Like Brett said. Save yer $100. Take yer Mom out to dinner with it. I would ad that when seating the studs an air compressor works good also with a washer under the lug nut with the wheel off to suck them in all the way. But a 4 way lug wrench works also. Yer young Bud. DIY. I have done many without pulling the rotor. Check it out. If there is one place in the rotation that the stud can come out. Than ya don't have to pull the rotor. I would do it this way in my shop 7 out of 10 times and beat flat rate shop time. SOOO the shop if they are any good at it will have it done in like 15 minutes and charge you how much? I'm just sayin Bud. But yer Mom would rather ya spent the money on her. Right?
PS: I would ad that to get a spot to get the studs out take off the backing plate. I think 3 an 5/16 headed little bolt. It works on some. Worth a shot anyway.
Thanks for the info guys, i guess sunday i will take the wheel off and check it out. I really don't feel comfortable trying to take the hub apart. If i can do it without pulling everything apart then i will. Yeah i know the hub is easy, probably easier than pulling a transmission. But i just don't feel comfortable messing with something like that.
As for my money being spent on my mom... No she would rather i save it for something else, she doesn't like when i spend it a lot.
I would just make a trip to your new Autozone, they should have some in stock that are right.
Pulling a hub is super easy as long as you have the spindle nut socket and a decent pair of snap ring pliers. No fluid to lose, just grease all over your hands.
Replacing them is so easy it makes you think you're doing it wrong. Just smack it out with a hammer, to seat new studs just pull it thru hub, place a few washers or something on it and thread the lug nut on, then just crank it down.
Yeah I can do that. my fear wasn't to much the studs, I feel like I can do those, its the hubs I'm worried about. I guess the only thing to do is open them up and go from there. Are the studs pounded into the rotors themselves? If so I might as well but new rotors too cause mine are getting thin...
Ok so i got some choices. If i do the work myself, i will need to buy new grease, bearings, and possibly other small things. I will have to get 2 rotors, cheapest ones are $29.99 per side and don't have studs or the center section pressed in. To buy a rotor that has all that stuff it is $209 for only one rotor. Studs are cheap and i will probably need new lug nuts which are probably cheap as well.
I didn't realize the rotors didn't come with any of it. I am thinking for now i should just buy the studs and bearings and do that. But i don't know. I don't know what i am doing anymore...
Rotors with all WHAT stuff?
You really should have done something with the rotors, turn or replace, when you did the pads. That said;
You don't NEED any parts really to replace the rotors and studs(except the studs and rotors of course), but the seal is cheap and at times hard to get out without damaging it. However there is a trick to get the seal out without damaging it so you can reuse it.
Bearings are the pricey part, and while you should buy some to have on hand in case you need them. You only need to replace them if they show damage. Otherwise you can return them and get your money back.
There's only a few moderatly hard parts of doing this. Packing the bearings with grease, here a ziplock back works great. Getting the right tension on the bearings, take your time and feel it out. And installing new bearing races if you need new bearings.
All THIS stuff Duralast/Brake Rotor - Front (5492) | 1978 Ford Bronco 8 Cylinders H 5.8L 2BLModified OHV | AutoZone.com
The center hub, the studs all the goodies. I think what i will do is pull the passenger side apart then i can figure out everything i need and go on a shopping binge . I KNOW i need rotors at some point cause mine are thin and rusty, yeah rust isn't the biggest issue, so i am not so concerned with it.
This is what i was looking at towards rotors, it is cheap and more for my budget. http://www.autozone.com/autozone/par...1_172979_2708_
I can't say why it is so intimidating to me, it just seems like getting these hubs apart is way out of my league. I guess since i don't really need to drive my truck anywhere anytime soon, i can "experiment" with taking that stuff apart and figure out what i will need to do.
Not sure what your trying to point me towards there, the only parts you can't reuse are the ones your there to replace. The $30 rotors and some studs. That is an assembly with the hub and studs already installed on the rotor. But you'll reuse your hub and put in your own studs.
Yes. I was trying to show you that the hub and studs are the stuff i ment in the earlier post. How does the hub separate from the rotor?
The studs hold the 2 together, so sence your replacing your studs you'll just pound out your studs, pull the old rotor off the hub, put the new rotor on and pound in new studs. All ya need is a good size hammer(not claw) or 2, a drift(could use a bolt) for the broken ones and to reach the back of the new ones, and a couple blocks of wood to hold the rotor/hub up off the floor.
So your shopping list is 2 plain rotors, 10 studs, grease, all 4 bearings with races, and 2 seals. Do your work, then chances are you can return the bearings, races and seals.
If you do end up needing bearings don't replace just the bearings, replace the races to. For that you will need a hammer and chisle to get the old ones out, and an installer to put the new ones in.
Don't forget to grease the hub, might want to replace the o-ring and the bolts if they have issues, at least use anti-seize on them. The little bolts for the hubs are the most likely thing to break.
