I always ran my load range D 33's on my trucks and Bronco at 35-50. The load range E's on my Excursion are at 75-80. Just play with it until you find your own sweet spot for ride and tire wear.
Old Oct 10, 2012 | 08:46 PM
  #563
arctic y block
Wow!! That's a lot of air and a damn hard tire. What's it say on the door for max pressure on what tire stock? You guys are killing me.
Old Oct 10, 2012 | 10:13 PM
  #564
GruesomeJeans
Haha, Mine is load range C IIRC, the sidewall i don't remember what it said the pressure was. I would need to look at the door tag to see if it states the psi.
Old Oct 10, 2012 | 11:35 PM
  #565
arctic y block
Never, Never fill a tire and run it at it's max inflation as stated on the tire. Only run them as it said on the door sticker.
Old Oct 10, 2012 | 11:48 PM
  #566
1_ton_bronco
i dont.. max psi is 80.. i run them at 60 or 50 depending on weather/ road condition
Old Oct 10, 2012 | 11:49 PM
  #567
1_ton_bronco
Old Oct 11, 2012 | 12:03 AM
  #568
arctic y block
Hay! That's Funny. You mind if I quote you in the Club? The thread is " Posts that make you say what the H...." The Guys will love this.
Old Oct 11, 2012 | 12:11 AM
  #569
GruesomeJeans
The new paint looks great, time for some daytime pics though So the door tag will be correct even with different size/material/age tires too?
Old Oct 11, 2012 | 12:31 AM
  #570
1_ton_bronco
Lol?
thanks
